Everything posted by Weegie
Thankyou @Mikko, I have 4 bikes but the Ducati 1098 is going, it had more than enough power to scare the Bayjasus outta me. That'll leave me with the 3 Magnis at my age my riding days are numbered (especially with the Scotish weather) so the 3 of them are more than enough, I'd have loved to get my hands on a Giaponne, but would rather stay married. Lashings of BHP would only get me into trouble that I don't have the skill to extracate myself from. The Australia when I first purchased it a good few years back below. I'd hate to sell any of the Magnis it'll break my heart when the time comes. Its an Australia 98, they were built in 2 batches, I think the first were built in 92, using the original Daytona/HiCam engine with a sort of Hybrid frame that's a cross between the Beam and Tonti type frames. The second series used the Daytona RS engines/HiCam 'C' Kitted (almost identical to the Centauro but with slightly different cams) and a beam frame very similar to the one Guzzi used. There are some other smaller differences between the 2 batches and at first glance they're hard to tell apart (engine colour and forks are the giveaway). I believe there were around 130 built in total, Magni's plan was to build a lot more but Guzzi couldn't supply him with the engines/gbxs and running gear. Good luck with modding the HiCam I'd certainly be interested if you start a thread on what your doing and how it progresses. As with all of my bikes I'm that useless I just count myself lucky if I can get them to run in factory spec. I'll settle for the HiCam not overheating, making good oil pressure and remaining oil tight. John
That's an interesting way to go @Mikko I'd never really considered, I'm also in the UK so even if I wanted to it's not really an option, although there are quite a few places in the UK who do offer hi tech coatings as part of their range of services. As you'll have seen a lot of owners have HiCams that run cool, I think I've just got the red headed stepchild. Where did you get the idea of larger crank bearings, I've never heard of that, or any mods to the crank/rods that I know of. Some of these engines have been extensively modified, @Paul Minnaert and @Lucky Phil have far more knowledge and skill than me when modding these engines, perhaps they'll chime in Personally I'm happy enough with the amount of power these blocks generate. I don't have any plans to start trying to tune them, I've enough trouble as it is. There are mods that can be done to reduce the oil consumption, eliminating the second bearing on the service shaft and converting it to a single bearing stub shaft is one I've heard of, I do believe there are others. A good place to start if going down that route would be to look at the MGS-01 engine parts book and any other information on it. Modifications were made on that engine to alleviate some of the shotcomings of the original Daytona/Centauro designs. Good Luck with it, so is your engine apart at the moment then? John
I don't own a Centauro but have a Daytona HiCam engine which is giving me a lot of grief (but that's another story). Just a couple of thing's Mikko, if you know already forgive me. The HiCam engine has both belts and gears, gears to drive the oil pump and service shaft and pulleys to drive the cams from the service shaft. I see somebody went the gear to chain route, but as you have a Caruso pump & gears, you are obviously not considering it..................wise move! AFAIK the V11 chain and pump conversion will reduce your oil output from the pump at least 20% (probably more) the V11 pump is smaller and the chain drive turns the pump slower. The HiCam engine has the largest oil pump of all the bikes of that era. This is supposition but I think the reason for the crazy sleeved oil pump is because Guzzi needed to make the pump large and then didn't have room for a roller bearing on the pump, so they just sleeved it instead. I wonder what oil pressures these bikes have after the conversion. I'd put at least a temporary oil pressure gauge onto it to see what pressures you get when the engine is up to temp, the relief valve is known to leak, an experiment I'm still fooling around with, I reckon if it's in line with the limited anectodal evidence I have it will be in the 40s. That said, I've never heard of a Centauro running its bearings except if there's been oil starvation from the pump breaking or the oil hoses coming off the oil cooler. I assume you've found Phil's excellent build thread https://www.v11lemans.com/forums/index.php?/topic/20664-v11-daytona-project/ My own woes are documented here if you fancy an amusing read at my expense https://www.v11lemans.com/forums/index.php?/topic/21884-hicam-oil-pressure-gross-stupidity-and-why-you-should-always-listen-to-chuck/ Just some info, make of it what you will John
So here is some rough oil pressure data I currently have running the bike on Motul 300V 15W 50 with the Griso spring in the PRV on the HiCam 20C 1200RPM 83psi 30C 1200RPM 81psi 40C 1200RPM 80psi 50C 1200RPM 79psi 58C 1200RPM 76psi 64C 1200RPM 63psi 64C 3000RPM 80psi 82C 1200RPM 40psi 82C 3000RPM 74psi 82C 4000RPM 76psi 90C 1200RPM 32psi 90C 3000RPM 72psi I reckon that bike will normally run at least a 90C oil temp under normal running and in order to get the pressure down a little at the colder oil temps I was wondering if it would be worth changing grades to a 5W 50, Motul have a fully synthetic car engine oil in this grade and as there are no wet clutch issues with the Guzzi, I wouldn't have thought that there would be any harm running an oil specified for car use. I'm pretty relaxed about any pressure below 80psi and the differences between the idle and 3kRPM pressures seem to be less when the oil is thicker (generally after 3k there isn't much change in pressure no matter the RPM). The problem being I daren't start it and ride it as I dread to think of the pressures I'd see below 65C when the RPM rises. The pressure pretty much plateaus at 2k more RPM just tends to raise the pressure perhaps around 4-5psi I wouldn't do this right away as I need to get the bike out for a decent run to get an idea of where the oil temperature stabilizes and that would determine if I change to a 5W-50/10W-60 or not and/or adjust the PRV by removing the 1.5mm shim, which I think would drop the pressure around 15psi. I'd be a bit loathed to do that though as at the higher temps the pressure is pretty well where I'd like it to be Just sorta throwing this out there for some experienced heads to comment and see what some of you thought. John
ANSWERED Sexy pictures!
Weegie replied to pete roper's topic in Special place for banter and conversation
Don't trust her Pete, she's 2 timing you, I got the same offer If I had the energy anymore I'd take her up on the offer -
Forgive me docc "Two Nations divided by a common language"
That's what I was thinking too, I don't know the Tonti frame's ins and out that well. With the Sfida which is Magni's take on the Tonti, there is a spacer and failing to install it or putting it in the wrong place does exactly that
Are we talking 1100 Sport injection? When you undo the clips on the lines there will be some spillage, but anytime I've had the tank off on mine (and that's a lot) neither inlet (petcock side) to the system nor return (fuel regulator) needed anything special. Simply undo the jubilee clamps or whatever else is holding the lines onto the petcock and the regulator then pull them off Be prepared for fuel to run out the lines but it doesn't spray everywhere if that's what concerns you at least mine never has.
I think I've now about reached the end of this but wanted to post some more prelim data for now and some more test results tomorrow. Who'd have thought I could spin out a 4 page thread on a bloody spring. So here's what I've found as a rough guide regarding shimming the OEM valve with the Griso spring. Below are 2 results, the first colum is static test data. In other words putting the valve in an oil tester or pumping up the valve on oil, if you use air the results will be different, probably lower from what I saw. I gave up on using air as a medium the leakage was so bad I couldn't obtain repeatable results. The oil I was using was a 15-50 full synth room temp 18-20C, cold oil for both the static test and the crank test. When static testing the valve just starts to crack then around 5psi later is well off the seat so it's difficult to pin down an exact lift value, but easy to get a ballpark within 5psi for when the valve lifts All results psi, shim numbers in mm. On all of these there was no crush washer or shim on the spring retaining nut on the PRV top, some have these installed others not. IMHO they serve no purpose, however, if they are in place they will subtract from the shim value as the nut will not penetrate as deeply into the valve body and compress the spring Shim Static Oil Pressure None 80-85 68 1.5 105-110 82 3 125-130 95 I think the results were pretty well linear in behaviour, so as a "Rule of thumb" for every 1mm of shim compressing the spring you'll see 14psi increase in static lift pressure and approximately 9psi on the oil pressure. Can only base this on my own anectodal evidence, but knowing that no shim gave me 68 and 3mm shim gave me 95, a 27psi difference, 1mm equated to 9psi. 1.5mm should give me pressure in the bike of somewhere around 80-83psi. When I crank tested it was somewhere between 80-82psi. If you have a facilities to static test by all means do it, you may get different numbers to me, but be aware that the static lift values are higher than what you'll see inside the engine. The figures here are just what I saw and posted up as a rough guide and starter for anybody mad enough to try it
Thanks Tim Looking at some of the comparisons, I think the valve in the bike as of now isn't as good as when I conducted the first test. Whether this is because this valve isn't preloaded (allowing some, or more, float), because the PRV clearances aren't as good or something to do with the lower setpoint I don't know. Hopefully I shall find out when I change the oil and replace the current valve with the TLM valve and Griso spring (still awaiting the new spring to arrive) which I will preload to 2 or 3mm. The idea being to mess with the valve internals as little as possible Looking at the first test and the most recent comparitive results are below, obviously nothing is exact here so a little latitude in reading the results is required. The main points I'm interested in are the 80C readings at elevated RPM. The second test valve has a lower setpoint and given that is the case (around 66-68psi) the idle results are all pretty much in line and way more than required. However the results at 80C 3&4k rpm are pretty stark around a 15psi difference. From what I see pretty much after 2.5-3k rpm oil pressure is constant with revs Same oil and same cooler (a 13 row, but smaller area, Setrab, with -8 hose and full flow fittings) so the only variable is the PRV. Motul 300V 15/50, full synth lube. 20C/idle 80psi 68psi 40C/idle 70psi 66psi 60C/idle 60psi 62psi 80C/idle 38psi 40psi 80C/3k 75psi 60psi 80C/4k 75psi 62psi Even as is it stands though its a big improvement over say the 43psi reported on @Lucky Phil thread page 5 by @Kevin_T . If I could get that 13-15psi back I'll be a very happy bunny, but for now at least I can rev it a little without fear of damage
Apologies Phil It's running Motul 300V 15/50 full synth. All tests have been conducted on that oil, so differing results have nothing to do with changes to the lubricant. Yes at the moment it's running the 1100 Sport PRV no spacer, Griso spring. The 1100 sport valve is the same part as the OEM HiCam engine's valve, the only difference is the spring, which of course is changed out for the Griso. I have another valve from TLM and awaiting a Griso spring for it. When that arrives I plan to douse the valve in oil and change to the Griso spring adding a 3mm, or 3mm with a 1mm spacer on top (effectively giving a 2mm spacer) onto the spring to preload it. The idea being it ups the setpoint and the extra preload on the spring might help drive the piston in the valve shut at higher oil temps (lower viscosity), in my case that would be normal running temperature of 80C and above where I think the valve will be completely closed. I could be wrong but I believe these valves are quite sensitive and should be liberally oiled when tested. If not the piston faces could get scratched and results in the valve passing even more than it does when it's new. If none of that improves anything I can see a move to 60 grade oil in my stars. I think Paul Daytona and one or two others already run the 60 grade. Differences will probably be ngligable, but as my engine runs hot, I think it's a reasonable move, if I still want to increase the pressure a little. One thing at a time though and change out the valve first. At the moment though I'm pretty happy thanks to all the help I've upped the pressure at least 10psi and probably a good deal more. So thank you to everybody for the assistance and it's nice to see some light at the end of very long tunnel
So couple of data points first a long boring video showing the results. Pressure is still a little low but I wonder if the pressure at the gauge is the same as what's at the crank, possibly a little higher at the crank. As the 2 valves run at this sort of pressure too I suppose it's nothing too much to worry about. Certainly better than in the 40s which I reckon the OEM will give you. Oh that Staining/drips on the tiles is some small leaks where the cans mate to the pipes, and the drips are water. There was another small oil leak from a rocker I reckon now fixed I'm just adding all this stuff as data points for others to let people see what the results I'm getting. Tomorrow I'll try to post a comparison of the different tests just for some more info to tie it together a little more
Hi Cam - Temporary Fuel Tank Do I need a Pressure Regulator?
Weegie replied to Weegie's topic in Technical Topics
Ok thanks Phil that's really what I thought. Cheap reg to run with it about £20-30, plan to use 2 tanks I think (the beer cans) with a line between them to hold level, so not too bad It was just a drip about every 30 seconds or so wouldn't have affected the running but made a mess inside the Oz fairing, after a while. Pretty sure it was that rocker gasket that was missing, nothing above it and there were tell tales drips on the rocket cap screws at the lowest point. Everything else was clean(ish). Had a spare so it's now on and ready to try again Nothing to worry about, Oh I'll add a video to the Gross Stupidity Thread later today as I got some video and data. Thanks for chiming in both you and docc's input appreciated -
Yeah it's an idea I do have 2x5 litre empty (a long time ago) beer cans. I'd need to do a little math though on what the rate is, I'm assuming the return is more that the bike drinks by some way so if it's returning a lot, running time could be limited, I could connect the tanks together using a line to balance them I'm assuming that the tank regulator back pressures the system and reduce the flow. I don't have a curve for the Bosch OEM on the bike, but a replacment Pierburg (IF it's characteristics are similar) is flowing about 100-110 litres per hour at 3 bar. With no regulator it would be higher with just the system components and hoses offering resistance...................I think!!!! That's partly why I'm asking the question, it wouldn't allow you much running time even regulated if you only had 5 litres to play with and no return. Saying that a Chinese Bay of Fleas regulator is pretty cheap and would be fine for just a test rig to run -
No not on the HiCam @docc that engine has an external fuel pump (located at the head of the frame) In tank pumps were later Oh may have found the leak anyway, a PO had installed 2/3rd of the left rocker cover gasket, he decided to save weight an leave 1/3rd out, that looked like where the leak was eminating from but not 100%, I'll only find out when I re-run it. I'd still like to have a method of using a temp tank, as it's a handy tool to have -
I've got an oil leak on a HiCam but where I've got no clue The easiest way to find it (& It's a good idea anyway for temporary use when testing) is to make a temporary tank/vessel to use a temporay feed. Ths would allow me max access to the engine and possibly see where the leak might be However being an injected bike I'll need to have a line into the temp tank for the return line So could I just run the line on the return into the temporary tank or do I need to rig up some sort of regulator to back pressure the system? I'm thinking I'll probably need something and wondering what I could rig up. Is there such a thing as in-line regualtor, I'm guessing they as simple spring and diaphragm devices but don't know. John
I got a lot of stick on WildGoose for saying the Daytona front forks were nigh on useless. It was a shame and a huge mistake by Guzzi to intorduce a new frame design with crap forks. I'm sure a lot of people thought the frame was at fault. Of course in typical Guzzi fashion, the stable door was closed, they were replaced with WP units, long after the horse had bolted. Anyway, when the BEARS racing was happening the few brave enough to enter a Guzzi Daytona, usually changed to GSXR forks, it's a road that's been well travelled and repeated by many owners, I'm ASS-uming the Sporti wears the same or similar front end. Personally I never tried it, as at time I never had the cash
Well bet you were all thinking this was dead and gone. So after removing my OEM V/V with Griso spring to try to lower the presssure a little I then couldn't get the valve to seal well again. I purchased an HMB valve and tried that but although I did get static tests that looked great whenever I put it in the engine I just never got the pressure I was expecting. The only explanation I can think of for differences I experienced between static and engine testing, is that oil pressure in the bike is constantly fluctuating probably at quite a high frequency so the valve is constantly chattering and you can't replicate in a static test. Anyway I took the PRV out of the 1100 Sport which is identical apart from the spring and used it with the Griso spring in. Static tests with the 3mm spacer showed the valve lifting at 120psi, a tad too high for my liking so I removed the spacer and got the v/v lifitng at 85psi. Put that in the HiCam engine and did a crank run, 68psi.................Hmmm Today I ran the engine, cold oil idle was around 80 psi and when the oil got hot 60-80 C the valve seemed to be controlling at 68psi. Before I had 83psi setpoint and the valve controlled throughout the range, but I think because now with the lower setting of 68psi, what's happening is the valve lifts earlier and the system pressure vs the PRV lift pressure is a larger delta. So when the oil is cold the valve gets choked and system pressure rises above the valve setpoint. I'd ideally liked to have the lift pressure to be a bit higher but learning from my previous experience I'll leave it at 68psi and call it "job done" Even at this lower pressure setting it's night and day over the standard spring with its 55psi cold idle and lower operating pressure throughout the range. Finally it looks like I've arrived at, if not the ideal solution, pressures that seem reasonable. The next question is how will this affect cooling? I'm hoping the higher system pressure will lead to the engine possibly ruunning a bit cooler, but that's for the summer and a good run out.................and that's a bit away yet
Count me in!! Me..............all the gear and no idea. If I wasn't so dammed old and had other shit to do I'd be building a Guareschi as well and it still might happen. Of course throwing my aging corpse into the saddle might be another issue
"New" 1100 Sport with 1388 miles for sale in Raleigh
Weegie replied to al_roethlisberger's topic in Older models
Gotta be "Medic Andy" on WG surely -
Thanks Phil Here was me labouring under the misapprehension that the temperature viscosity relationship was linear, which it clearly is not From that graph it appears that after 70C and certainly after 80, a temperature approaching normal running condition, that the viscosity changes are pretty much negligable Very interesting
I did mean to comment on this Phil, as I'm seriously considering both The Griso spring will help to hold the pressure as the bike comes up to temperature and eliminate some (but not all) leakage. However when the engine's hot, 80C+ oil temp the max I obtained at 4k RPM was 75psi. The relief is closed at running temperature and only oil weight will have any effect on pressure. 75psi is sufficient and I'd be more than happy enough with that (and continue to run my 15/50) IF the engine temperature stabilizes at 80C. A shakedown run will be the only way I can establish the true hot oil temperature and Winter is knocking at the door here. It appears that after around 3k the pressure maxes out and increasing revs to 4k did nothing to increase the pressure. I can't say for sure that it doesn't rise at revs above 4k but from the data I've gathered so far it certainly looks like it's peaked by 3k RPM. John
Hi @Twin AH I've got some pictures of the teardown and install of the Caruso gear and pump change. At some point I've been hoping to a do a "how to" if that's what you're referring to, but it hasn't happened yet. I don't know of a single document or place where all the mods are listed and it all depends on how far you want to go. I'm sure Lucky Phil will chime in and he's the real expert. As far as the Griso spring change out, I'm the only person to have done it as far as I'm aware and the bike hasn't even been out on a shakedown run, although the results are encouraging. The problem as far as I can see is the original spring is too soft and so starts to lift early. The Griso spring is much more positive helping the valve to seat and only lifting at it's setpoint. Once the engine is up to temp the valve will be shut (but probably still leak a little it's a rotten design), The OEM spring will probably still float and rob the engine of oil flow. I haven't done extensive testing with either but a few have reported that running oil pressure can be lower than I'd personally be comfortable with. Have you read through Lucky Phil's Hi Cam build? That's a great place to start. https://www.v11lemans.com/forums/index.php?/topic/20664-v11-daytona-project Part number for the Griso spring is 94321077 All I've really done of significance is the Caruso pump & gear mod, the Griso spring and installed a different oil cooler as I didn't like the OEM setup, due to the 4 banjo fittings which I reckon will introduce a signifcant pressure drop across the cooler. However with the exception of the Caruso gears and pump, I can't recommend them any of them yet as the bike hasn't been out on a proper run to asses them
Oh @Kevin_T to also answer your question on why Guzzi didn't do it from the get go. I can only surmise, but Guzzi were not in a good way during the 90s and could barely keep their head above water, the situation getting worse as the 90s went on and into the early turn of the century. I think they were desperate to get a new model out and increase sales. The HiCam engine was not a well developed product, it was a race bike engine to which the minimal of changes were made to make it just about suitable as a road machine. There are many flaws in the design which were probably only really seriously addressed when the MGS-01 was designed. It probably wasn't perfect either, I don't know enough about it. The MGS heads and oil flow to the heads are different in many aspects. Back to the HiCam, for goodness sake you need to remove the service shaft pulley to change the belts on the OEM design. You'll hear Chuck often comment that the only reason they assembled the Centauro was to make sure you got all the parts. The relief valve is probably only one of a long list of things that should have been sorted. They either found or thought that with the increase in oil flow required they'd just make the pump bigger, leading to the "grenade with the pin pulled" pump design and shim the exsiting spring in the relief valve to increase the pressure setpoint and that would be that. What I found when I swapped over the 1100's relief valve which is set 10-14 psi lower, there was no change still the 50psi cold oil idle. That leads me to think the spring in that valve although working well with the 2v/v engines is unsuitable for the HiCams. At 50psi the pressure is below both the 2v/v and of course 4v/v setpoint. I suspect (but don't know) that the spring is too soft and the valve is partially lifting. That's been proved through Phil's rather over enthusiatic spring holding the valve shut and seeing system pressure build to way in exceess of that required on cold oil. It can also be seen on my engine run test with the Griso spring earlier in the thread as well, where the pressure holds 82 on the relief valve setpoint. The Griso spring though shorter is stronger and heavier, holding the valve shut, the valve still passes but not nearly as badly as with the OEM spring. From my rather limited engine run you can see how much more positive the relief valve action is. Rather than the valve floating slowly open on the OEM spring, the pressure rises until 82psi (that I had as an aribitary setpoint) then "Boom" the valve opens and you can see the gauge fluctuating in response to the valve chattering, constantly opening and closing at its designated setpoint.
