Everything posted by p6x
@Tomchri Your system works on 12 Volts. I am looking at something completely mechanical. No wiring modification to implement. I only need to confirm the dimensions of the spare port hole. Then I will need to look for something to go from M16 male to pipe/tube connection on the other side. The vendor of the Rochester instrument confirmed that theirs require a JIC 5/8"-18 UNF to seal around the capillary. The other information that would I would appreciate, is the length of capillary I should go for, to set the gauge somewhere at the dashboard level. The gauge diameter is about 51+mm. These gauges are designed to be mounted on a dashboard. I am thinking this should be above the existing Guzzi instruments and lights panel. The European are all offering a fixed length of about 1800mm The Rochester comes in four lengths: 48", 60", 72", 144" (1219mm, 1524mm, 1828mm, 3657mm). I can coil the excess underneath the tank (maybe), but it would certainly help to purchase the closest to what I need.
After two days of driving around, I have a small inconvenience to report. The thermometer gauge vibrates between 65 and 70 mph. Not enough to make the instrument unreadable, but it does look out of focus. Strangely enough, the clock is not affected, and remains unvibrating at the same speed. Now, I do not know why the right side behaves differently than the left side, but I am going to try to find out if I can do something to alleviate the problem. Something I have noticed is in motion, yesterday, the temperature read about 106 degF. After a stop, it was about 101 degF. Since the Formotion gauge has no probe, I am thinking it is not very accurate. Good enough when the bike is not moving.
@docc I am not certain M15 exists in the Metric standard. It could either be M14 or M16 both with 1.50 mm thread pitch. The oil drain in the middle of those two threaded holes, what is it for? the main drain is underneath the sump, is it not? I am asking because this hole is M10, thus, I found one of those mechanical oil temperature gauge which fits an M10 threaded hole. I found an adapter from M14 x 150 male to 5/8"-18 UNF Female. This would work for the Rochester or Smith gauges. https://www.bpsracing.com/adaptateur-de-filetage-femelle-5-8-unf-male-m14-1-5.html
@docc The oil drain plug is m10 x 1mm pitch. The other plug looks larger in diameter, maybe M12. But it is only a matter of finding a crossover to either M10 or 5/8" UNF
@Tomchri@docc I found the drawing from the spare parts catalog. There is a spare hole. Of course, Guzzi does not tell us the dimensions of the adapter to pipe they use. Once I figure out the specs of item 22, then I can check what crossover I can use to 5/8"-18 UNF, or I can go Smith. It does not matter if the Temperature is in C or F. I am familiar with both scale.
This is perfect. Do you know the size and thread pitch of the plug? If it is a the threads are parallel, then there is an o'ring to seal. If the threads are conical, then I just need to install a nipple that fits the hole on one side, and the capillary on the other. The challenge is those threaded holes are metric. What I found metric requires a 10mm diameter hole. The easy way, since 5/8" UNF seems the standard, would be to find an adapter Guzzi threaded hole Male, by 5/8" UNF female. If you can tell me what size it is, I can start looking for a Male by Female cross-over. I found a lot of mechanical oil temperature systems for air cooled engines. A lot of them for airplanes. This is made by Rochester. However the nut is 5/8"-18 UNF, not going to fit a Guzzi. This is Smith; UK based. Those of you who had Jaguars and Triumph cars will know that brand. Another 5/8 UNF-18 adaptor, by 3/8" British Standard Pipe I found this one in Switzerland; the capillary fits M10 x 1.5 mm thread pitch.
Making a “Beeline” work – the alternative Sat-Nav
p6x replied to Cabernet's topic in Travel & dealers
@LowRyter I have considered purchasing a Beeline, but have abandoned the idea. Here's my rationale; I don't know how are roads in Oklahoma although I went there for work once. Today while coming back from Katy on the I-10, I had to avoid three palettes dropped on the asphalt. The car that I was following (at a distance) barely avoided them, and as he was obstructing my view, I had less time to react too. The other typical issue we have, are the numerous delaminated tire debris which can cause a fall. But not only that. It is my strong belief that on a motorcycle, you need to keep your eyes on the road all the time. A couple of seconds glance at the dashboard to check for warnings is safe. In my mind, keep eyes on a navigation device is a possible cause to have an accident because it requires too much attention. This is why I deliberately exclude any screen to compete for my attention. About Beeline; I read lots of reviews complaining about devices that stop working and an under par customer service in Europe. Generally speaking, customer service in the USA is a lot better than what we have in Europe. Also, Beeline requires to pair it with a phone. That makes up for some kind of redundancy. If I have to pair my phone, why do I need Beeline? Personally, I only "listen" to directions, and I found the best application to do that is Waze. My phone remains in my pocket, and I follow verbal instructions spoken through Bluetooth. My helmet is equipped with small speakers. Other advantages of Waze, you get warnings about hazards on the road, traffic issues. This is the best App for navigation for motorcyclists that don't watch the display. Google and Apple not as good with voice commands. By only listening to my navigation, my eyes keep scanning as they should. My major problem is the noise in my helmet. If I wear ear plugs, I don't hear the instructions any longer. I need to find ear plugs that lower the noise without completely cutting the Waze audio commands. For the record, I participated to the funding of the Pebble watch, which failed lamentably and was purchased by Fitbit eventually. My Pebble watches invariably failed after a few months. The display became unreadable. Pebble was a US company, they had a good customer service. They replaced the watch each time. Towards the end, they no longer did. I would think that Beeline does not have the financial means to perfect their design and make it reliable. What you are experiencing I have read about in the reviews. -
Working on my head light last week.... three showers and complete change to carry out the task.... My biggest problem is vision..... I am short sighted, so I need to remove my glasses all the time to alternate near sighting and far sighting. It is only with old age that I no longer have glasses that do both. At least, I don't need so-called reading glasses. Do you have a bench with a vice?
I had the exact same problem on the Le Mans last week, when I attempted to replace the H4 lamp with a LED light in the head light. I followed the manual's instruction, requiring to remove the little "access trap" underneath the fairing, to get access to the screw that enables pivoting the assembly upwards, and removing the diffuser/reflector. What I did not know at that time, is that the clip on nut was attached to a plastic tab inside, and the plastic tab was no longer holding the nut. @Tomchri suggested to take off the entire fairing, which I did, and this is when I realized what was happening. I repaired the plastic tab with modelism plastic glue. That saved me from purchasing a replacement bucket. I did notice that a lot of the hard plastic parts become brittle with time, especially when exposed to so much UV light.
I finally installed the two Formotion instruments after a long moment of reflection. Rather than using the front fork tee, I opted to use the 6mm screws that hold the front fairing cover. It is not (yet) perfect. I have plastic bushings that I was planning to file down at an angle, so the instruments would be perfectly in line with my vision when I ride the bike. But I need a vice to do that properly. Instead, I used washers to make up for the recess, and simply installed the thermometer on the left and the clock on the right. No permanent modification of the Guzzi. That's what I prefer. Unfortunately, the Formotion instruments don't have night fluorescent pointers, at night they will be unreadable. Which is fine, since I am still not planning to ride at night. ______________________________________________________________________________________ I am considering the installation of an RTD or Thermocouple based Oil Temperature indicator. I know that the oil temperature information is unnecessary. I am simply interested in finding a way to do it. I would like to get that information on the dashboard, so the oil combined thermometer dipstick is not what I am looking for. One way to use gas flow rate, is to measure pressure, differential pressure across a known orifice, and of course temperature taken in the gas stream. Before electronics took over, we used RTD devices, which were completely mechanical. I found what I was looking for in Europe, now what I need to devise, is where to connect the temperature probe on the Guzzi. But its another thread I guess. [docc edit: agreed. Installing Oil Temperature Sensor thread created based upon @p6x's comment, italicized.]:
Motorcycle Grand Tour of Texas - 2022 edition - Repository -
p6x replied to p6x's topic in Meetings, Clubs & Events
Lots of police prowlers on the return trip. Maybe someone decided to temper those heavy right feet and wringing out right hands?- 111 replies
- 1
- motorcycle grand tour of texas
- 2022
(and 3 more)
Tagged with:
18,000 miles on the odometer. I have doubled the amount from the day I got the bike. 8800 miles from 2004 until April 2021; although I don't know what the exact mileage was since it was disabled when I got the bike. The Tour of Texas is an easy excuse to go for a ride. I am already longing for the next excursion.- 111 replies
- 1
- 2022
(and 3 more)
Tagged with:
I should have, not only to protect against insects, but I also got sun burnt. Including my wrists, since I rode with short gloves, and there is a band of skin showing between the glove and the end of the sleeves. Riding Australia's back country is certainly more challenging. Can you even get gas easily? the one peace of mind you have here, is gas stations are plentiful. I think on 77, on my way back, there was a sign indicating a 60 miles drought from the last station. But I was riding the main highways.- 111 replies
- 2022
(and 3 more)
Tagged with:
I did it! would I do it again? no! it is not about the physical limits, it is about being on the clock. I did not take all the photos to document the trip the way I wanted to. The time lost to get to the South Padre Island stop and other incidentals put me behind schedule. Stops 24, 29. 17/50. 805.8 miles (793 miles recorded by the ITI Odometer) (approximate)1297 km in a single ride. Funny to think that in Europe, on such distance, I would have crossed multiple borders. In the USA, I could remain within a single state albeit, the second largest. Edited on June 28th, 2022: I refilled the tank and attached the detailed fuel log to the post. 19.522 Gal of premium gas exactly; which for 806 miles is quite good! (91 liters for 1300 km) Highlights: What an Incredible experience! The Le Mans managed better than expected in the sizzling heat; Riding in the night is great too! Lowlights: Stung by a (which kind?)bee while riding; Stopped for speeding Incredible traffic from Port Isabel all the way into South Padre Island. Why can't motorcyclist go through the lanes? Unpleasant moment with Customs and Border Protection coming back from South Padre Island My legs were the weakest part of the trip. The fixed curl angle is killing.... Details: Between Wharton and Victoria, I got my first police pull over ever, for going 84 mph in a 75 mph zone. This came as a surprise, because in Texas, I thought the unwritten rule was 20 mph above posted speed. The police officer was quite nice and asked me a lot of questions about the Le Mans. So many, that I am thinking he just pulled me over to discuss it. I explained him it is difficult to read 75 mph on the speedometer, because the tick is blending into the dark background of the instrument. Besides, I don't see well at a short distances so it is all a blur. He was very young, and maybe he was not expecting a senior guy speeding? Between Wharton and Victoria (again), I got stung by an insect. It got caught between the top of my jacket and my neck, and decided it was my fault, defended itself. I am not allergic, but having a large red volcano on the side of the neck ruined my otherwise casual looks. This morning, it itches very much. What makes it funny, is the first stop in Hidalgo was a Killer Bee artifact. Fate maybe? painful one too. I had been stung before, and I knew what it was right away. I let the pain ride its course, did not try to touch it, stopped at the next gas station to check it out! The ride in the Texan humid heat was not a problem at all. I was not expecting it would be, and it did not affect me. I drank water, and coffee at my refueling stops, every 150 miles even if I could have pushed to 200 given that my average fuel consumption is around 40 mpg. I would have liked to have had a co rider, to have someone else's opinion. I did not cross many other bikers. The ingress to South Padre Island was a real nightmare. Saturday of course, vacation too, but Port Isabel had road works to add more lanes for the future, reducing flow to just one lane per side. The biggest choke point is the causeway to South Padre. There is room for two lanes, a motorbike could easily go through the cars. However, this is prohibited by law in Texas. South Padre island was also packed and bursting at the seams. Flow was complicated by multiple golf cars offered everywhere on rental, because of the price of gas? The view from the South Padre Island causeway was breathtaking; Somewhere on the 69E or 77, there is an immigration check point. I should have known there was one because of the proximity of the border, I would have been better prepared. All cars and commercial vehicles were checked. I thought it would be a formality, but when you are not a US citizen, it gets complicated, especially if you do not carry anything but your state issued driver's license. The only question you are being asked is about your citizenship. If you are a denizen, you need to have a proof that you are not an illegal migrant. Problem was, I did not expect that you had to carry proof of legal residency within the US. I was planning to carry my documents for the Big Bend trip. The last part of the ride from Victoria to Houston I did in the night. Although I try to avoid riding after dark, it was pleasant to be in human temperatures. The Le Mans liked that too. The traffic jams under the scorching sun, not so much. The V11 was constantly eructing its displeasure to move at snail pace during stop and go motion. I definitively need to change the lamp to something with more lumen in the head light. The yellow spot in front of the bike does not really help. It is not a problem on highways, plenty of traffic around you to show you the way. The way back I had to alternate postures which works fine when you use the tank as a crutch for your bum. However, what cannot really change is your legs' position. Having them recoiled all the time is difficult to sustain. Reminder of the map of that trip: The times and mileage of the trip; not included are the numerous incidental stops for gas and undesirable events: The Gas refuels record. The last one is missing, since I have not yet replenished the tank: The temperature early in the morning is a clue of what it will be later after the sun cooks us down! First refuel in Victoria at "The Texan" a copy cat of Buc-ee's. They still have a long way to go, but the principle remains the same. Some sort of gas stop supermarket for the people in motion. The first Motorcycle Grand Tour of Texas stop of the day; isn't it funny that this was also the day I was stung by a bee? Temperature before I took to home: The last stop. Observe the youth playing basket ball in the shadow of the Water Tower. Even then, the temperature is brutal! Back at the Texan, I am gratified by a beautiful sunset, which is kind of the cherry on top of this outing! the colors are beautiful and the heat haze makes it looking like a halo...- 111 replies
- 4
- 2022
(and 3 more)
Tagged with:
Talk to you later.... This is the day for my 800 miles ride!- 111 replies
- 2
- 2022
(and 3 more)
Tagged with:
Can you provide me with a link for the H4 led version? the parking light with a 12volts 5 watts wedge connection could also be replaced. Is this an acceptable solution? AUXITO H4: https://www.amazon.com/dp/B07TQLK6SH?th=1&psc=1&geniuslink=true AOLED H4: https://www.amazon.com/dp/B07Z4QKB33?th=1&geniuslink=true this one is for motorcycles, only one in the package. I don't really like the "blue halo".
Petrucci and Moto America
p6x replied to GuzziMoto's topic in Special place for banter and conversation
Danilo Petrucci lives in Pennsylvania. He still commutes to Italy, but he has a base in the USA. Fun interview to watch. -
I have replaced all the incandescent lamps with led ones; the flasher too, since the stock one does not work with led lights; remains the head light. I forgot to report the lenses on the turn indicators were completely brittle. Probably the UV from the sun. The plastic tab where the screw goes broke when attempting to remove. The plastic tab on the opposite side too. More money for MG Cycle... I have depleted their stock. I followed the instructions found in the owner's manual. The lower part of the fairing is held by four 5mm chc screws. The screws are held by four 5 mm nuts that your counter torque with a 8mm wrench. I removed the screw "A", which is cruciform, but the sheath does not come off. I believe there is probably another screw somewhere else underneath the top of the fairing. As I want to ride tomorrow, I have put back everything together. Can anyone with a front fairing confirm what needs to be removed to access the lamps in the head lights?
Yes. A friend of mine had one, in the early 80's. Really fun car to drive...
Did you try the GTV?
If I can, I will get myself a Citroën Méhari. This is the perfect car for Texas. 2 cylinders air cooled, 602 cc. Comes under the 25 years import law.
All the "old" cars that I used to drive back in Europe never gave me any concern. Probably because there was so little sophistication built into them. So crude, that if anything would go wrong, you could fix it yourself. Having a car requiring an ECU re-programming because of a failed battery was a discovery for me.
