Guzzijens
    2
Guzzijens last won the day on June 18 2023
Guzzijens had the most liked content!
  • Location
    Norway
    Moto Guzzi Rosso Mandello
Guzzijens's Achievements
Guzzisti
Guzzisti (2/5)
83
  1. 2 years I think, I was lucky and bought the stickers from Rolf Halvorsen Jens Martin
  2. I have mine painted at Elgeseter Billakk in Trondheim, maybe they have stored tha code. Jens Martin
  3. Yes, you need the xdf file as well, the one at the top v2.32 I think
  4. That the pump stops doesnt always mean it build pressure, it is controlled by the ecu and goes a specific time when the ignition is switch on
  5. My other italian ride...๐Ÿ˜€
  6. I owned a Multistrada earlier, I have a ducati leather jacket as well๐Ÿ˜€
  7. It is mounted with a quick mount, and this Givibag have a movable mount, I can check the type if you want
  8. I have a bad experience with ca cyclework TPS, maybe due to moisture, as it is not a proper sealing around the TPS. The bike was not rideable, and become good when a old original TPS was installed. As a solution to this I put some water resistance grease around the TPS, have worked well since
  9. Guzzijens
    Guzzijens
  10. It was a attemt to reduce the clutch noise (not a great success) and to improve the behavior of the clutch action when downshifting. This is much better, the "tripod?" clutchplate flex maybe a little compared to the original.
  11. I inspect the flywheel/clutch assembly of my Rosso Mandello last winter, no sign of cracks at all. Maybe the Rosso Mandello isnt affected with this issue? And how many of the Scura`s is affected? I also installed the new type of clutch plate, much smooter engaging, but some issues with the clutch dragging, now sorted out Jens
  12. Hello. I have just upload a bin for my Rosso Mandello, see the file section. I have the original air filter box though... Jens Martin
  13. Thank you for your answer, good to hear that I'm not the only one with this issue. No, I have not many miles (or km here in Norway ๐Ÿ˜€) on the new clutch plate, so I assume it will getting better. Jens Martin
