dowieze
Everything posted by dowieze
Bad news. The selector spring on my bike broke again after 3000 km. For the third time in three years. In the garage they replaced 5 springs in 20 years, includes 2 times on my bike. They do not find the cause. Currently they trying to modificate the gear box by reducing the travel way of the selector spring. I hope it will work this time. Any suggestions are we welkom. Best regards Marc
Thanks for the advice. I have the bridgestone battlax BT 023 on my bike. Pressure front tyre 2,3 en rear 2,5. It seems to quite good.
What is the required pressure for the front en rear tyre for a V11 le mans? Front 120/70 en rear 180/55. I get different advice. Thanks
Le mans has been repaired. Thanks everybody for the feedback and advice. Special thanks to docc for the technical support and for Scudd for sending me a new selector spring. I'm back on the road again and the gearbox works fine, for a guzzi. I hope for a long time now. Best regards. Marc, Belgium, Ypres
Thanks for the advice. I have a check up.
I think I do not have to lenghten the shift lever arm. It seems already assembled on the highest position.
I'm looking for a decent shift selector spring. They are hard to find in Belgium. I've read that you have a re-engineered spring. Is it possible to buy such a spring? I can not find any information about the sending cost for a secure envelope to Belgium - Europe. Maybe you have some experience in sending to Europe. Thanks
The shift selector spring has been replaced a few months ago. I have had since then problems to shift down. Problem has not been solved. Now for the second down gearbox problems. Maybe I can used such a new spring. First I let inspect the gearbox. Thanks for the info.
Today my gearbox stucks in second gear. I can not change the gears anymore. What can be the cause?
I bought a second hand bike. I thought he had an accident. What a relieve.
I noticed that there is a difference between the left and ride exhaust height of my guzzi of 2 cm . The same difference was mesured between the left and right height of the rear footrests. I can not find the cause. Nothing is damaged. Please check out on your bike en let me known what is possibly the cause. I noticed it when I have assembled the stucchi luggage rack. Thanks in advance for the feedback.
Phil thanks for the advice. I do a check up.
Billy I have the same problem with my 02 Lemans. The selector spring has been broken en have been replaced by a new one. Since then I have problems to shift down. Have you already found and solved the problem? I have already replaced the oil bij 75W140. It is a little better to shift down when the motor is warm but the problem still exist. Thanks and best regards. Marc
The spring of my V11 has been broken. A new one has been placed. Since then I have problems to shift down in gear. Specialy 4,3 en 2de gear. The selector pedal comes back to neutral very slow. Shifting up is not a problem. Is it possible that a wrong spring has been placed? What could cause the problem?
I have the same stucchi rack. The rack is perfect but once mounted on the bike the rack is crooked at on side. I don't find the problem or the cause. Do you have some tips to solve the problem? Thanks Marc
charging current light does not light up / starting issues
dowieze replied to dowieze's topic in Technical Topics
The V11 is from 2002. The starter is realy slow. After a few attemps it starts with a dot of trottle. It just seem he will not start at all. -
