Everything posted by Speedfrog
Are you talking about the rubber boot covering the HT wire terminal at the coil? https://www.mgcycle.com/index.php?main_page=product_info&cPath=37_209&products_id=315
Picker had the PC686 Micro ISO relay rated at 40A continuous..! Unfortunatly it's not in production anymore. Makes me think they know how to build a high current micro relay though..
@mikev Looks like you scored on the chinadian Omrons Otoh I'm not sure how the chinese made CIT A1 relays ever got the nod.. Afaik their continuous current rating has never been published.. Only Omron, Panasonic and Picker disclose that value in their datasheets. And althought Panasonic downrates their CM1 relays switching capacity(resistive) of 35A/20A-NO/NC to 20/10-NO/NC max. continuous current, Omron high current G8HN & G8HE report equal values for resistive and continuous at 35/20-NO/NC and Picker PC782 reported max. continuous current value of 35A is given indistinctive of NO/NC. Interestingly, Picker Components is a wholly owned subsidiary of CIT Relays & Switch.. Another relay option I found interesting is the japanese made Omron G8HN high current(G8HN-1C4T-RH) used by Suzuki. @docc Very compelling information on the different relays and their various functions. It would surely come in handy while chasing electrical gremlins that can affect the V11s. It would be worth assembling into a compelling spreadsheet or pdf..
Van Gogh Immersion
Speedfrog replied to LowRyter's topic in Special place for banter and conversation
That sounds like a fantastic immersive experience, well beyond your typical museum exhibit. After living for a couple of years in Paris, Monsieur Vincent had his most prolific period in Arles, a short ride from where I grew up. In a little over a year he spent there, he produced over 200 paintings and 100+ drawings depicting local life and the countryside of this area in the south of France. Beautiful country with a warm and bright southern light compelled him to work frantically and can be experienced throughout his outdoor paintings there. I should say that it’s also where he lost his mind... This beautiful countryside is littered with meandering 2 lanes roads from sea to rolling hills, linking small villages through marshes and vineyards and is best experienced on two wheels for all of its sensory palette.. That is where most of my early experience riding motorcycles took place. @LowRyterThat should tie this topic back up nicely to a more moto-centric subject... -
Have you inquired about pricing? Price range from $30 to $100 on that Alibaba link you provided, probably depending on amount of units ordered. MDI sells them for 70 bucks a pop right now out of SoCal with a phone # and email you can reach them at. Unless it’s significantly cheaper, I would think twice about ordering from overseas...
Got a little package in the mail today... Beauties!! A million thanks to @Chuck and his S&H crew for all their hard work and @Lucky Phil for all his ingenuity..
Without any intention of hijacking this thread and turning it into a relay one, I will just say that I spent a lot of time researching suitable relays alternative for the v11 and I would be wary of any relays offering on ebay coming out of China... The ebay vendor I got the Omrons from back in December is still offering them, albeit at twice the price I paid for them.. I think they've learned the value of what they're sitting on.. https://www.ebay.com/itm/162517009426 Aside from the CIT's @docc posted above, here are a few more alternatives I found: (Disclaimer: Even though I haven't tried these, all specs suggest they would be a good alternative for the V11) https://www.digikey.com/en/products/detail/picker-components/PC782-1C-12S-R-X/12352866 https://www.digikey.com/en/products/detail/panasonic-electric-works/CM1-12V/647128
Just my personal observation after miss Curiosity pushed me to check that listing.. I know, I know, curiosity killed the cat
I highly doubt the relays on that listing are the real thing, made in US Omrons that is. Omron label is obscured in picture and no mention of it in description either. In fact it states "unbranded" in "Item specifics"..
Definitely not a frame mount front fairing. Photo #8 in the CT listing clearly shows the fork mounted headlight brackets..
Beautiful bike! Welcome to the hive Sam!
Magnificent!!!
On the older model, the computer cable with USB-A plug was attached permanently to the interface and you needed an adapter to connect to a tablet or a phone. Nowadays a lot of laptop have USB-C ports as well, so I guess they upgraded the interface with a USB-B port to plug in the proper USB cable directly, eliminating the need for any adapter. Note that Lonelec sells the different USB cables separetely for a couple of bucks each so you could essentially make your interface ready for all type of USB connections. I'm not sure that you can run GuzziDiag on an iPad, my understanding is that there only is an Android version for mobile devices. I could be wrong though... it's happened before... Edit: No Android version of GuzziDiag exists at this time. If you want to run it on a tablet it has to be a Windows tablet.
Here is the direct link to the “Guzzi” cables. https://www.lonelec.com/product/guzzidiag-3pin-interface-cable-kit/ All you have to do is choose an option for the cable to plug to your computer/tablet/phone. The original cables came with USB-A plug attached for standard PC connection. I’d go for that, you can always use an adapter if you want to plug into a tablet/phone.
To do a TPS adjustment, you need to loosen the 2 screws that fasten it to the throttle body and rotate it until you read your desired output - 157mV. It's pretty sensitive, we are talking micro adjustment here. Only loosen the screws enough to allow rotation while maintaining some tension. Your output might jump around when you tighten the screws back so you might need to rinse and repeat until locked in. And definetely read and follow docc procedure in Decent Tune-up: https://www.v11lemans.com/forums/index.php?/topic/19610-decent-tune-up/
Tag bracket broken; weld? replace? substitue solution?
Speedfrog replied to p6x's topic in Technical Topics
One could fairly easily fabricate their own fender eliminator /license plate holder /tail tidy or whatever you wanna call it... Here is an interesting idea/drawing that could be implemented as is or used for inspiration. Fender Eliminator Bracket.pdf -
Yes, fun memories with that car… Then I finally had to scrap it when the fuel tank developed leaks due to rust… Enjoy your GTV!
That was my dream car as a young driver… I had a ‘74 Alphasud, the poor man Alpha Romeo. Great fun to drive but I it literally just rusted away.
Premium prices even considering the shipping is included. But then it comes from the motherland...
If you already have the powder then by all mean, use that.
That is great, thank you Chuck! Take your time, finish your flying machine, no hurry on my side, don’t just go take off into the sunset... On the finish side of things, would it be possible to have a satin black instead of flat? That’s how I’m having all my little parts that sit in the background refinished.
OK, let's close that deal, I'll take two to make it ten. I personally would prefer mines in black, powder coated if possible. IIRC Chuck made a run of powder coated ones, otherwise I'll take them raw as I have a bunch of parts to send to the PC. @Chuck? And thanks to everyone who raised their hands for this!
