LaGrasta
Everything posted by LaGrasta
  1. https://www.aliexpress.us/item/2251832622654235.html?spm=a2g0o.order_list.order_list_main.39.21ef1802KSAcWS&gatewayAdapt=glo2usa&_randl_shipto=US i'm using these on both my V7 and V11
  2. I use Lithium batteries in 5 of my 7 bikes. The Shorai in my V7 lasted something like 7-8 years! Their small size allows them to fit anywhere, and doesn't matter what end is up! Regardless of brand, these batteries all ship with self monitoring overcharge circuitry, very safe. I've never had a problem. I'm adding to this thread now to let you know about my most recent purchase, NOCO. Even prior to opening the box of this 1.5 lbs battery I was so impressed. The packaging is incredible, over the top. Being in marketing, I understand what goes into boxes, manual, etc. I literally saved everything, not sure why, but it was too nice to dump. The battery itself, being used for my Dual Sport spins it right up. I'll be considering this brand again next time I'm in need.
  3. Forgive for not only adding to a 16 page thread, but also for bringing up AliExpress again. Numerous headlight choices can be had for little to no money. https://www.aliexpress.com/w/wholesale-7-inch-motorcycle-headlight.html?catId=0&initiative_id=SB_20230202092858&SearchText=7+inch+motorcycle+headlight&spm=a2g0o.home.1000002.0
  4. Nice to hear your updates and adjustments. I now have my fork in the riser at 15mm, much better turning. That may sound extreme, but I tested and tested, and it felt best. Come to find out, Todd over at GuzziTech advises this exact amount. I was merely basing my adjustments to the V7 steering, which is great. Next is setting my sag, as I have the tank back off, allowing access to the shock adjustment. If you're curious of proper sag settings, search for my sag thread.
  5. To better restore mine, I soaked it in automotive interior leather spray, came out super nice.
  6. These are the LEDs I used for this modification. https://www.amazon.com/dp/B07HK9HFJH?psc=1&ref=ppx_yo2ov_dt_b_product_details (this style would have worked just as well) https://www.amazon.com/dp/B01AUI4VR4/ref=sspa_dk_detail_1?pd_rd_i=B01AUI4W5U&pd_rd_w=QI9Xw&content-id=amzn1.sym.dd2c6db7-6626-466d-bf04-9570e69a7df0&pf_rd_p=dd2c6db7-6626-466d-bf04-9570e69a7df0&pf_rd_r=CP5GM8DPK77KKQ92KT8B&pd_rd_wg=maNJI&pd_rd_r=2d713b18-4e80-4abd-bea6-89d24ffcd42c&s=hi&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM&smid=A14FP9XIRL6C1F&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExTDBBRlRPVTlPVkZTJmVuY3J5cHRlZElkPUEwMzUxNDY5TDNPMEkzMThIQUVGJmVuY3J5cHRlZEFkSWQ9QTA1MDE3NTgxSEZSTEVDWEZDTk0zJndpZGdldE5hbWU9c3BfZGV0YWlsX3RoZW1hdGljJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1 Instead of using the new LED supplied sockets however, I elected to use the OEM rubber ones. It was easy to pull out the old clips, cut and solder in the new LED bulbs. They seat perfect within the rubber socket. They provide plenty light as well. Note LEDs are directional, thus the above color key includes positive and negative designations.
  7. this is accurate for my 2003 "carryover" V11 Sport, with a single turn signal light.Thank you @docc As for dash light wiring, this is now confirmed to be correct: Instrument bulb harness color key HIGH BEAM: brown +, black - OIL: red black +, blue black - NEUTRAL: white +, violet - FUEL: red black +, yellow white - BATTERY: red black +, light blue - TURN: green black +, pink – [docc edit to clarify 2003 "carryover" V11]
  8. Can anyone confirm please? If not, I'll start poking each wire to see what lights, lol I should explain further. I removed each light socket, marked each before doing so. Then afterward realized the pen I used wiped off the masking tape while working with the harness. I then proceeded to remove the now unless tape and inadvertently also slid off the tiny zip ties that contained two wires, per socket. I now have all of these wires, unclear what one is positive, what one is negative, and what two belong together. The above is what I have concluded thus far. I'll figure it out, then post to the thread if no one else has ever recorded these facts.
  9. Instrument bulb harness color key HIGH BEAM: brown +, black - OIL: red black +, blue black - NEUTRAL: white +, violet - FUEL: red black +, yellow white - BATTERY: red black +, light blue - TURN: green black +, pink –
  10. …dealing with this now, as I'm replacing my panel lights with LEDs, the OEM sockets were touch and go. After cutting them all off, I THEN noticed the schematic is not reflective of my bike. After a quick forum search, I find this @docc schematic, and accurate too! Thank you! Kudos also to Carl Allison, nicely built schematic as well, allowing me to zoom in. The factory manual schematic, in comparison is poorly labeled, confusing, and not in english. I would have been lost. Thank you again Carl and docc!
  11. sorry about the image links, this site limits us. I don't host images on another site, so I have to Photoshop them to 200k.
  12. from my notes: MPH Cycles Starter Interruptus mod Parts at http://www.cycleterminal.com/ (except the 14 AWG blue, green and white wires). The MPH Cycles part comes with a 10amp fuse in the fuse link. The heat shrink tubing and the black protective tubing could be replaced by ordinary electrical tape. You need a crimping tool for the brass terminals, but a garden variety tool from the hardware store will do fine. The connectors from Cycle Terminal come with male and female spade terminals. The "eye" terminal on the fuse link has to be purchased separately.
  13. Newly acquired vehicles always have me and a can of slippery-squirt spray all hinges, keyholes, buttons, etc. Give it a try.
  14. Another calming, impressive MG channel was, 46 Works, https://www.youtube.com/@shiroh73/featured This guy is talented with his build skills, but also his video editing, I found them to be very calming. Enjoy!
  15. I hurt my back yesterday, building a tire change jig. As I laid on the couch all day I watched lot's of good stuff. One of my favorite movies, Sing Street (Netflix), and endless Youtube videos. This particular one was so calming, I really enjoyed traveling along with him as he rode his '67 so so very far across Canada. Enjoy!
  16. @JoeWow, your bike is beautiful, THAT color! The exhaust looks fantastic, makes our stockers looks so HEAVY, in comparison. Congrats! I ran the Mistrals on my V7 for years with DBkillers. Eventually, curiosity got to me and I removed them. They haven't been reinstalled now for over a decade! @MartyNZ great looking Wilbers MonoShock! I have Wilbers on my V7, so fantastically accurate, and infinitely adjustable. I'm too cheap to upgrade my V11 with one, but you got me thinking!
  17. @80CX100 I really appreciate your perspective. I will make my order later this week, waiting for a few vendors to respond to my request. I did already order the upgraded MGC OEM cable. I believe they are out of stock, but they still took my order money so maybe it's just a matter of them having a request before they fill it. I hope to hear back from them this week.
  18. after far too much research, this vendor seems to have the best choices of cables, and pricing too. https://www.officine08.com/web/elenco_prodotti.php?idfiltro1=4&idfiltro2=4037&idfiltro3=5169&pag=3
  19. @gstallons yes, only the inner needs replacement.
  20. does this fit our bikes, expecting no difference from their listed years to my 2003? https://www.officine08.com/p14778_speedometer-cable-moto-guzzi-v-11-01.html In my research, I've created such a confusion for myself. For $80, TLM seems to have a modded cable that eliminates both drives and the plastic gear at the speedo. they do have stock afterall. The link above show a new cable really cheap. The thing is, I've been hesitant to purchase since none of these seem to ensure fitment. I did also put a deposit on the modded MGC cable, however this seems to be nothing more than a slightly bent versions of OEM. I haven't heard from them since my deposit though.
  21. my exhaust of choice. I'm actually running one on my dual sport, KLX250. https://shop.gprexhaustsystems.com/?gclid=Cj0KCQiAtbqdBhDvARIsAGYnXBNAy8tO73BXZ2isZlvmn4bDHF1U2KNPh4SLfnsnG63p0us_UqdhB3YaAg9CEALw_wcB
  22. …it seems no one has any cables, MGC or TLM.
  23. Encyclopedia of Compatible Parts
      • 1
      • Thanks
  24. LED instrument lights, $20 Amazon https://www.amazon.com/gp/product/B07HK9HFJH/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 I installed these on my 2003, work fantastic, fit so nice too. They are brighter than OEM, but not overly bright.
  25. @cash1000 this company is closed for the Christmas holiday, but once they are back in office, confirm USA delivery, I'm going to go for this option. Appreciate your confirming. I did also order and pay for a stock style from MGCycle, but as noted, they have none at present.
