I guess it's normal to join a forum when searching for a solution to a problem - I will try to contribute where I'm able to as well!
My 2001 V11 started to misfire, never when cold and always on the over-run / low throttle. Just the occasional miss but consistent in these situations. It's not repetitive enough to work out if it's specific to one cylinder or both. It ticks over fine and runs well on anything above low throttle.
I have so far, replaced plugs and leads, tried with the power commander out of circuit. Plug colour looks good after running and in all other respects the bike runs fine.
Also worth mentioning that it started after / soon after I put the bike back together after replacing the clutch. Can't actually recall if it was immediately afterwards.
Any advice and suggestions gratefully received.
Cheers, Mike.
