alannn
Everything posted by alannn
  1. My favorite too. The beautiful Miura is proportioned so well, you can't appreciate how low and ground hugging it is until you are standing next to it, towering over it. Although they weren't crazy expensive when new, they sure are now. Well above my budget, so I enjoy driving my Toyota MR2 Spyder instead.
  2. Out of respect for science, I prefer to consider the character ( ) of my V11 as artificial intelligence rather than soul.
  3. I run heavy gauge lamp cord to my speakers. Compared to fancy speaker wire, it sounds the same, and it keeps my wallet heavy gauge too.
  4. You guys have quick answers. Scura's and Tenni's single plate clutch is a potential problem, so I'm fine without it on my best bang for the buck, unlimited '02 Lemans. I'm sure my Lemans revs up slower in neutral without it. I can live with that. Titanium nitride coated forks sound nice. Perhaps longer lasting? I wonder if any other Moto Guzzi's have titanium nitride coated forks. The coating I've heard of on Jap bikes for low stiction is teflon. That doesn't sound as durable, does it? I'm happy with my '02's wrinkle paint. So perfect, that I'm sure the engine cases were replaced under warranty. A tiny touch up on my gearbox case was easy enough.
  5. 2024 is the year I bought my first V11, the Champagne Lemans. So I'm still learning. This thread seems like the obvious place to ask: Does my '02 have the same lightweight single-plate clutch and titanium nitride coated forks as the Tenni?
  6. I may be wrong, but my head is wrapped around the idea that the V11 Tenni is a rare color, not a rare bike.
  7. I wish I could have gotten that signal instead of being stuck out on Long Island at my parent's.
  8. 102.7 was WNEW. Alison Steele perfected the sultry, whispering dj technique there.
  9. Alison Steele, WNEW, 10 pm - 2 am. That was the reason I slept with my Koss headphones on. My alternate dj was Alex Bennett on WPLJ. I suppose NY FM radio was a big influence on my teenage musical tastes during the 70's decade.
  10. Standard lengths of 16ft and 25ft can be combined using optional DIY® Couplers for longer lengths
  11. I still have fond memories of the sound and smell and fun of my Yamaha Daytona Special (RD400 style 2 stroke). I sold it because of overwhelming feelings of inadequacy when an associate showed up on his Suzuki RG500 "Gamma." Sadly my excitement over the Gamma exceeded that of my Daytona, and I never even rode it. What a sound!
  12. My understanding is the 105/G08E fits my 2002 LeMans. I am not clear about fork sizes. Is someone here able to post a chart with year and model vs fork size?
  13. Glad to hear you got a good one too. Pete, have you ever ridden a Honda DCT? To me it seems like a winner over the Mana CVT, but I've never riden either one. Honda makes a 750 parallel twin with DCT.
  14. Every combination of height and color says: "Diese Kombination ist derzeit nicht am Lager. Die bestellte Menge wird schnellstmöglich von uns geliefert." Google translate German to English says, not in stock. What does ist derzeit nicht am Lager mean to you?
  15. This is another nice option by Das Mototec that is also no longer available. Their website says out of stock. Did I help here? Edit: I emailed the company and now can happily report they are available for purchase. My comment of no longer available was my mistake. Thank you for alerting me, @audiomick .
  16. That sounds like a bargain price.
  17. The OEM Ohlins shock used by Guzzi does not approach the performance of the shock offered separately from Ohlins. I would inquire with an Ohlins rebuilder if the OEM Ohlins shock could be upgraded to that level, and if so compare prices to new shocks. A new Wilbers or Penske shock performs better than the Guzzi OEM Ohlins version. I am currently saving for a custom Wilbers shock for my new to me Lemans.
  18. Thank you for posting that link to that thread that pre-empted my metal core gasket question. So 2 p/n B063861, and 1 p/n GU01003600. Easy-peasy.
  19. I understand 3 new gaskets are required for installation. If they are not included, does anyone have the part numbers of these gaskets handy to post here?
  20. I think the best way to think of preload is it places the (loaded) bike on average at the center of the springs range of travel, so that the spring experiences minimal occurrences of full extension and full compression. Personally, I like having my shock spring rate where my normal load requires zero (or close to zero) preload, and I just dial in more preload for extra luggage and/or passenger. On the other hand, from experience, I have noticed fork springs are usually designed with a minimum preload built in, even with the preload adjuster set to minimum. Possibly due to the fact that forks don't use the rising rate frame geometry typically seen for rear shocks. During use, damping also affects spring travel. When a bump is encountered and the suspension starts moving (accelerating), damping is what diminishes the inertia of that motion, for after the bump impact is absorbed.
  21. Wilbers web site spells it out clearly: 641-0519-00 for the KR, short frame. 641-0519-01 for the KT, long frame. That inspires more confidence than the listing in the Hyperpro catalog. Edit: Then for the hell of it, I check the OEM parts listing which shows GU02550201 for both the short frame and long frame models. So to answer my own question, it looks like all non Ohlins V11's have the same OEM shock, GU02550201. So now I suspect Wilbers took the initiative to specify a longer shock for all long frame models to match the Ohlins spec. I will try to contact Wilbers to verify my wild guess.
  22. Looking at Hyperpro catalog, they show the same emulsion shock, type 460, model MG11-0AA, for many different V11 models, from 1998-2005. But for their type 461 ("hose reservoir"), model MG11-1AA, they show fitment for V11 SPORT, 1998 and up, only. https://hyperpro.com/wp-content/uploads/2016/02/HYPERPRO-Shockabsorbers.pdf Do short frame and long frame V11's require different rear shocks? In a nutshell, I want their type 461 on a 2002 Lemans. What additional hardware is needed to fit an external reservoir in the same location as the Ohlin equipped V11's beside the left porkchop? Final question, what is the extra shock length required for raising rear to match the Ohlin equipped bike spec?
