Steve Swan
    2
Everything posted by Steve Swan
  1. Too funny! Went out to my shop last evening and shortly after, noticed the "missing" clamp lying in a corner below my work bench I use for clean work. Bingo!
  2. Thanks for your reply, fuel flow, tank to pump to filter to throttle bodies. Apparently 2 logical for me to make sense of! Have everything reconnected, ready 2 go except for a short 2prong female electrical connector on the right side above throttle body. Don’t see a male counter part and only thing on tank is is on left side. When ive another moment, I'll see what o.m. and p.m. can teach me.
  3. Ok. On to the the next topic. A couple questions... Atttached are pics of: 1. The fuel filter, the arrow points to "out," which means gas flow out from the tank to the butt of the arrow? And the front of the filter, the arrow tip, where does that flow to? 2. The fuel pump, that hose connection between the Positive and Negative terminals, where does it go to? 3. The two brackets on top of the spine, what attaches to them? And, now for a free chuckle... when we drop something, or it flies away, if we're lucky we'll here it hit whateve it lands on that gives us a hint of what part of the black hole it ran off to hide in, so hopefully we can find that something sooner than later. I cease to be amazed at how far away things move from their point of impact... In thins particulat case, i cannot find that second yellow zinc clamp holding the fuel pump to the frame... I searched for 2 hours to no avail, the only place i have not looked for that clamp is in my refridgerator. All i can think is that i got busy with something, possibly had that clamp in my hand and absentmindedly laid it down to complete what may have required 2 hands... I finally quit looking for it tonight, and will go back out to the shop another time with a clear mind and a fresh set of eyes and find it. As always, thanks for sharing your always helpful experience.
  4. Thanks @docc and @audiomick for your replies. To clarify, i will set the RH pin at its original 7 threads exposed and then turn the LH pin in for contact, then turn it out between 1/16 to 1/8 turn. I'll forgo the string and once the beast is back on the road, do a few hands off test drives.
  5. Upate to revitalizing this LeMans. I have the rear end back together. i was able to remove the retainers for the 2-row swing arm bearing, wash them out with brake cleaner, and then blow them clean with 120 psi, grease the balls bottom and top, reinstall retainers, reinstall seals. i am now at the place where the wheel alignment needs to be adjusted and set. Your shared expertise to set the alignment will be appreciated. Prior to dismantle, threads of RH pin protruded 7 tread; right 6 threads. Threading in the pins, turning RH pin in to expose 7 threads, the LH pin threaed in to 4 thrreads exposed, not the 6 treads exposed. Attached are pics of tihis stage completed.
  6. Today i gave the poor old sow a bed bath... first step to making at the least as faux silk purse... apology for siedeways pic, took the damn thing in vertical with camera phone, and rotated 90 degrees x's 4 to get it upright, ain't happenin'
  7. All a person has to do is take the whole apart and those zertks are really easy to get to.
  8. This pic must be a gag! I practiced as a nurse for 45 years, started out in in a busy K.C. trauma E.R. How are you infusing what i assume is grease via clear plastic tubing into the U-joint? Not!?
  9. @docc what is KlĂĽber Staburags? I was thinking if i could get away with cutting off the degraded piece of hose and reconnecting... Where can i source a new one?
  10. Can't get enough hammers and screwdrivers!
  11. Noticed these 2 things... Does the splined area look soupy to you? I didn't sniff for Hypoid smell. If this signals a leak, where's it coming from? And a degraded breather hose.
  12. Ok, a few shots of the carcass. i've removed as much as i think is necessary to begin the deep cleaning which i'll start this weekend. Docc's to do list when the rear end's off is printed and on the work bench. Thank goodness i guess that i've got February through April to get things back together. I'm looking forward to the new Road 6's and the Mistral satin round muffs were shipped today from MGC. Not sure how i'm going to freshen up the cosmetic damage from being the neglect of put away salty wet, something to think about and i welcome your suggestions. At least when i'm done, i'm not going to have a show bike that i have to keep in spit and polish condition.
  13. Ok, more pics. I think i've dismantled, loosened or freed up about as much as i think needs 2b done to deep clean, inspect and service what's needed. Looking out my shop window past the pile 'o LeMans parts, it's snowing, 8ÂşF here in Laporte, Colorado, but i'm warm in my cozy little shop. Bring it on!
  14. I have the lens, need the stalk. Thanks in advance.
  15. @gstallons by wheel bearing grease, to you mean that thick heavy dark brownish grease? I've been using Belray Waterproof in the white/blue plastic tub, but have started using Lucas Red "N" Tacky a few yeasrs ago...
  16. @gstallons @Scud @docc @audiomick i have the swing arm removed. I'll inspect hte lower shock mount and report back. Will start cleaning away the greasy, salty grime. The swing arm double row bearings are almost dry, no water damage, don't turn easy but are smooth. My bearing puller slide hammer isn't heavy enough to pull the bearings. Wonder if heat gun might help... Removed the outer cage, will thoroughly wash them out, see how they turn and if free and if smooth, thinking i will repack with new grease. I'll stay with the factory shock, i'm tired of dumping money into more bikes than i care to remember over the past six decades, so a full thorough inspection and service is all this poor old crusty hag gets from me. I've saved her from an untimely death, so she'll love me well for what i do give her. Thanks for the comprehensive lists of things to inspect and service, and the tip on the clutch bleeder. I'll post before and after pics of the cleaning. My spirits dampened having to dive deep into this bike, i never thought it, but i've gone to the dark side and become a car guy for the first time in my 73 years. Last September, bought a '94 Corvette in exquisitely clean condition which has thoroughly excited my passions...
  17. @scud thanks for the tips.
  18. @Scud Thanks for the tips, yes there were exh.pipe gaskets! i shall see what the Encyclopedia has and if i find parts not listed in it, certainly i shall post them.
  19. @audiomick Thanks for sharing the resource, no love on the 30 53 05 25 boot, lower master cyl rubber. 10.4 on paying for quality.
  20. @gstallons mea culpa "ff" = fuel filter (: wrapped in tinfoil, probably an attempt to deflect heat, are the '02 LeMans prone to vapor lock with an external fuel pump?
  21. Thanks, yes the gaskets were there! and Absolutely, will post any new parts i find in the Encyclopedia.
  22. Hello to All who are so genrously sharing your wealth of knowledge and experience. Saturday i got the front end back on and got the carcass blocked up to remove the swing arm. This morning (Sunday) when i put eyes on the LeMans, to my dismay, there was a tiny puddle of oil under the RH fork. So, pulled the fork and massive chunk of the seal's lip was torn, careful as i was, it happened. So, i should have seals, fuel filter by week's end. Once i have the front end back on, then i will block up again and move into the swing arm removal. Thanks for mentioning those pins for setting up wheel alignment. One thing i don't have is a laser, is that something i can buy anywhere and then attach it to a magnetic base i use for holding a dial indicator? Another picture, this one portrays how this bike has been treated by whoever worked on it before my ownership. It's obvious somebody had their hamfists throughout the bike, a NAPA ff wrapped in tin foil. No gaskets between exh.pipes and heads. Are rubber parts generally available or are they nla? There are a couple boots elsewhere on the bike that are cracked, torn, degraded. To be sure, i will be cleaninging all the electrical connectors, with a little emery paper on eyelets and DeoxIT D5S-6 for the connectors.
  23. Gentlemen, thank you. The old Coats 220 gave me a bit of a workout removing the rear tire. I'll get the front tire m&b then back on forks so i can get the weight off center stand and then i can proceed further dismantling on the rear end of this old gal.
  24. Thank you gentlemen for your replies. Yes, will continue this deep dive and THANK YOU for informing me what to look for. i have the rear driveshaft separated from the diff. Do i remove the side plate to remove the front half of driveshaft? Otherwise, i shall remove the swing arm and of course the front half of shaft will come out. for the moment, a couple questions. 1. Looking in the parts book at driveshaft, i don't see the thin O-ring listed. Is there a pn for this? Purchase where? We have a Guzzi dealer in town. 2. This morning when i was surveying the carnage, i noted this 12x21x27 spacer on the lift. I don't remember for the life of me removing it from anywhere... (i AM a sharp 73 year old). Where does this spacer fit? Pic attached.
