Tennitragic
Everything posted by Tennitragic
  1. Many thanks for all these replies…I will go through them properly with my (new!) multimeter in hand over the coming weekend and respond accordingly… Of note, and as a (part) answer to GuzziMoto is that brake and tail lights are working perfectly (now). Had to replace the micro switch at the brake lever….one of the 3 pins was loose on the original micro switch causing an intermittent brake light.
  2. This latest niggle has me perplexed…my Tenni’s original headlight was a bit rusty and reflector scratched. Pilot light and high beam fine but low beam was not lighting. Replaced bulb - no low beam. New headlight arrived - no low beam. Checking left handlebar switch block as possible culprit, the horn button, indicators, passing switch all working. Flicking the light switch, position 1 pilot light fine, position 2 high beam only. Could the problem be the red high/low beam button? And here I thought was the fun part…with no key inserted/ignition off, low beam works when the light switch is moved to position 2, but nothing else is ‘live’! Any ideas or hints? Thanks.
  3. Thanks for the quick response Peter…I will contact you via Private Message.
  4. A new RAM low inertia clutch has arrived….looks correct for the Tenni when I refer to many other owner posts. But thanks to Lucky Phil, docc,gstallons and others who have been down this road. Now to fit….prefer experienced Guzzi mechanic and not spanner this one myself. Any suggestions ‘down under’?
  5. Cheers docc! Thanks to all who have been there before….MG Cycle appears to have what is needed…and not Stein Dinse from previous commentary.
  6. Again thanks Lucky Phil.
  7. Many thanks Lucky Phil for this advice!….Aussie dollar has ‘collapsed’ compared to the U.S.$ lately so why SD prices don’t look too bad! Just to confirm for this V11 series novice, SD #200001620 and MG Cycle #1096620 RAM parts are the same kit? Better images with bike back together will eventually follow….regards, Tennitragic.
  8. Hello fellow enthusiasts….closing in on 70 years so more a collector than a rider these days!…and moved to Guzzi from Laverda’s! Purchased a Tenni recently (photos to follow) Albeit bit of a Tech Luddite, will have to learn forum linking/sending photo’s etc. Currently recommissioning the bike for the roads ‘down under’. Continuing this thread as the Tenni’s previous owner said the flywheel/clutch are originals. Lurking and reading here made me aware of common faults including flywheel. And some owners adapting/fitting the RAM 5 speed clutch assembly because the crucial clutch hub is oem in Tenni/RM/Scura….all thanks to you guys…! Stein Dinse helped to date with Guzzi parts but are now dissuading me from purchasing “Moto Guzzi Single disc clutch RAM - big models No. 200001620”. Checked with MG Cycle about Part Number MG1096620 but they said they are “unaware this 5 speed will work with a 6 speed”. Should I go back to them or am I missing something? Thanks for any help here as I realise this is a very tired old topic!
