Everything posted by stormsedge
I may be able to make the Saturday ride this year. Where would the start point/time be located? k
My TDC sensor is leaking oil. It looks like it is seeping out where the rubber block adheres to the metal mounting tab. I'm considering cleaning it up with electical contact cleaner, then placing a small bead of super glue or silicone to get me down the road a little longer...however, knowing that it will only be a short term bandaid vice a repair, I will have to replace when I get the down time. The repair manual describes setting/checking the air gap inside the timing cover...easy enough, but takes some time and sanitary conditions. Has anyone changed their TDC out using without setting the gap, that is, using the original shims? What happened? Heading out for a couple of weeks, so your post will languish until I get back. Appreciate response. k
High 31F today...doing an oil change, then a bit of a ride to charge battery anyway. Brisk...it only made it to 29!!! Time to go on the battery tender. k
Ordered Odyssey PC545 for my 03 LeMans - any install tips?
stormsedge replied to rktman1's topic in Technical Topics
I placed a couple of stick-on furniture pads on my frame rails forward of the battery to set the seat pan upon, yielding better clearance. k -
Hmmm, pair of threes. I fold k
The early Guzzi's input splines were smaller and tended to weardown with the dual disc arrangement over time (been awhile since I've had one apart, but I believe the "center floater" causes the wear)...the later Guzzis like ours have a larger spline that is supposed to put most of that concern to rest. My old SP (at about 60K miles) had a worn input spline which caused occasional clutchomania, but it was not a showstopper. In fact, despite the latent recommendations I will probably receive, I even replaced my clutch discs once on the worn input spline due to that particular fix being cost prohibitive at the time. The guy who bought it from me never messed with it either to my knowledge although he did install sportier bars and a cafe racer fairing. Not going to get into the idle discussion...but I may bump mine up a little . Keep smiling. k
Do you disconnect your battery from the bike's electrical system before putting it on the tender/charger? I have been due to some posts a couple of years ago about there not being any not being any protection for the ECU...but, now I wonder if that is true? I just put an Odyssey in a couple of weeks ago after five years of use from my previous mailorder AGM (which I left on a tender many times including +6 months sitting out of the bike while I was overseas). k
Andy, I'm really not sure what a VDST is? And is there a CO sniffer involved in this? Will any CO sniffer do and if so, which pipe...my right cylinder has gotten so bad I can't ride it. k
Okay, invested in a second compression tester (since my other is 600 miles away)...compression is good so no burned valve. Coil wires are good. Put in an Odyssey PC545 battery since I killed the other (I got 5 years from it, so it was time). Reset the TPS again (and it was way rich). Bike is still popping back through the right intake and blacking the plug. I think its the fuel injector on the right cylinder. I'm going to put fresh plugs in it tomorrow and give it one more go on the TPS, but if that doesn't do it, I'm going to replace that injector. k
Thanks Docc. k
Okay, I've read most of the nine pages posted here. I know my damper leaks, and I'm certain I have it dialed almost to or at minimum...that due to speed wobble when I first bought the bike used 6 years ago...so, I'm game to try another---is there a good replacement out there? Not a gold plated one, but the one that will do the job reliably for a reasonable period of time (like years)? k
Whoa nellie! I'll check the coil wires tomorrow.
Yup, plugs are good...intake rubbers are good. I'll get a compression tester and do the compression next weekend. I'm out of time the week. I'm also going to get into the fuel system, change the filter, swap injectors and maybe get them checked somewhere. I'm running out of places to look, but it will probably be something simple when I find it. k
Okay...mine is ribbed, not open. TPS is reset, checked thrice. Valves checked. Ignition pickup removed and cleaned. Intake rubbers are good. Motor is still backfiring 3-5K rpms...right cylinder only....with or without the PCIII. This has been progressively getting worse, starting with some occasional popping at 3-3500...now effects alot of the rpm range and makes the bike unridable. Won't idle. Thoughts? k
Redline Heavy Shockproof,front and rear boxes?
stormsedge replied to mznyc's topic in Technical Topics
Yup, red heavy in both...and it really helped the shifting as well. k -
If mine is unsealed/slotted, I'll take a picture of it. But, I'm not going to get to it for another week...hope it is slotted so I can clean it up. Probably a very good bet that it being mucked up is a part of my problem, since its been outside under a cover for over a year (in the salt air). Good advice from all. Time to get a new digital meter so I can do it right. Keep smiling. k
I've been putting it off, but the ole girl is surging and stuttering with the occasional backfire at 4-5000rpms...time to reset the TPI. Two questions here--1) want to get a fluke meter that will read the very low millivolts for this operation...used my old meter last time and best guessed the needle position, but far from optimum. Pls recommend make/model of meter and where you purchased (USA). 2) Is it worth my effort to procure and install the Harley TPI piece during this tune up? If so, pls pass the US part number. Thank you. 2001 Rosso Mandello w/open air box, and PCIIIusb. k--Tampa
I remember having an issue with an LED kit as well, but it was so long ago I don't remember what I did to fix it. Since you know you have juice going to it, I'd start by making sure the ground point you've chosen is actually a ground vice isolated somehow. Something else you might try is taking the lighting wires directly to the battery +/- to make sure you do not have a bad group of LEDs. Keep smiling. k
#244 here.
I like my MPH risers as well. Pretty straight forward install. Lines are included with the kit. k
Is there a part number I can ask for? Thanks. k
This interests me...did you recal/reset your TPS after installing the new switch?
They were giving demo rides at the Harley dealer yesterday...I didn't bother. k
Johno, I find that my RM gets squirrelly at anything less than 34F/37R...I typically run a higher pressure, about +3 or +4. I weigh in at about 200 pounds. Cheers. k
