O2 V11
Everything posted by O2 V11
@Molly, Reading the regulations in place you can import one vehicle, without that vehicle having to comply with the relevant ABS regulations. It would be a relatively painless process. The other piece of the puzzle is that the importer of the vehicle under this piece of legislation is either a returning NZ resident or a NZ citizen. You have not said whether the move here is permanent or temporary, this will determine the eligibility for the above. Have a look at this link if you already haven't: https://www.nzta.govt.nz/vehicles/importing-a-vehicle/2-complying-with-vehicle-standards-and-providing-evidence/immigrants-vehicles/ Rob
alannn, In answer to both your questions, the answer is no to both of them. I believe the single plate clutches were fitted to the Tenni and Scura models and only the Tenni came with the coated forks. You should have a twin plate clutch and conventionally finished forks. Rob
BramF, Have a look at these ones https://www.omniaracing.net/en/brembo-serie-oro-front-floating-brake-disc-for-moto-guzzi-v11-mans-20012005-p-164545.html Rob
O2 V11 replied to chamberlin's topic in 24/7 V11
It looks like a parts bin special alright. I am inclined to go with it being a 2002 year early Le Mans, it has the first generation switchgear as fitted to the original Sports. The clipons being under the top yoke and the hollow front axle only muddy the waters. At that price it would be the perfect candidate for cannibilisation. Rob -
@BallabioJoj, I have a MBTX12U fitted and it works very well for me. Rob
@LowRyter in a word, No. They are different sizes. Rob
@gstallons you are correct, but I have always called it from day one of ownership a 2002. When the bike arrived in 2004 the "new" 2003 model was available. The 2003 model as we know sports many changes, amongst these are satin cases, an exhaust crossover, lengthened tank, ITI gauges with different paint schemes . My bike although it was made in early 2003 is not representative of what I call a 2003 model. To avoid any confusion around which iteration mine was I decided to a call it a 2002 model. Rob
I see a post by @motortouring showing a Burgundy side cover on his bike which he said was manufactured in 2001 which would make this would be one of the earliest carryover models. The switchgear changed somewhere in at a guess late 2001 or early 2002. I have seen a Champagne Le Mans with the same switchgear as the original Sports and Rosso Mandellos but later ones had the newer switchgear. The question that needs answering is has anyone seen what is accepted as the carryover 2002 model available in Grey, Burgundy and Lemon/Lime with the earlier switchgear? If there is such a beast this would mean this configuration was manufactured from late 2001 until early 2003. Rob
Carryover 2002 Sport Naked manufactured March 2003, as above ZGUKRAKR53M114957. Rob
40 mm is the fork tube diameter for this iteration. Rob
Very nice, those should work very well, quick question, are you having to change your brake lines to suit? Don't forget to give us a rundown on how they perform, are you upgrading the master cylinder as well? Rob
p6x, check your breather pipe from the top of the block to the frame, this is notorious for degrading and leaking oil. I had to replace mine after 17 years. Rob
It has been a while since I have had my cover off but from memory there is only one position that the 4 dowels can be in for the cover to fit correctly. I got it wrong once and cracked my cover by tightening it up with the dowels incorrectly aligned. If you still have your cover on the bike have a close look at your gear linkages on the up shift. Make sure nothing is binding preventing the up shift, the starter is really close to the linkages. Hopefully you only have one of the connecting fittings reversed and it is catching on the starter, preventing an up shift past neutral. Rob
Here are my tank connections, as docc said both of the under tank nipples are drains/vents. I have joined the two hoses that connect to these with a garden irrigator 'Y" into a single hose which is routed towards the ground at the left rear of the motor. This was done as my bike was a California spec one which had the tank overflow hose originally plumbed separately to a canister which was removed. My fuel lines are original so hopefully yours will look the same as mine.
It could be either your tank vent or drain. There are two outlets on the bottom of the tank. One is a drain for any liquids that my be present around the filler ring and the other is a vent for any pressure that may build up inside the filler cap. If your bike originally was a CA spec one, the vent line would have been plumbed into the filter canister. This is generally removed and both lines a joined with a small joiner to the drain line and are discharged down at the rear of the sump. This is where the drain line is routed. For this I used a small garden irrigation "Y". I am unsure how the vent system is structured on non CA spec bikes. Rob
I have had mine for about 3 years now. Tinnitus in one ear and the other one is just getting old. When there is a TV for example in the next room and I listen to it with my bad ear only it might as well be in a foreign language as I cannot distinguish anything. I put this down to loud motorcycles and work related noise exposure over the years. Before getting them any socialising was hard. With a lot of background noise I found it near impossible to clearly understand and follow the flow of the conversations. My wife eventually made me go and get mine. I went to an Audiologist who owned the business himself. I ended up with an inexpensive pair, about $2300, Oticon is the brand. After my hearing test the hearing aids were tuned for frequency responses which best matched what I can't hear. I have annual hearing tests and the process is repeated. Overall I am very happy with them, the batteries last about 2 weeks, they are turned off at night. There are other disposables you will need like earbuds and filters. As an aside, at work there are other people who have hearing aids from franchised operations who are not happy with their devices. I can only assume that theirs are not tuned correctly for their needs. There is a multitude of options out there now in hearing aids, Bluetooth models you can adjust with your phone and use as speakers for your phone or music, rechargeable ones you plug into a dock to charge. Back to the original question I take them out when riding and have never worn earplugs which in hindsight may have helped slow the decline in my hearing. Mine fit behind the ear and unless you look really hard you cannot tell they are there. Putting a helmet off and on will dislodge them as I found out. I find the sound just a little bit tinnier then normal but that is understandable you can't get bass out of a speaker the size of a gnat, wind can be a problem sometimes but it is not the end of the world. Overall it was the right thing to do and have no regrets with my choice in provider and the appliances themselves. Rob
Didn't Carl Allison have an accident damaged TT many, many moons ago? He may have ended up dismantling it if my memory serves me correctly. Rob
Cash1000, you could try hand cleaner. I have the Supercheap SCA branded stuff. Used successfully on painted alloy wheels that were black with brake dust. took a while with a toothbrush but eventually removed all the crud. It has a bit of gritty material in it so shouldn't be used on bare metal but is OK on painted surfaces. Rob
Kane, when my front end was rebuilt it was fitted with both a 0.9 and a 1.0. I cannot say which spring went where. The springs were only part of the equation along with an Andreani valve kit in 26mm. Interestingly the oil that was used was 20 cSt as opposed to the usual 26 cSt recommended for Marzocchis The stock front end is atrocious with next to no compression damping. New springs would help a little but a deeper dive into the forks would give much better results. Race Tech would be a good place to start for either springs or a full front end rebuild. Rob
Hi BramF, not in the EU but in New Zealand. This is available here for 44 odd Euro. The same kit will be available near you, keep searching the net, you must find one. This listing does not show a Brembo part number. Rob https://www.trademe.co.nz/a/motors/motorbikes/parts-for-sale/brakes/listing/3234721013
dowieze, This is what I used instead of the mount you are trying to find. There is enough room to put a nut on the bolt inside the steering head itself. A smaller socket set with plenty of extensions and a long reach/deep socket will get the job done. Using a shorter bolt would have been much easier, I used the shortest of the 3 supplied. RAM Motorcycle Handlebar Clamp Base (RAM-B-367U) Rob
Wow, at only 2.6 kg that's quite a weight saving over the MBTX12U at 4.4 kg I just installed before Christmas. I have always had a lot of time for the Motobatt range of batteries. Just checked retail pricing at $339 as opposed to $160 for the conventional. For me it is a case of yeah, nah. Rob
That wear is definitely not normal, even though it seems we favour left handers that accelerated wear on the left side doesn't make sense at all. I was going to say it must be a dual compound tire, soft in the left and hard on the right but I wouldn't want anyone to take me seriously... Rob
