Bruce Reader
Everything posted by Bruce Reader
  1. Check all the front frame bolts Cheers Bruce
  2. Bruce Reader
    Bruce Reader
  3. A group buy for a kiwi roy re designed wiring loom ? I'm going to ride this bike for another 20 years. Cheers Bruce
  4. Yes the gears would be cool. Group buy ?
  5. Group buy ??? Cheers Bruce
  6. I'd take two if you make some more. Cheers Bruce
  7. If someone made a new and improved harness i would buy 2 of them. Cheers Bruce
  8. Check the head temp sensor is working/connected. mine recently came off and it went from 6.5 l per 100km to 10l per 100 km !!!! Cheers Bruce
  9. is 59.Chuck at Gmail dot com the paypal address ? Cheers Bruce
  10. i think it may be the personal message part that notifies me directly. Cheers for the parts Chuck Bruce
  11. i thought i might have received a pm regarding this. sorry haven't logged on for a while.
  12. i'll take 2 please cheers Bruce
  13. Any left ? I'll take 2 if available. Cheers Bruce
  14. First flywheel had cracks nearly identical to the picture posted by fotoguzzi.
  15. Australia- no 250 Can't be sure but i think 22000km for cracked flywheel then the replacement (not the one i ordered) at about another similar interval - exploded and took out gear box. 80000km since on 2 plate. Cheers Bruce
  16. Any chance we can gather all of his diagrams in the file share or how to sections ? Cheers Bruce
  17. does the bracket adjust the space from the wheel to the swingarm (lhs) ? Where is it on his site ? Cheers Bruce
  18. Ill take one. Cheers Bruce- Australia
  19. Still on the original battery after 14 years. Have had some issues though !
  20. Headlight relay switched with key for the Scura. Cheers Bruce
  21. From the Centauro Owners Group Forum Ok, here's one. You know the plastic fitting that screws on the rod that snaps on the ball on the right fuel injector? Wears out over time, and can actually fall off. (designed to fail) It isn't listed on the parts list. Hmmm. Mercedes throttle rod end, p/n 000 991 88 22 made of steel, slightly longer than the original Guzzi part. $5 US. Thanks to Todd of MPH for that one. Looks like it'll last forever. Cheers! Chuck in Indiana Cheers Bruce
  22. Sidestand helper ?
  23. All sorted thanks to Roy. Fuse 1 plug was snug inside the fuse holder underneath but 'beside the terminal !!! Cheers Bruce
  24. Check the 3 rubber mounting points of the speedo/tach assembly. While there check the ignition mounting bolts as well. Cheers Bruce
  25. i didnt. cheers Bruce
