jimbemotumbo
  • Location
    Rockies
    1200RT, Laverda SF2, Aprilia Tuono 'The Tuon Monster', Goose-to-be-named-later
821 profile views
jimbemotumbo's Achievements
Guzzisti
Guzzisti (2/5)
0
  1. jimbemotumbo
    jimbemotumbo
  2. Good advice above. The only other thing I can tell you is to be absolutely certain that all linkages are disconnected from the TB when you set the TPS. I'm sure you've already considered that. I always did a careful valve adjustment to Euro specs then the TPS, then the TBs. I also balanced at just off idle, say 1500 rpm, rather than 3k rpm, as I feel it results in a better tune. If I varied from that approach I would see a bit of 3k hiccup. YMMV
  3. I find I am cleaning the screen a lot more often in the last few days!
  4. +1 to Raz. Even if the relay change fixed you up, you need to spend some time cleaning the contacts and applying a bit of dielectric grease. Trust me, the problem WILL be back if the contacts are nasty. Ride Safe!
  5. Cheapest and easiest fix that works for many vapor lock sufferers is the reflective heat tape, or similar shielding stuff, followed closely by installing a manual petcock. Although, I did it other way round and the petcock did the trick.
  6. SNIP: I'll trade any one of my bikes for either! However the maintenance costs may surprise me. Cheers.
  7. I have a Tuono R, so must add a bit to this: The Tuono lack of comfort is highly overstated, as is it's "nervousness" as Antonio puts it. I am a very legroom and general ergo conscious rider. I sold a new FJR tourer due to ergos (after throwing a good bit of money into changing it). I sold my V11 sport due to ergos. My 50 + year old knees can't deal with a sport bike at all, and they prefer my BMW 1200RT or a GS for leg room and comfort. However, I bought the tuono for a little hoon action now and then. Full Akro system and fueling changes made. After setting up the suspension properly, it's a stable freight train on steriods. All nervousness was dialed completely out in about 10 minutes. The most pronounced improvement comes from dropping the forks in the tree and setting rebound. The power rush on this bike hits HARD, and after the suspension tweaks I can now enter decreasing radius curves, with significant pavement quality changes, under full power and with full confidence. There is no wandering, twitchiness, turn-in, etc. probably the best handling bike I have ever had. The OEM bars had a tad too much sweep, so Protaper Hi-ATV bars went on. I now find myself commuting daily on this, and have done several all-day rides. Although the pegs are indeed high, the position is surprisingly very nice. No knee strain or neck problems for me, and I am a hard sell. I do not plan to add vario pegs or the like .. there is absolutely no problem here, despite my grumpy old knees. Great commuter, canyon-carver, and sport tourer. Mad crazy power curve. Superb stability and handling. I honestly think you could fit this with a rear rack or soft bags and tour the shit out of it, or tape it up and race it. Of course for touring, the 140 mi range is a bit of a worry out here in Colorado and points west. Hope this helps.
  8. My 2000 Sport behaved the exact same way. As stated, it is a tuning issue. Adjust the valves to world spec, not US spec. Then set your TPS per instructions presented in the sticky so named. The key is to ensure ALL your linkages are disconnected from the TBs in order to get accurate adjustments. Finish off with a good balancing of the TBs, but not at idle. Balance them so they are most evenly matched at 1500 and 3000 rpm. - Jim
  9. I forgot to mention the price includes shipping CONUS.
  10. Gently used. Yellow cover (ed.?). No bruises, missing bits, splooge, etc. To loving home only. Price: 40 USD Prefer US shipping, but I can manage international.
  11. The Once and Future Guzzisti
  12. Listed on ADVrider at $7800 appox. Low miles. Not mine. I don't know the owner and have not seen the bike other than a pic. Looks to be in excellent to mint condition. I want this badly, but have no cash. I offered to swap my Laverda SF2 for it, but he's trying to thin the herd and not looking for more bikes. Somebody buy this awesome bike! If not, my offer stands .. if anyone here wants my Laverda, they can buy this Mk1 and we can work out a reasonable trade. - Jim
  13. Sam, You know I'll be there. Hoping to have time to tune the Laverda so she can hang out with her Guzzi cousins.
  14. I am on my third set of dual compound Roadsmarts, and they have become my tire of choice over the Pilot Road 2. Better mileage than the z6 or ME880, and far better peformance. These scrub in quicker than the PR2, are just as good in the rain and twisty bits, and last easily over 10k. Best rain tire I have ever used. The ONLY problems I have had with the PR2 is that they require several hundred miles of break in (not a huge deal .. just be aware), but more importantly, they suffer performance degradation in the latter half of their life. The Roadsmarts remain very consistent until the end of their life, and then they go very very quickly! Neither are particularly find of tar snakes (which are getting more prevalent on the roads I frequent). The Dunlops are easily $75 cheaper, each tire. Last two sets cost about $140 for the rear and $120 front, with free mount/balance. Used to do it myself, but as RH points out ... just not worth an afternoon of wrestling when the shop can do it in 10 minutes. Next set will be the newer pilot roads with triple compound. Curious to see if they can eliminate that raised center ridge that dual compounds tend to get. The ridge can sometimes create a rather abrupt transition from straight up to lean. YMMV
