richard100t
Everything posted by richard100t
The only thing I would add to the discussion is you might need to set your tps a little higher when you switch to the pods. They seem to lean out the mix a little and setting the tps a little higher did the trick with my bike. I had the K&N's and then I bought a pair of the aluminum ones from sportcycle pacific. You'll enjoy being able to work on your bike a lot more with that airbox out of the way too.
I remember seeing a thread here with a complete teardown and replacement of the clutch system. Someone here will remember where it is and hopefully post the link to it here for you.
I'm selling my v11 sport single plate clutch assembly. I'm asking $300 plus shipping. I have plenty of pictures so just pm me and I'll email them to you. You get the complete setup, flywheel, disc, etc
Changing the Scura Clutch.Options for replacments.
richard100t replied to mznyc's topic in Technical Topics
I've seen quite a few pictures of the Scura flywheels with cracks in them. If Guzzi only made 600 or so Scura's then the problem is much higher than 2% of them. The clutch disc is a wearable item and if I owned a Scura with that flywheel, the next time the disc needed replaced the flywheel would be replaced. The problem with that flywheel is if it does go and you're moving pretty fast when it does its going to be very bad. -
Keith did you use MG special tools during the operation or fabricate or buy generic ones? Yup I think it looks great,just want Micha and Pete Roper's opinions of twin vs single plate replacement. Pete? I have Pete's Scura, and he had the single plate changed out before he took delivery. He told me that while some people don't seem to have any trouble with them, he didn't want it to blow up when he was out in urine drinking country in the west.. H Ha Thanks Chuck I believe he said he changed it to a twin-plater in a thread could''t find it,hopefully I can get him to confirm/deny. I remember reading that thread too and I also remember him going to a twin plate setup. They are thought to be more reliable but other than the Scura flywheel problem I havent heard much other trouble with the single plate setup. The twin plate is more money too, which is another consideration. -
I have a complete clutch/flywheel brand new setup just sitting in the basement. I'll sell it for $300 if you're interested pm me and I'll send you pics. The flywheel is made of steel. -
Yeah theres no fixing it. I just have to find a used replacement part.
Richard....... Do this: go to an automotive parts store, ask to look at any two identical U-joins. Take them out of the boxes and stand them up about 2' from each other. You see that the caps are matching at 3-6-9-12 o'clock positions. Your driveshaft HAS to be assembled this way to be "in time". Now the yokes at the ends of the driveshaft HAVE to be in the same position as you would touch both your thumbs and middle fingers together.When you have all of these as thy should be, the driveshaft will be "in time". Do this as you are sitting at your computer to understand this concept. You will probably find something is not kosher with your driveline. I appreciate the advice, BUT I need a whole new driveshaft at the moment because the old one got mangled up with the bits of the broken u joint. Unfortunately there arent as many v11's out there as there are Hondas, so it will just take a little longer to get the used parts that I need. When I do get them I'll definitely keep all of you up to date.
I'd like to post the pictures but I think I'll need a moderator so that I dont have to crop them down too small. If one of the moderators will pm me I'll send all the pics of the damages for viewing here.
Hi Tracey, I have 40k on it now. I appreciate the offer of help, but I kinda need the replacement shaft before the bike will go again. Send me your phone number in a pm, I cleared out my phone and I should have written down my contact numbers first!
I was out for a nice relaxing ride last night when I started to hear this weird ratting sound. I was only doing about 50mph and not hot rodding at all so I thought this is odd, did I run over something? Then it got real bad real fast. I pulled over to the side of the road to find that my front u joint had broken, taking the cover with it and pretty much trashing the front shaft yoke in the process. If anyone has, or knows where I can get a new shaft please PM me. I'll post pictures of it later, its hot and I'm still pissed about it. I greased that *^&^%*%* joint every damn year.
How is the twin plater working out for you and where did you buy it? Thanks. TJ I'm turning 40k miles on my Rosso Mandello and I have my fingers crossed! I dont ride it very hard though.
Intake Mods: No "Lid" versus Pods
richard100t replied to al_roethlisberger's topic in Technical Topics
I had the K&N filters on mine for years and they were just fine. Then I recently aquired a pair of billet velocity stacks on ebay with the foam type filters. They also work just fine. The nice thing about them for me is you lose 5 pounds or so and you have much more and easier access to service the bike. Wether it makes the bike any faster is almost irrelevant to me. Oh did I mention they make the bike LOOK faster and way cooler! -
I bought a replacement flywheel and clutch kit on ebay a few years ago just in case. Its still sitting in a box somewhere in the house I'll never need it...unless I sell it.
Since you checked the valves the other two major causes of the popping and misfiring are the tb balance and tps. I'd try balancing the tb's and giving the tps a good look. All the other things mentioned could be causing the problem, BUT the tb balance and tps is a very easy job to do and free so I would go there first. The tb's only have to be off just a little to cause that problem.
Ducati Diavel
richard100t replied to antonio carroccio's topic in Special place for banter and conversation
I have seen the Diavel and sat on it and it looks much better when its in front of you. I can tell you that I didnt really care for it that much...until I sat on it. Then you really get it, its very comfortable even with a stock seat and the grips and switches are all where you would like them to be and they have this feel about them. Its hard to describe but I did like it. Then you imagine the 160 hp and it weighs about the same as your v11 -
The only problem that I recall is a forum member didnt line the marks up right once and it caused problems. I cant recall any u joint failures that werent related to bad alignment. I havent heard of a single one that has just worn out yet.
You're saying this is a picture of a replacement flywheel? I've never heard of a replacement breaking up in the middle like that. Makes me think theres something else wrong thats causing this sort of damage. You arent letting BFG's mechanic work on it are you?
You want to get the Ballabio version with the higher bars. If you can find an 04 model those are pretty sweet. That newer sport12 model is a Breva with some very slight body panel changes. Still its a really nice bike, more modern and digital dash. Look at both bikes in real life, not pictures on the net and pic the one that moves you.
Changing out the pinion gear in the v11 is damn near impossible to do. You probably need special tools and some of the plastic bits just get trashed when you try to remove them. Thats a big downside to shaft drive, and the added weight. But its cleaner and allegedly less maintenance.
Scary bike crash on the news
richard100t replied to tmcafe's topic in Special place for banter and conversation
Well theres the thing about being right and being "dead" right. When you're on a motorcycle its always on you to do everything you can to not get hit. People do stupid crap, drive distracted and generally dont pay attention to their surroundings. Its always your responsibility to spot these types of drivers and then avoid them at all cost. You all know that when you pass someone thats not driving right that you have to put space between you and them. If they hit you it may be their fault, but you're the one going to the hospital....or worse. -
Damn Tracey! I better get on the road! Mine only has 39,000 on it. You probably put that many on the beemer in the same time period though
They stole the wrong bike
richard100t replied to belfastguzzi's topic in Special place for banter and conversation
pictures would be handy and a Google map, just for interest Sorry BFG I'm afraid your new Griso is probably MUCH harder to steal than your Scura! -
Its really satisfying to see that they couldnt get the bike to start. I can just imagine how mad he or they were about that! Hell my vll is so simple to start without the key that its not even funny. I forget now what I did at some point one of the bolts holding the ignition came out, anyway once you get in there all you have to do is unscrew something and its as easy as turning it by hand without the key. Same deal with the rear seat lock, just unbolt the locking mechanism and you're in. -
If anyone actually does a front end conversion using modern spottbike forks and wheel please post the bearing numbers and a few pictures. I've been interested in putting a gsxr, cbr, ninja type setup on mine for awhile, but I didnt wanna be the first guy to try it
