Dan M
    2
Everything posted by Dan M
  1. Dan M
    Guzzi utility
    The ultimate touring Guzzi? http://www.guzzioverland.co.uk/
  2. If the power line has circuitry to reduce voltage that is likely your draw. I have an older Garmin Streetpilot that is hooked up directly and there is just B+/- right to the unit. No draw when switched off or disconnected. 3mA is pretty small. Would take quite a long time to run down a good battery.
  3. Feedback fuel control is only at relatively steady throttle and at lower throttle openings. When the throttle is moving or opened wide it reverts to a base map and O2 input is ignored. The earlier bike like Guzzimeister's 2002 does not use a O2 sensor so he can adjust via PCIII at any throttle opening or RPM.
  4. +1 Looks good and there is a lot of truth to the "leave well enough alone" adage.
  5. Dan M
    Saying Hi
    Welcome Pete. The Thruxton is a nice bike but doesn't have the character of the V11. You made the right choice. Enjoy.
  6. Hey, Al's back! Yep, 5 days over 5 years; isn't that something like 5 sidereal years exactly? I forget... Well, you know what they say: time flies like an arrow, fruit flies like a banana! [Actually drosophila prefer thin-skinned fruit, but whatever... ] Or as I say: "Time flies when you're having fun... and even when you're not!" Yep, just goes to show, still relevant I guess for relative newbs like me to Di..d..MGland! I've been reading all these "old" Lid/Pod post's - & gotta say too that that Ratch dude is just classic - he got (gives?) so much pleasure outta pulling the odd goatee here & there, did'nt he? Has he died or just been spam banned? Invite him back I say, sure need some spark to light great fires to stand around & warm our great collective arses! Anyhow, getting back to the inlet side of things I appreciate Phil A's improvement photos being reposted by Tom M, 'cos I'm fairly certain this, in conjuction with keeping a paper filter, is prob the most convincing proposition for me in the near future as I'm about to start on the whole PC-V or PC111 conund.. roadtrip thang! Or any new thoughts now that things have moved on with 5 years more experience/observations? Ratchet has been banned. He could not keep himself from calling people on stuff and often times things got way out of hand. There were other antagonists who fueled the fire but escaped the executioner. Most of them have since stopped posting for one reason or another. It is true, the pace has slowed here since.
  7. where did you get that strap???? I want it! I like my leather one now but it won't last a lot longer I wear the watch every weekend and whenever I go out. I wanted number 3 but ended up with 33 as I was too late for the low or high numbers. ere: http://www.thewatchprince.com/Carbon-Watch-Straps
  8. That is a nice looking watch. Sleek & modern. You can ship your Junkers here: http://www.watchrepairsusa.com/junkers/watch-repair
  9. Watch, not bike. I don't know how many of the original 99 or so lucky members who picked up Jen's custom Moto Guzzi watches are still on the board but mine is still being worn proudly. The strap was showing age from wearing it to work nearly every day so I found one worthy of the watch.
  10. That's a good looking bike.
  11. Dan M
    Good deal?
    I think the price on these has leveled out. A good example will command $5000. There are only so many to go around so don't wait too long. I like the ad - "ultra-smooth 6 speed transmission,.........BREMBO 3 SPOKE ULTRA LIGHT WHEELS"
  12. Pod filters will make it lean if you are looking for stock tune and stock exhaust. It will get worse with open mufflers or aftermarket crossover unless you take the PC3 or other route for adding fuel. I feel pod filters are too noisy but some people don't mind it. Before you order them, disconnect the inlet tubes to the throttle bodies and go for a quick ride down the street and back with open throttle bodies. You'll get a feel for the noise level. I'm not a big fan of K&N. The stock paper filter will flow more air than you can use and do a better job of filtering. Amen on the K&N. You must be a mechanic? Yes sir.
  13. Pod filters will make it lean if you are looking for stock tune and stock exhaust. It will get worse with open mufflers or aftermarket crossover unless you take the PC3 or other route for adding fuel. I feel pod filters are too noisy but some people don't mind it. Before you order them, disconnect the inlet tubes to the throttle bodies and go for a quick ride down the street and back with open throttle bodies. You'll get a feel for the noise level. I'm not a big fan of K&N. The stock paper filter will flow more air than you can use and do a better job of filtering.
  14. Stradas have been my favorite tire on the LeMans. Great grip both wet and dry. I just mounted a set of Angels on the Tuono today. Should be able to take the first ride with them tomorrow.
  15. Dan M
    8V Norge
    Motorcycle.com reviewed the new 8V Norge. Lots of praise. http://www.motorcycle.com/manufacturer/2011-moto-guzzi-norge-1200-gt8v-review-90851.html
  16. It's a pressure switch Doc. I didn't completely remove it to get a look at the whole part because I didn't want to bother with bleeding the rear brake again, but it might be the same as this one that's used on a number of older Guzzis: MG Cycle gets $40 plus shipping for this one. MPH never responded to my request for a price so I ordered one from a dealer near my workplace. I've never done business with them but they seem to have a good reputation among the New England Guzzi guys. http://www.seacoastsport.com/ I have not seen a pressure switch like that for automotive brake lights. From about '95 to '02 Fords used something similar on their master cylinders for cruise control interrupt but I don't know if it is normally open or normally closed. Early ones were problematic and recalled.
  17. That is a good idea if you don't have a drill guide. Although in this case, since you have an existing hole that you are just enlarging the bit is going to follow it straight so long as you don't force it. Tape your bit so you don't go too deep.
  18. Yea, those are great roads. We rode around the lake last August. Routes 31, 22 & 109-(tunnel of trees) were memorable roads. I hope to get up there later in the season.
  19. Looks like there needs to be a "take a bow" emoticon for foto.
  20. Well, well, well, look what the cat dragged in. I ride up MI's left coast occasionally. Maybe we can hook up for a ride this summer. You'll find tons of good info here. Welcome (we don't say @#!#$# off around here like those other guys)
  21. The case of the ECU is grounded so it is unlikely you did any damage. Shorting the positive post directly to ground will not hurt fuses or relays because there is no fuse between the B+ post and the battery. (you would have to short a circuit after a fuse to blow it) Is it possible one of the wires did not get reconnected to the battery post when you hooked things back up? One eyelet may have dropped down when you pulled the bolt out.
  22. If I recall Metzeler owns Pirelli MC so maybe they moved production? The Angels are the replacement for the Diablo Strada. I loved the Diablo Stradas. The next set which are on the bike now are the more sporty Diablos. Both very good, Diablos may be better in the dry and Stradas better in the wet but neither ever let me down. I just bought a pair of Angels for my Aprilia. Have not mounted them yet.
  23. Yes, Gene's method will pin it down for you. The fact that oil didn't help does point to valves. Yes, guides have reportedly been the issue with this engine. Talk to your local mechanic for advice on a good machine shop in your area. Valves & guides are pretty basic stuff. You don't need a Guzzi specialist.
  24. I've had the motobits for a number of years and like them. They move your feet down and forward about the same distance the MPH riser moves your hands up and back so the result is rotating your body slightly more upright. Very comfortable position for me. 5'11", 31" inseam.
  25. +1. Never an issue here either. My LeMans has a plug in the front tire right now. I prefer the rope style plugs. I have never seen a plug come out. We have plugged literally thousands of car tires in my shop over the years. It is a reliable repair.
