biesel
    17
Everything posted by biesel
  1. Does someone have experience with painting the tail part of a Rosso Corsa with clear coat? Is it possible to varnish the stickers or will they be harmed?
  2. Available at the German Guzzi specialist Däs: Bolts for the frame bearings made of stainless steel and nuts made of high-strength aluminium. Paul Minnaert pointet out that Guzzi made two variants (22x1 mm & 20x1 mm threads). So if someone is really interested he has to be aware of that.
  3. He guys thanks a lot! The windscreen was an initiative by me, a V11 LM rider from Hamburg and my Guzzi dealer. Where do you get your screen from? Directly from MRA, Germany (the manufacturer) or my dealer (Claus Carstens)?
  4. Hi Al, at the moment just for the brake.
  5. He is also offering this wonderful V11 part Ebay
  6. At the moment he has only one piece in stock, which can found on Ebay. Motoschmitz
  7. Or work in a "Man´s Kitchen" like the other Al:
  8. Thread "Anyone out there that can explain how the stock crossover works? I found one on E-bay for $13.00 so I thought I'd modify it for use on my 02 Lemans. When I cut it open you see a thin layer of steel wool type material, then a screen, then you come to the two post, another screen on the bottom with the packing behind it. I expected to see some type of baffle in there but there is none! It appears it's straight flow through except for the two post. The screens and packing are on the top & bottom and I don't see how the exhaust would be forced to flow through this area. I thought I read that this would give the bike a little more sound (but I don't see how removing the screen. packing, or post could have much effect now that I can see the insides of this thing). How's this thing work??? Could the screen and packing on the top & bottom of collector just be there to keep the heat down? Any thought on this are appreciated...I've attached a picture of the inside of the crossover. Thanks, Steve Thoerner" -------------------------------------------------------------------------------------------------- "I went ahead and gutted the inside of the box and welded a new stainless plate back in on the top and bottom of the collector. To see what kind of sound difference I'd get I made some measurements with a sound meter. All measurements were with the bikes at 1500RPM standing about 5 feet behind the bike or 5 feet to the side of the motor. Stock Guzzi V11 Lemans: 97dB from the rear 92dB from the side with modified crossover 99dB at the rear 96dB from the side both measured before the bike warmed up. After a ride with the modified crossover hot I measured 95dB from the rear and 92 from the side...these bikes must quiet down as the motor gets hotter. To give a refrence point I measured my BMW R1150RT: 89dB from the rear and 89dB on the side (way quiet). My brothers H-D Road King loud aftermarket pipes but some baffling 111dB from the rear 107dB from the side at 1500RPM's. When he cranked to 2000RPM's it hit about 120dB. I advised him to get some earplugs!!! Really no difference in the performance so all in all I'm not sure this modification is worth the effort...I'll probably put my stock crossover back on. I wanted to get a little more sound from the bike but not give myself headaches on long rides. This modification isn't noticable without the sound measuring instrument. If anyone has some spare Lemans pipes they want to let me have for a reasonable price I'll do the mods and post the measurements on them. Glad I only invested a few bucks on the used crossover.... Steve Thoerner"
  9. biesel
    crash bars
    Can be found here: Agostini (Italy)
  10. Image 4
  11. Image 3
  12. Image 2
  13. Windshield manufactured (tailormade) by MRA Germany. Distributed by Claus Carstens, Germany Price: "82,-- € incl. 16% Mwst and TÜV Gutachten"
  14. Available at the German Guzzi specialist Roland Däs: http://www.daes-mototec.de (=> look here: " Produkte", "Lenker/Lenkerstummel")
  15. Ippogrifo is written with a single "F"
  16. Ippogrifo Flyer
  17. Ippgrifo Flyer:
  18. Ippogrifo engine? Wonderful prototype Ippogrifo:
  19. biesel
    vapor lock
    Could this help cooling the fuel pump? Sport Cycle Pacific
  20. Found on ANIMA GUZZISTA (Forum)
  21. Kreeb GmbH & Co
  22. more details
