Janusz
Everything posted by Janusz
  1. I have better speedo then you guys. ha ha! Mine shows up to 240 but I have never seen it over 220 no matter how I'd try. But some time ago. more than 15 years ago, I've seen 298 (yes,yes, kilometers and in MPH it would be 185) on the empty road going from Waterton Lakes Ata back to BC, on my 2004 Yamaha R1. I've never went so fast before or after even on the track.
  2. Thanks for all comments. I had very neat gear indicator on my 2004 R1 (Acumen brand?) and it was very useful. I gave this bike to my son so I do not ride it anymore. Yes, V11 speedo is cable driven so this type of indicator is useless. On my cruiser bike there is 5 speed and no tach but this rolling armchair is so easy and relaxing/boring that no sporting and engaging riding is feasible. So, I will have to continue to remember speed to RPM relations in top 4 gears to be able to guess the gear with accuracy. Pity.
  3. And still you do not know what gear you are in...
  4. Hi guys; I would like to install a gear indicator on my V11S. Anybody has one? Advice?
  5. Hi Guys; So I am looking at Shop Manual and the first sentence in the "Transmission Shaft" towards the end, section "O" says: "Replace the shaft with transmission joints every 20,000 Km; if the motorbike is mainly used for racing type driving or usually high speed driving, replace every 15,000 Km." WHAT??? Is anybody doing this? Did anybody replace the shaft if its not damaged or broken? My bike is low mileage (47,xxx Km) and just changing tires last week I inspected and greased the shaft which turns smooth and looks like new. According to MG people I should be on my FOURTH shaft (I ride less last 12 years but still "usually high speed driving") Anybody cares to comment? Happy Easter everybody!
  6. Thank you for this detailed and straightforward information, Marty. It is highly appreciated. And docc, you can be always counted on. Thanks. This crowbar surgery seems quite radical; should I expect the spline disc to be rust frozen and difficult to separate? I will be anxious not to damage it...
  7. So I've removed wheels to have new tires installed at the shop. Should I disassemble the rear wheel and remove cush drive rubbers for tire installation and balancing or take the whole wheel to the shop? I would like to inspect/grease etc cush drive rubbers but it seems difficult to me and the factory shop manual is not very helpful. It wants me to: "Working on the opposite side remove the bearing and then lift the plate with gearing (do they mean spline drive??) using two screwdrivers." Could somebody walk me through this using simple explanation please?
  8. Janusz
    Janusz
  9. I've got Vespa 150 and like it a lot. Great running short errands around. I live in the rural setting on the coast, no need to gearing up, no helmet, no insurance...Feels like I am 16 again when I had my very first motorized vehicle also called "wasp" but in Polish ( Polish "Osa" = Italian "Vespa" = English "wasp") Good times...
  10. The first one (starter?) is Bosh - slightly bigger then other ones which are original factory relays black in color. The Bosh is grey. Some years ago I took off alternator cover off to repaint it. Is it possible I've pinched some wire? It is possible this charging light did not work since then, I practically did not run the bike for 11 years. By year 2011 I had 45,700 km on it, now is 46,800 km. I bought it new in 2002. I have it insured now and enjoy almost like a new bike. Janusz
  11. Yes, the oil light works. After I stop the engine and turn on the ignition only right away the light does not come on, but after couple of minutes it comes on with ignition and extinguishes when engine is started. It is a residue oil pressure I suppose. No, the only thing is "no charging light" never comes on.
  12. My 2001 V11s battery charge warning light does not work. I changed the bulb twice and no help. Alternator is charging, battery OK. Any suggestions how to diagnose/repair? I would really appreciate any suggestions. Janusz
  13. My rear drive on V11S is leaking oil and I want to take it off and send to the shop for resealing. Tried to search but no success. i need some advice how to do it please. First, I take the wheel off (I have a proper stand); is is an easy and straigtforward operaton? anything I should know? Then I disconnect the torque arm- looks easy. But how and where I separate the rear end from the driveshaft? Are the two allen bolts which seem to hold the driveshaft to the rear box shaft the ones to remove and it will just separate? I do not want to start the job and the become stuck on something I do not know how to do it. Please help. Thanks.
  14. I respectfully disagree. If the pinging is caused by too lean mixture (which is the case with a stock setting to begin with and then, after some modifications to intake/exhaust it becomes really excessive) then richening is NOT the short term solution BUT the only proper one and no carbon build-up is expected. Once again: first make sure the mixture is close to proper one and then worry about valves, TPS, idle, balance etc. Unless Im missing something. If that is the case please tell me what.
  15. There is a different method of defining pump octane # in North America then in Europe. You should remember that. Canadian (and US) octane 87 is an equivalent of European 91/92. V11 Guzzi owner's manual specifies unleaded 95 octane RM ; as I said this is a Research Method octane # which is same as ours 91 R+M octane at most. The manual also specifies Benzina Super 97 RM which, as I seem to remember from my Italian travels, is a leaded gasoline. Anyways, my experience was that any engine pinging was caused by too lean fueling, especially extremely lean after opening an airbox and/or freer muffler. In my case adding fuel at pinging throttle/RPM points of Power Commander completely cured any pinging I ever had. Using too high octane gas is a bandaid solution bad for engine and bad for your pocket.
  16. There is hardly a combustion problem which cannot be solved with a little adjustment of your powercommander (you do have a Powercommander, dont you).
  17. My engine is overdue for an oil change now. I am planning to take the oil pan off this time when changing oil and clean/repaint it. In 3 days I am going away overseas for a month. Here is my dillema: Shoud I: 1- leave the bike like it is for a month in the carpot and do all the work after I came back, or, 2- let out all the oil now, let it drip till November and do all my painting and fill the new oil then. So basically I wonder if leaving an engine empty of oil for a month will be unhealthy for the engine more then leaving it filled with 16 month old oil. Doing all the painting/oil refill now is not possible (too busy getting ready for the trip/too lazy).
  18. You forgot to add: "for a short time".
  19. Full four pages of elaboration about how to prevent the fast idle lever from returning on its own while starting the engine. And yet nobody mention one, even more important benefit of springs swap; it allows to have a poor man cruise control when under way and makes riding no hands on longer empty road stretches possible.
  20. When I had to leave my V11S at the dealer for some time he loaned me his V11S which was identical to mine but with higher handlebar installed. I couldn't believe how much the front end felt light and unstable comparing to mine. The original clip-ons put your body weight more towards the front and it makes a noticeable difference. I felt very uneasy with these higher bars and could not enjoy the bike properly. I am also glad thet my body size and archtecture make the clip-ons more comfortable then higher bars. Contrary to even my own expectations out of all my bikes the most comfortable one for long trips is '04 R1.
  21. Janusz
    Zero
    What a beautiful bike! For me definitely the nicest of all custom made Guzzi derivatives. And, although de gustibus non disputandum est, I strongly suspect that envy has a lot to do with some negative comments above.
  22. After reading all these posts about oil pressure troubles, relief valve etc. I became seriously worried about some of my trips far away from home. What if...? My bike is 6 years old and over 40,000 km but there are periods of prolonged lack of use especially during our winter months when moisture condensation in open carpot is severe. Is my reliefe valve just about to rust in solid? Is there an easy way of checking it?
  23. V11 S Short Frame is the king of Guzzi's! Any color you like except of silver. Then go all its derivatives like LeMans, Scura etc. After that anything goes according to your individual taste, except cruisers and with some positive bias towards old V7. Here then, I also registered my opinion.
  24. Steve, is it possoble to get a collector plate for as new as 2001 Guzzi from ICBC? They told me "no way". How are you doing it?
  25. I've read all info in this thread carefully and I am more confused then before. Could somebody please answer my questions in a simple manner, yes or no? I have just received a direct replacement of stock battery, a new Power Source WP13-12NE, which seems to be identical to Sparks 500. I have an old charger which has 6A and 2A switch and a little analog needle gauge which is an ammeter I believe. I also have a digital $10 multimeter. I will not install this battery for approx. 4-6 weeks before riding and the voltage measured is now 12.22V which means, as I understand, 50% charge state. Should I "top up" (charge) it now? If yes at what setting (6A or 2A) and for how long? I do not mind constantly monitor charging voltage with my multimeter.
