MINNESOTALEMANS
    2002 v11 lemans
MINNESOTALEMANS's Achievements
Guzzisti
Guzzisti (2/5)
0
  1. WANTED A PAIR OF STOCK MUFFLERS FOR A 2002 LEMANS USA ONLY
  2. give judson cycle a call Ron has a lot of guzzi smarts and parts 507/726/2222 hwy 60 east lake crystal mn. a dealer for 44 years good luck.
  3. how do you remove the clutch lever (stock one) mine moves up and down in the mount on the handle bar is there a bushing in the mount pin ?? and how do you get the pin out i took the nut off does it turn out? i cant get it out!! 2002 lemans
  4. 02 lemans 65,000 still works like new!!!
  5. GUZZI SADDLE BAGS, TIRES WERE PUT ON AT 58,800 MILES, RADIALS SUPER MAXXIS FRONT AND REAR / SILVER 61.000 MILES,GUZZI TANK BAG , , VERY SMALL CRACK RIGHT SIDE FAIRING FAR END BELOW TANK RIGHT OVER THE VALVE COVER, FELL OVER IN GARAGE, SOME SCUFFING ON RIGHT MIRROR AND VALVE COVER ALSO,SLIGHT CREASE LEFT SIDE MUFFLER FROM ANOTHER BIKE'S CRUSIER PEG BECAUSE HE WAS CHECKING OUT MY GUZZI, NOTHING MECHANICAL BIKES RUNS AND DRIVE GREAT, HAS THROTTLE MEISTER BAR WEIGHTS,BATTERY TENDER , DUAL FIAAM HORNS 120 DECIBEL,READY TO CRUISE ,email me for many more pictures and any questions, this a great deal for 4500, bought new in august 2003, ONE OWNER 50 YEAR OLD MALE RIDER email is oldjeeparmy@yahoo.com i posted some about my bike on here over the last 2 years let me know if any questions it is great deall
  6. I think you shoud keep your bwm and be happy. buy a v11 you wont.
  7. Bought it in august of 2003 with 0miles on it 2002 lemans red/ sliver has 52000 on it now
  8. 2 stock mufflers good shape small scuff on left one on top and a set of stock bar weights a speedomter reads 47500 has had the glass replaced with lexand small nicks on bezzel ?of it works good
  9. Its your cover seal in the diff housing leaking my had to be replaced along with the rear transmision seal at a little past 40k 02 lemans its better to have your dealer do it .
  10. Bmw makes replacement bushings for there arms i used them to replace mine 02 lemans you need to make two spacers orshims about 60 thous. thick theywork just fine and only $14.00 dollars each. good luck
  11. sorry about puting the question in the spot. torque arm bushings on my 02 lemans or shot front and rear the dealer said guzzi only sells the whole arm not just the bushings i dont need the whole arm($) will the bushings from a R11rt fit they look very close to guzzi size??????
  12. my front and rear torque arm bushings are shot . and guzzi will sell you a new arm NOT THE BUSHINGS BUT THE WHOLE THING. i just want just the bushings the arm is fine. any one have any ideas the bmw dealer thinks ones from a r11rt will work .????? 2002 v11 lemans 43.000 k
  13. i jusit came back from a week in the black hills(sturigs) i could smell gear oil looked around and found it leaking from the rear of trans where the drive shaft mounts to trans 43k on it is that seal hard to replace or a trip to dealer for this one ? its not pouring out just makes amess of the rear wheel rim only not tire:
  14. the same thing happen to me 02 lemans went to my dealer judson cycle sales (the best) put in a set of bmw stainless steel ones NOMORE valve trouble
