MINNESOTALEMANS
Everything posted by MINNESOTALEMANS
WANTED A PAIR OF STOCK MUFFLERS FOR A 2002 LEMANS USA ONLY
Well, I crashed it - parts fiche for V11 LeMans?
MINNESOTALEMANS replied to Repeater's topic in Technical Topics
give judson cycle a call Ron has a lot of guzzi smarts and parts 507/726/2222 hwy 60 east lake crystal mn. a dealer for 44 years good luck. -
how do you remove the clutch lever (stock one) mine moves up and down in the mount on the handle bar is there a bushing in the mount pin ?? and how do you get the pin out i took the nut off does it turn out? i cant get it out!! 2002 lemans
02 lemans 65,000 still works like new!!!
GUZZI SADDLE BAGS, TIRES WERE PUT ON AT 58,800 MILES, RADIALS SUPER MAXXIS FRONT AND REAR / SILVER 61.000 MILES,GUZZI TANK BAG , , VERY SMALL CRACK RIGHT SIDE FAIRING FAR END BELOW TANK RIGHT OVER THE VALVE COVER, FELL OVER IN GARAGE, SOME SCUFFING ON RIGHT MIRROR AND VALVE COVER ALSO,SLIGHT CREASE LEFT SIDE MUFFLER FROM ANOTHER BIKE'S CRUSIER PEG BECAUSE HE WAS CHECKING OUT MY GUZZI, NOTHING MECHANICAL BIKES RUNS AND DRIVE GREAT, HAS THROTTLE MEISTER BAR WEIGHTS,BATTERY TENDER , DUAL FIAAM HORNS 120 DECIBEL,READY TO CRUISE ,email me for many more pictures and any questions, this a great deal for 4500, bought new in august 2003, ONE OWNER 50 YEAR OLD MALE RIDER email is oldjeeparmy@yahoo.com i posted some about my bike on here over the last 2 years let me know if any questions it is great deall
I think you shoud keep your bwm and be happy. buy a v11 you wont.
Bought it in august of 2003 with 0miles on it 2002 lemans red/ sliver has 52000 on it now
2 stock mufflers good shape small scuff on left one on top and a set of stock bar weights a speedomter reads 47500 has had the glass replaced with lexand small nicks on bezzel ?of it works good
Its your cover seal in the diff housing leaking my had to be replaced along with the rear transmision seal at a little past 40k 02 lemans its better to have your dealer do it .
Bmw makes replacement bushings for there arms i used them to replace mine 02 lemans you need to make two spacers orshims about 60 thous. thick theywork just fine and only $14.00 dollars each. good luck
sorry about puting the question in the spot. torque arm bushings on my 02 lemans or shot front and rear the dealer said guzzi only sells the whole arm not just the bushings i dont need the whole arm($) will the bushings from a R11rt fit they look very close to guzzi size??????
my front and rear torque arm bushings are shot . and guzzi will sell you a new arm NOT THE BUSHINGS BUT THE WHOLE THING. i just want just the bushings the arm is fine. any one have any ideas the bmw dealer thinks ones from a r11rt will work .????? 2002 v11 lemans 43.000 k
i jusit came back from a week in the black hills(sturigs) i could smell gear oil looked around and found it leaking from the rear of trans where the drive shaft mounts to trans 43k on it is that seal hard to replace or a trip to dealer for this one ? its not pouring out just makes amess of the rear wheel rim only not tire:
the same thing happen to me 02 lemans went to my dealer judson cycle sales (the best) put in a set of bmw stainless steel ones NOMORE valve trouble
sam try abuell dealer or check how to section on page 4 buell turn siganls i think the ones of a s2 will work
with regrets ,mixed, selling,i think,stranded
MINNESOTALEMANS replied to fernando's topic in 24/7 V11
I have the same trouble with my 02 lemans if its hot 95+out it wont run if you stop and start again (for gas or a pop ect) no matter what i do to it i have leard to park it out in the open not next to others to help it cool of so the fuel pump make the (right sound ) if i dont hear the good sound I HAVE TO WAIT there or down the road when it quits so i wait at the gas station ,bar what have you less stressful that way. and not as imbarssing just life the guzzi way iguess you figure ways around it.dont sell it you will miss it .be chosee ride a guzzi ! -
mine went to @##$ at about 29, 000 miles the spade conector part was loose new one from dealer was 57.00 +tax easy to fix it hard to understand 57.00 for that ! O well thats the price we pay
Not that idont like BMWs but come on no more pics .of them guzzis guzzis guzzis
The redline oil is the best! Ihave used it for 4years in my 02 lemans over 34,000 miles NO TROUBLES with it at ALL! Buy 2 qts 1for the gearbox 1/2qt for the rearend and your good to GO!
Ii WHEN TO MY AUTO PARTS SHOP AND BOUGHT SOME DEI wrap for headers and put it on the pipes it said to soak in water then apply it. my question is do you think it will help stop the fuelboiling when it realy hot out and you stop for gas andhave to wait a half hour to go again? have done all the other mods to it . fuel pump wrap and lines and removed the tip over valve. it looks good on it but will it last and work? 2002 lemans
6,000 DOLLARS!!!! 29,400 MILES, ONE ADULT OWNER RIDDEN, BOUGHT NEW IN AUGUST OF 2003,FACTORY GUZZI TANK BAG, AND EXPANDABLE SOFT SADDLE BAGS,THROTTLE MEISTER BAR WEIGHTS,CONTINENTAL ROAD ATTACKS TIRES, FRONT AND BACK TIRES, REAR WAS PUT ON IN AUGUST 2005 , FRONT WAS APRIL 2005 , NEW BRAKE PADS FRONT, K & N HIGH FLOW AIR FILTER,SMOKED TURN SIGNAL LENSES,MUFFLER CANS ARE UNPACKED, RUNS AND DRIVES FANTASTIC , IF YOU WANT PICTURES , PRIVATE MESSAGE ME AND LEAVE YOUR E- MAIL, I WILL SEND YOU SOME, BIKE IS LOCATED IN SOUTHERN MINESOTA, ALWAYS GARAGED, CAN BE SEEN JUST LEAVE ME A MESSAGE, DELIVERY AROUND LOCAL AREA IS AVAILABLE,JUST ASK, BIKE IS A SUPER CLEAN LEMANS
I BUY TIRES FROM BOBS CYCLE SUPPLY IN MINNEAPOLIS WHERE YOU NEVER PAY RETAIL AND CHANGE THEM MYSLEF WHITH A CHANGER FROM HARBOR FREIGHTCO. AND SCRATCHED THEM MYSLEF TOO. THE PRICE OF DOIT YOUR SLEF.ITS GOODTRANING FOR WHEN YOUR OUT ON THE ROAD.AND YOU HAVE TROUBLE P.S I DONT TRY TO SCRATCH THEM IT JUST HAPPENDS SOME TIMES
