hgravelpha@aol.com
About hgravelpha@aol.com
  • Birthday 08/13/1969
741 profile views
hgravelpha@aol.com's Achievements
Guzzisti
Guzzisti (2/5)
0
  1. does anyone have the part number for the harley rectifier that will work with a 2001 v11 sport?
  2. It's alive...... Just changed the switch today and I have neutral again. They must have defeated the switch or swapped it with a defective unit. Loving it. I can warm it up without being on the bike - 10 long years. Thanks all.
  3. i just purchased the neutral switch from mg cycle. i will find out if it is the switch by the end of the week.
  4. what is the part number for the neutral switch? where can i buy one online. nearest dealer is 45 miles away even living in la, ca.
  5. i was able to ground the wire from the neutral switch and the neutral light came on. i then removed he neutral switch and it appears fine. i then plug the wire to the switch and ground it with the plunger pushed in and the key on but no green light. does this mean that they did something to the neutral switch or something internally? do i need a new neutral switch or do i need to do something behind the plate? i think i can rule out the relay as a culprit?
  6. when i first bought my 2001 v11 new, i was having problem with the false neutral. took it to orange county motorsport and they told me that they can disconnect the neutral something completely or put two wires together but the downside would be that i cannot start the bike with the kickstand down. i agreed but now would like to put it back to its original state. what did they disconnect or connect? i cannot find any loose wiring. the neutral light has not come on in 9 years.
  7. How about $100 for the rear wheel and $50 for the exhaust cans. Is the wheel the larger width? I have a 2001 with the 4.5" rear.
  8. I purchased a set of fbf high compression pistons on ebay. I was going to install them tomorrow but I saw a pic from helicopter jim's installation and they appear to be different. My pistons looks like the ones on the fbf site. Helicopter jim's pistons were more angular or sloped on the top. Any info would be appreciated. Can I still use it? It would suck if I can't..
  9. I am going to install the pistons in the next two weeks. With two young kids, I am having trouble finding time to install them in one sitting. I will try and install one cylinder at atime. Wish me luck.
  10. Does anyone have instructions on how to install FBF high compression pistons. I bought them on EBAY but they did not come with intructions. If you have a set of instructions, please email them to me at hgravelpha@aol.com or fax to 562-463-1336. How hard was it to install? How long did it take? Any tricks that you had to do to make it fit? Do I have to do anything after the installation - timing - adjustments This a mod that I really wanted to do for years, so please don't spoil it for me with negative remarks. Oh yeah, my bike is a 2001 V11. Thanks, Thang
  11. PIC Test
  12. Thanks Greg, I'll order it on Monday through your company. Is this the part number for the angle or both the cable and the angle. If separate I would like to order both.
  13. Speedo went down yesterday. Look at the angle drive that connects the speedo cable to the transmission on a 2001 model - there is a hole and no innerts. Guess it fell off while I was riding. What do I need to buy- the speedo cable and the angle drive? Are they one unit? Where can I get one of these? My dealer does not have one in stock and does not know if a later unit will work with the 2001 model. I have the white Veglia speedo. I do not want to change to the black speedo. Any hints will help. Thanks.
  14. Thanks guys for the info. I will check it this weekend. If not, I will hunt for a used white face Veglia Tach.
  15. It is a 2001 v11 sport with the Veglia (white face) tach.
