Joe_V11
    2000 V11 Sport
Joe_V11's Achievements
Rookie
Rookie (1/5)
0
  1. After reading this thread and looking at the pics and diagram, I'm thinking the illustrated fitment might be backward. You seem to be using the "tipover valve" as a way to get air into the fuel tank, and it may work for that in helping to avoid tank suck. But the purpose of the carbon canister, I'm pretty sure, is to collect hydrocarbons that come out of the tank as it sits (if there is a build-up of pressure in the headspace of the tank due to temperature fluctuation) - when the bike is restarted, the hydrocarbons are pulled off the carbon and into the throttle bodies where they become part of the fuel/air mixture introduced to the engine. For this to work, the valve must let air out, but not in. The orientation suggested in this thread lets air in, not out, if I've read the posts right. I'm interested in this because I recently replaced the stock air box with pods (for the "looks cool" factor) and at the same time removed the carbon canisters and associated plumbing. Since then there's been some occurrences of the bike losing power for short periods during sustained high-way-speed riding, leaving me to wonder whether I have taken care of the plumbing issues properly. (Restarting hasn't been a problem and low-speed riding gives me no problems.) What I've done is to plug the vacuum ports in the throttle bodies and just run the two hoses coming off the bottom of the tank (the one with the tipover valve and another one that's just a hose, I think it went into the airbox) down toward the bottom of the engine, letting them vent to atmosphere. The tipover valve I've left alone, and I believe it's plumbed the opposite to the photo - that is, long end is up, but plumbed into the tank. I'd appreciate getting anyone's thoughts on this, in the meantime I'll continue researching and check with some non-Guzzi folks for outside advice.
  2. Agreed, thanks for the post and pics. Having just dropped my V11 my right-side Ti can has a nice dent inside under the strap. Nice to know I can take it apart and fix it.
  3. When I read your first note I was reminded of when I bought my 2000 Sport (used) - the connection between the spark plug cap and the plug wire was burned (how does that happen?), and replacing it solved an occasional misfire in the affected cylinder. From reading the thread it sounds like you have good spark, but it's worth taking a look. Don't know about that revving up part, though...
