fotoguzzi
    21
  1. Too bad your changing the look.. to me no other motorcycle has such a muscle bike profile..
  2. I've got a set made by my friend.. $200 with an extension for the brake line included.
  3. fotoguzzi
    manuals
    go to Greg Benders site, download free.. http://www.thisoldtractor.com/moto_guzzi_misc.html then print out a copy.. I did it at work so used their ink..
  4. my Lemans (stock) had the same stumble at 3200 and when I got rid of the stock crossover for a Mistral the stumble went away.. I did not have the front balance pipe tho..
  5. first I would load test the battery.
  6. I do think there is a difference.. in the bottom plastic and you might be able to modify it.. or if it was only $125. you should be able to flip it and not loose any money..
  7. as to vibration.. make sure both tires are balanced. and steering head bearings tightened to spec... also the forks have compression in one and damping in the other leg, some miss match in settings could set up some vibration? I doubt the TB sync would cause that much vibes accept at idle. note that the steering neck/frame bolts right to the timing chest of the motor, vibration is inherent in the design so if the motor is not well balanced you shake..
  8. seat looks re-worked.. bars look really nice, no idea what they are.. if you need a steering dampner go for something after market. stock wears out fast. I never thought it was needed but the 02 and later have slightly less rake.. Nice looking bike w/low miles, good for you!
  9. "One thing that really gets on my nerves is everything needed lubrication." don't forget the driveshaft, total of 3 zirks, front one is a pain to get at, a swivel nozzle will help. do it with the axle insitu so the shaft doesn't stretch when you put lube in the center zirk.
  10. LOL! stock? maybe 75-80hp..
  11. my opinion, throw a lot of money at it and you get small performance upgrade.. Enjoy it as is for what it is..
  12. did it clean up well enough to leave bare? or would a guy have to repaint it?
  13. is the throttle linkage returning all the way to stop? high speed lever on left grip turned down? has someone messed with the stop screws on the throttle bodies?
  14. that looks like the Bomb! I'd mount that up yesterday.. make a video of the sound for us..
  15. Price not bad especially in California.. If it's been f/s awhile offer $3500 but come with $3800. Just get it, you won't be disappointed. just a note, the 99-00 bikes have slightly tighter geometry- less rake, trail or wheel base?, they turn in quicker than the 01-on v11's.. I found it unusual after riding my 02 a few years.. probably wouldn't have noticed without owning the Lemans first. find more Guzzi enthusiasts here, http://wildguzzi.com/forum
  16. The VF1000R or the Rosso Corsa:) the Rosso but I probably don't have enough funds, what would it take to buy? how far from Minneapolis are you?
  17. sell it to me, what's your location?
  18. I'll just add, the stock heated grips on my Buell Uly were fantastic.. maybe they could be used.. no wires showing, 2 levels of heat.
  19. I would grab that deal.. I've had a few odyssey batteries last over 7 years.
  20. I can't really see the end cone from the foto but they look like Mistral reverse cone pipes like I had.
  21. My experience with the Corbin, it looked nice and should have been more comfy but you have to be just the perfect size or it doesn't work.. If I were 6' and not 5'10" it would have been a keeper.. as it was I sat and inch or 2 forward of the pocket so never got comfy.
  22. check the oil pressure sending unit for the oil leak or one of the hoses feeding the cooler? the whisling- it's not the rear tire isit?
  23. Time to move on from Guzzi, they got stuck in the old world. pretty sad..
  24. I got a swivel fitting for my greese gun from Ace hardware, it is about 2" long and swivels enought to engage the front zerk.
  25. Pray tell? that's all I remember, call MPH in Houston.
