fotoguzzi
    21
  1. what happens if you move the tps to lower voltage say 450mv? sounds like too much gas is being fed for the speed of the motor. are the air by pass screws open a half turn or so?
  2. ps, do you know of this site? http://wildguzzi.com/forum/index.php?board=1.0
  3. yes, but the later models (cal 3 on?) have a 3" taller steering neck and longer swing arm.. the frame behind the triangle was longer too. so it won't have the compactness of the original Tonti. this is a Jackal..
  4. I have a silver tank for a 99 Sport. it has swelling and the forks touch on full lock. I'll sell for 50 bucks plus shipping. you could paint it w/out ruining your stock tank. got the rear tail piece in silver too..
  5. they did make a V11TT , I have a friend with one. I've not seen it yet so don't have pics.. it's black and silver.
  6. What a BUMMER to wake to that news..
  7. STUNNING! be (relatively) glad you got the Veglias. carry a shift return spring in case..
  8. I have a friend using Pentax, seems good.. if you have lenses stay w/Pentax if not Canon..
  9. NICE VIDEO, you should consider an upgrade to something like a Canon T3i or 60D for higher quality video to match your skills/creativity.. good editing too. not sure if I posted my latest or not.. first two shots are my GoPro and the rest is shot with my new to me Canon 60D w/Rokinon 8mm.. bump up the res on bottom right of window..
  10. thankyou! I have a NAPA 1 mile away..
  11. start with a load test to battery, sounds like it went dead.
  12. fotoguzzi
    V1100 Sport
    You will totally fall in love and forget about any Beemer you used to like.
  13. personally I wouldn't mess with any booster pack, and wouldn't have tried jump starting either, a bump start maybe.. take your battery in for a load test or borrow a known good one but don't rely on some extra boost to your battery. after you fix the battery problem then you can find out if something else is funky. yes you may have fried something in the ECU, what Guzzi and what ECU is it anyway? I had a buddy at work fix 2 bad p8 ECU from 98 EV's.. it was a diode I believe and I have a pic if you have that same box.. your Spot is probably a different unit tho..
  14. I would try a known good battery before buying anything.
  15. the good thing about a v11 Lemans is there is no chrome (accept the ring around tach and speedo) the other parts can rust.
  16. Great Ben! I'll be watching the roads for you.. do you need help doing that gasket? my Lemans spews a little mist, I "think" it's from the timing cover but isn't bad enough to want to fix it yet.
  17. HB is very nice sturdy luggage and the top box works great if not loaded with heavy stuff.
  18. Wait, the key was off? it blew just by putting the fuse in? maybe your regulator is fine, something is crossed up, check the ignition switch? when the starter came loose, how loose, could it have buggered up the electrical connection and it's shorting?
  19. THIS THREAD NEEDS PICS.
  20. AND COLLECT A LOT OF TAXES
  21. agreed, don't waste your time, the V11 should be braked from the front, mostly.. if you do it anyway, I think you could just get a system (m/c hoses etc) off an EV, mount the manifold/proportioning stuff in an out of the way place, make the hoses fit up to your existing calipers. probably need to change out the front pump to the one off the EV too.
  22. Yosemity Sam is often seen warning people not to tailgate,
  23. unscrew? turn screw out? I didn't read the link but is it about the throttle stop screw? I have one of the two throttle stop screws "backed off" so that only one screw affects the idle..
  24. price seems a little high if he wants to sell.. you can look up ended auctions on ebay and see what some have sold for..
