fotoguzzi
    21
  1. wheelsucker, two for one at the bar? how about someone posting PICS!
  2. I have most of the Centauri bits to lower my LemaNS PEGS BUT IT DOESN'T LOOK too easy to fit up// the brake lever has a bend in it and looks like a awkward position to apply brake. anyone have picsd of the Centauro pegs on a V11?
  3. if you grease the center zirk (the spline area) with the wheel off, grease will push the driveshaft out making it longer and the axle no longer aligns. so I had to take off the zirk and push some grease back out while pushing the back of the shaft in. put axle back on then refill the zirk fitting.
  4. yes get a photo! I found the front joint pretty easy to lube once I had the right tool.. from ACE hardware i got a grease fitting with a swivel head so it can fit up the cover from rear and then swivel to the angle needed to reach into the zirk.
  5. you should check w/Mark @ moto guzzi classics, signal hills, ca.. sorry I don't have the number but he might have the front cover (used) and some other stuff.
  6. sorry to hear that.. could you tell the insurance company that you hit a deer or something to get coverage? I'm in Bloomington, have we met? if there is anything I can do to help I will.. I have trailer, garage w/ tools and lifts if you need space to repair. are you on the local Guzzi newsletter list? our rally at grand Marais is 2 weeks out hope you can make it, Brad leaving for wisconsin rally in a couple hours.
  7. Now you should get the Mistral crossover.. that little stumble will be gone.
  8. fotoguzzi
    Newly Smitten
    Welcome to the board.. here's a link to help you find your new Sport! http://www.jaxed.com/cgi-bin/mash.cgi?itm=...amp;ys=&ye= today is going to be perfect here, 83F.. blue sky.. I'm gonna RIDE!
  9. are you left handed too? is your computer a mac? we're a bunch of oddballs, welcome!
  10. you have a 15m computer. the one you reference is a p8 from a EV or cal 1100i.
  11. sidestand switch? wires around steering neck under tank, left side can come unplugged?
  12. welcome! dive in, mine keeps getting better and better!
  13. do you have any tank suck? what color are the plugs?
  14. the fuel filter is a one way device (on my bike w/external pump) maybe you have the FF in backwards? that might be too nutty.. ?
  15. that sounds a little like the stumble/cough I had at 4200rpm... I put on a Mistral cross over and it went away completely. Is you air cleaner flowing air or could there be a mouse nest in there?
  16. Lucky guy, did you get the Gold color? welcome to the board! you must know of Moto International, yes? my charge light never does that, start by checking the battery posts are clean and tight, and the ground wire from battery to motor or frame.
  17. I just got them from edge a month or two ago, nice! got rid of the hugger completely, is that OK?
  18. fotoguzzi
    MPG...
    AGREED!
  19. you could probably make a really nice up trade if it is nice condition.. go to Moto International and trade for the same type but w/out the fairing.
  20. Because that is where the dirty oil is!
  21. good , just testing! could a tight zip tie do the fix?
  22. how do you know its the CPU and not the plug?
  23. sounds far out but try cleaning the ignition switch. you've tried everything else!
