fotoguzzi
    21
  1. I had that thought too.
  2. could you just put a variable resistor in line and w/an Ohm meter follow readings to find out what the optimum reading "should" be.? Then correct the the sensor with a small resistance? I'm not afraid to ask dumb questions!
  3. thanks for posting that!
  4. OK here's my new apparatus, a friend built this for me, I paid him 50 bucks.. it fits tightly on my jack stand and is a trick to get under the bike but once up it's very stable side to side.. it can still rock fore and aft a bit so when I work on one or the other wheels I'll support the other end. I need to avoid working on my knees some of the time. my jack doesn't seem to have full power, can I rebuild with o-rings or something to fix it?
  5. I just got this for 52.00US at Harbor Freight.. I'm quite pleased with it. once set up for tire size I can roll right in and walk away.. I trust it more than a sidestand in my garage. the straps are not needed.
  6. if you squint a little it looks like your bike has 4 nipples like a cow!
  7. the tranny is fine but the bike did have a little lay down which ground a little edge off the head fins on the right, looks like a file could bring it back to looking normal. the rear body piece over the fender has a crummy looking fibeglass repair and there might be a scar on the front fairing right side. It would make a great bike for LSR or track.. I can only guess around 600. to ship to LA.. I'm in Minneapolis.. I could deliver it to any shipping company if it came to that. I sat on it and the Converti bars made it fit just like a V11, made me want it even more but I have no cash.
  8. here's the 1000S
  9. I have a new friend with a simply gorgeous '93 1000S. black w/green. I'm helping him get it back near stock and add a bikini fairing. This is his dream bike, I wish I could steal it from him! sorry no pics yet, we had all the body work off. It has such a clean uncomplicated look, I think it might be the nicest looking Guzzi I've ever seen. I'll try for pics today. anyhow, Now that the dream bike is in the garage he wants to sell a nice 1100 Sport for only 3500. someone save me by buying it! I know it's a little to long for me but I have been dreaming of that motor in a 1000S replica.. I've got a frame, EV forks, 5 speed, SA w/7X33 RD, and some older cast wheels or Borani spoked... I'd need a gas tank, seat, fenders, instruments would come w/the sport wiring loom. someone please buy it so I can sleep at night again!
  10. I like the bar, wish I had a 1200 sport but I love the V11.
  11. do you need the base too or can you change tires w/just the bar?
  12. I visit here almost everyday... what would I do as a moderator?
  13. i doesn't even need a side or center stand?
  14. checking your valve gap is the simplest of tasks and YOU CAN DO IT YOURSELF! all you need is a hex wrench and a feeler gauge. http://www.guzzitech.com/Valveadjust-terry.html http://www.guzzitech.com/tdc-tracy.html here's pics, http://www.kodakgallery.com/Slideshow.jsp?...mp;conn_speed=1 oh yea, you need a 11mm box end wrench and a vise grips or small crescent wrench. you don't need the big socket on the crank nut. you can rotate the motor by turning the rear wheel in a high gear.
  15. if this is a V11 it doesn't even have a crank sensor! maybe they changed the cam sensor? and I see they got him a TPS for 329. surely all those things together were not the problem, one of them maybe. FYI, you can get a better regulator from the aftermarket for less $.. and 32.00 Harley TPS will work..My V11 sometimes stumbles around 4200 rpm and does not like to cruse along steady in the range. I change the TPS and it got slightly better. someone told me that is the nature of the bike w/stock crossover. I plan to try smoothing it out some with a fine tuning of the TPS and redo the valve settings this spring. Have you looked at the relays? probably not related but funnier things have happened w/the stock Seimans relays, get a set of replacements from DPGUzzi.com for less than 20 bucks, if you still have the seimans try something else.
  16. hurry up w/the next installment.. is filling the void really going to increase comfort?
  17. I would worry the sport motor would over power the convert tranny, or running gear. but I did it with a EV motor and if I can score a v11 motor and systems I have all the convert parts to build one.
  18. Everything is gonna change, give the guy a minute to catch his breath.
  19. well it's not really cafe or muscle but I wanted to show my conversion. I started with a crashed EV motor, Convert running gear and SP body. had to use a cam and front cover from a vert to run the ATF pump. made the mags tubeless, modified the EV seat and luggage, modded the flywheel for the crank sensor but it was tricky, see.
  20. visceral, raw, sound, and the way you hold the motor between your knees.
  21. Get a new set of relays for under 20 bucks from Pyro Dan, dpguzzi.com you can download parts book and service manual here, http://thisoldtractor.com/gtbender/moto_guzzi_misc.htm
  22. ahh! thanks for reporting back.. were the originals Seimens?
  23. by my snowy video did you mean the icycle derby? I exported from Imovie and selected "for the web" and the mac calculated the size, that made it about 14MB size and was a pretty fast to upload to you tube, I think it has a little better quality than photobucket. so I didn't have to think about the size of compression at all w/you tube.
  24. if you had a .mac account you can host a larger file there and it doesn't have to be compressed as much. OR maybe you should try google videos? I had the same problem with photobucket as a host. who is your internet provider? they might have storage space you can use instead of you tube.
