Lamedog
    '02 Lemans. '81 Cafe thing
1,228 profile views
Lamedog's Achievements
Guzzisti
Guzzisti (2/5)
2
  1. Lamedog
    Lamedog
  2. I just fit the Mistral crossover to my Nero Corsa. I'd already put the MG Ti cans on the bike and left the stock ECU (the Guzzi pipes come with a different map that presumably has greater advance.). Adding the crossover gave splendid improvment, and I'm still using the stock ecu. I will try swapping the ecu and PCIII this week.
  3. Thanks. Dad always said "Plan your work, work your plan". I am not the man he is/was, and continue second guessing - even when it is a good plan and on track. Will go ahead and complete the project of building my perfect classic sports tourer. Photos soon on Nero Corsa Register.
  4. 1,400 miles, perfect condition. MG Ti pipes, Roper Plate, Odyssey Battery, Buell Pegs, Throttlemeister bar ends and custom bar risers. Fits me perfectly at 6' 2". Currently fit with headers from '02 but can restore to stock '04 exhaust with front crossover. Stock crossover at the moment. Pics would just show a perfect condition Nero Corsa with Ti pipes. San Francisco Bay. All parts to return bike to stock. Daniel Craig, Sean Connery or Bradd Pitt would ride this bike. Tom cruise - not so much. The next stage of fettle involves selling the stock exhaust with my '02 LeMans, adding an aftermarket crossover and reflashing the ecu. This is another $1,200 and won't be recovered, although I will have the perfect Nero Corsa and continued admittance to the great Bay Area Guzzisti club. The worst part of selling the Nero would be that I cannot envision a more perfect replacement for anything like the money it may bring.
  5. Al, you're adventure with this bike - as well as the many other "old dude's" was what got me into Guzzi's. It does seem a shame to sell - even in the midst of a Guzzi revival this "best example", won't dent school fees. Maybe the best logic to sell is that the project is complete and perfect. What is left to do? Anyone smart enough to be on this forum will appreciate the refinement of you bike and its attendant value. Best Wishes
  6. Thanks Skeeve. It is easy enough to experiment.
  7. Searching past tech topics for this, but thought I'd post here. Picking up a '04 Nero Corsa with 1200 miles tomorrow. A bit to new to be a barn find, but the owner's priorities changed soon after buying it and he has a bigger garage than mine. I cUrrently own an '02 Lemans that is well sorted at 31 k miles. Idea is to move the better bits from the '02 to the corsa and sell the '02 since this makes things easier at home. Question is how much to migrate? The '02 has "guzzi" Ti pipes and ecu, a PC III with map recommended for this setup from Moto Intl, Roper Slop plate, centerstand, and some ergonomic aids (HD lower pegs and custom bar risers). Runs much better than stock, though the dominant benefit was the exhaust and ecu. Power commander seemed to help with the power dip in mid RPM, but I never did put it on a dyno I'm thinking, the Ti map would have incorrect map for the '04 because of the front crossover (at least). Is it worth swapping this for the ignition advance and correcting the map with the Power Commander? Or, is there an '04 ecu available separately? Or reflash the '02 TI ecu? Is there consensus on value of the front exhaust crossover? This one is still tight because of low mileage. Any sense in switching to headers and using the '02 PC map, or is this a losing propisition? Also between '02 and '04 they changed from caps on the throttle body port to an interonnecting hose. Does this complexity help performance, or is it just a gradual accumulation of clutter?
  8. Picking mine up tomorrow, an '04 with 1,300 miles in beautiful shape. Will post pics. Interesting that it's about 30 miles away from Splicer's. expect we'll run into each other at the next Alameda Italian car/bike show.
  9. Thanks guys, been awhile since I have been here. I don't have an Axone or ability to test exhaust. I did have the bike running great awhile back with the Ti Ecu, and a PCIII map I made by combining maps from Moto Intl web site when I got the new exhaust. But things slipped toward the end of last summer with more uneveness at low throttle and a bit of popping on decelleration. I replaced TB rubber manifolds which were cracked (but not thru as it turned out), plugs and HT leads. New fuel filter, set valves and adjusted TB's with the above procedure. Things got considerably better, but not all the way back. I'll set up the fans and give it another pass. Will try a few settings at 1100 RPM indicated and take notes on what seems best. I love the bike and with 30k miles there is no reason to let such a lovely thing go.
  10. Adjusting TPS and balancing TB's this weekend on my '02 lemans. Bike has the Ti exhaust and ECU. I don't see reference in the procedure where this affects the target 521 mv. Any thoughts on this? Also, do I disconnect my PCIII while doing this? Wouldn't see why, but its easy enough to do. Thanks for helping me beat an old horse....
  11. Second docc's advice. My '02 developed serious hiccup and power loss this spring. Finally did a real TPS adjust instead of just sync TB's, do valves, filters and fluids. Solved the problem. I replaced Rubbers between TB's and head because Of the many evident small cracks around outside. Couldn't see them on inside, but wanted to be sure there were no air leaks. Not too expensive in any case. However, subsequent destructive testing confirmed they were superficial only. I hear this is a common dead end for folks. Do TB synch and TPS adjust first. Enjoy, this is part of why you bought a Guzzi, though you may not have realized or desired this....
  12. Thanks Docc, thanks Soren. I am of the mind and attention span that an '81 Guzzi is probably the most complex thing I can envision putting precisely as I want it. No such success with wife, kids, dog, house, etc. This is close though. This weekend I begin the added support for the seat pan back. Will post if it turns out nice and deny if it doesn't. Dennis
  13. I wire brushed the corrosion and painted them with a matte black automotive paint.........turned out perfect ! Me too. Use fancy rattle can for brake calipers. Just noticed I need to do this again.
  14. Link to my project before I futz further. '81 G5
  15. Lamedog
    81 Cafe
    This silly bike is for sale too. Will keep this or the 'O2 Lemans whichever doesn't move. Start point was an '81 G5, but not much remains. Engine was done by Ace Mallot. I talked with Ace and previous owner. Can't confirm, but understand it has been flow balanced, new cam, steel timing gears, (somewhat) lightened flywheel, higher compression pistons and Carrillo rods. Recent clutch. Rear drive and transmission rebuilt by Charlie Cole. Virtually everything else on the bike is new. This bike generates comments and smiles for sure. It rides and sounds great. I have put in 300 mile days on the bike on NorCal coastal roads. Not sure you'd want to do this on a regular basis - but it can be done. Project Entertaining reasonable offers over $15K. Which is a silly price until you look at Kaffee Machine's Roundhead and realize they are 15 to 18 k euro, and this one has some nicer features imo. Oh well, maybe Billy Joel or Jay Leno will accept my Facebook request.
