nose2wind
    2000 v11s
nose2wind's Achievements
Guzzisti
Guzzisti (2/5)
0
  1. nose2wind
    nose2wind
  2. I don't believe 471 lbs on a Stelvio. More like 571... The BMW is lighter than the Stelvio.
  3. I still have my V11s after purchasing a Stelvio. If I had to sell one it would be the Stelvio. The V11 is my short ride bike and such a classic and still a hoot to ride. The Stelvio is a long distance machine. I don't like the weight of the Stelvio.
  4. I had a similar problem just after purchasing a 09 Stelvio @ 20,000 miles. I installed new gaskets ($$) and have over 40,000 miles with no issues. I understand that if you let anything get loose at the fittings the gaskets are prone to blowing out. I checked mine for loosening up, but no issues. We are talking about the expensive carbon spacers?
  5. The Good I have 2 Shorai batteries in a newer vintage Stelvio and Buell. Weight savings in nice, but not the only reason I switched. The batteries can sit longer without needing a charge. I don't like having to put my bikes on chargers. They should last longer and don't have acid. So far I like them. The Bad In very cold weather they loose cranking power. I have not been stranded, but have noticed the weaker starting on cold mornings close to freezing. Below that could have been a problem. Fitment for a 2000 V11s. I have called on the Shorai and another brand and was told they do not have a battery for this model. Something about the older model charging system is not compatible. Not sure what that would be, but It put me off for now. If you find out different let me know.
  6. I purchased a 2009 Stelvio. It has/had Pirelli Scorp Trails. The originals were Syn's. I need to replace the tires. Is there a preferred tire for this model? The original owner seemed to like the Trails a lot. Any suggestions? TIA
  7. I like the V7 series too, but they need to make a dual sport out of one!
  8. Hey Docc, been awhile. You get a Stelvio. I was considering one, but the weight has me a little concerned. You?
  9. I would like to replace my relays. Is there a good source to purchase from? There used to be someone on the list who was selling them. I checked Autozone and they were really expensive. Thanks for any help
  10. Hey sorry. That was referring to a filter cleaning kit for the K&N filters. It sold long time ago.
    Thanks !
  11. What is an oil cleaning kit?
  12. Docc, I think Guzzi moved away from the bevel drive because they had a tendency to self destruct. I'm on my 3rd! Birddawg
  13. So what would they charge to put some other internals and re-calibrate. That might be the way to go if the price is right. You get a decent speedo that looks great. A new Veglia is gonna go south eventually and $300.00 a pop Birddawg
  14. Just a heads up, While trying to track down a stumble I was checking fuel filter and blew out a bunch of black residue. I think the tank to pump hose was emitting a residue (black Powder) substance into the filter. I changed out the hose. The bike is 10 years old now so maybe a good idea to change these out. Birddawg
  15. Hey Doc, I sent my speedo to North Hollywood Speedometer once. Came back fine but has some similar problems again. I think you did the right thing going new. It cost almost as much to ship and repair with no Gaurantee. Birddawg
