Thanks guys for the replies. Interesting comments. I should clarify my question: i'm not necessarily looking for outright power at 8000rpm, i've heard that the upper crossover increases mid-range which is an area i'd like to maximize (i'm hoping to rely on the torque and great handling rather than outright power). I'll be dicing (or should i call that following) 110 HP Z1's and CB's and in Vintage Superbike so i have to pick my battles......
I've noticed that the '03 V11's have the upper crossover after not having them in prior years so i figured Guzzi were up to something??
Greg, i'm using 38mm SP forks with Maxton internals and T-3 wire wheels. I'm also using the La Franconis but i'll cut off the first few inches of taper to fit the larger diameter headers. Also using a Mk 3 frame so i can use the frame as a breather.
As regards eligibility of the 97 motor..... like technology!!!! i'm entering it as a MK3 (bored and stroked) and i'll be well within class limits and truthfully if someone protests my measly 85 hp and 480lbs then they would need to get a life.
Other specs are: stock bore, Mike Rich heads milled for 11:1 compression, Carillos, x10 Megacycle cam, Ti pushrods, Mikuni carbs (39.5mm) and Dyna ignition driven off the cam.
I've spent the last year gathering parts and i'm close to starting the mock up. I'll be posting pix soon. Any further comments or advice will be hugely appreciated.
