Everything posted by mznyc
Got to poke around today.Yep,fiddle with that relay and she comes to life.Can't isolate which connection is failing tho,...I guess beefing up the whole block is in order....
Thanks PA!
Thanks Docc,this will help if the relay board is not the issue...
Thanks Chuck,the bike has never been molested by me or previous/original owner.I will check connections are switchgear if the relay board is not the issue but when this originally happened I pulled the board and massaged it,it came to life,so going to focus on that first then move on to other options...Thanks!
Replaced all relays to new Ormon,just cuz,....NO FUEL PUMP...,I'll pull relay block again and see if working it a bit brings the pump back to life as it did before. Where do I check to see if volts are getting to relay block and pump.Just want to make sure volts are coming from ECU and then past relay to pump... Thanks!
mznyc replied to p6x's topic in Newer models
Directly from the Piaggio guys last week,who will gobble them up for promotions,the shipment is due in December... -
Anyone attending the Moto Guzzi tour in California next week?
mznyc replied to mznyc's topic in Meetings, Clubs & Events
Just got back,...HOLY SH!TT that was an amazing trip and I have been on many.That bike is incredible,will do a review of it with a summary of the tour at some point.Can not stress how well organized and fun the tour was and everything was first class.Incredible value.They also offer these in Europe.They lose money on these and approach it as a promotional tool to get the brand into the public's eye and offer a discount to all attendees if they decide to buy one....I am a solo rider and fiercely independent so would never consider an organized tour,usually solo or occasionally with 1,2 riders I know well and trust but this soo good and a steal of deal I would do it again and again...Oh and Docc,...you may get your wish...shipment of V100's are due in Dec and "The Experience" has first dibs before dealers... -
Just for reference,I addressed notchy shifting and false neutrals,with replacing single plate clutch to twin plate,changing spring and opening pre-selector assembly numerous times (spring had already been updated with newer spring) and multitude of control adjustments ...nothing made a difference,for yucks,took a whole pre-selector assembly off a complete transmission I bought cheap,just in case,and she shifted like new.maybe reassembling old pre-selector unit and greasing and checking for anything amiss may make it good again,but it hadn't been touched and went from proper shifting to bad shifting in a short period,may be worth keeping it as a possibility something may be slightly out of spec in there...
If I waited for the MGS-01 Experience I'd never go anywhere,...it's about the ride,riding a new generation Guzzi is a plus bit not necessary....Although you live near the best roads in the East,Cali is the best of the West and best weather of the year for them! -
So would it be safe to say you're not going Docc?... https://www.motoguzzi.com/us_EN/mg-exp-2022/ -
And similarities to the ugliest modern Guzzi's ever...The Centauro... -
I like what they're suggesting for specs but that jelly mold bodywork is horrid,....Hopefully it's closer to a Norge as it had decent modern lines.... -
Ordered some 5-pin Ormon Form C relays so I'll update them when I get it and do a few local test rides to shake her down,but I least I know where to look if I don't hear fuel pump click...thanks!
These were replaced by previous owner to Dan Pruske's relays(GEI AR4-012-C11S),don't know if that's the latest flavor of the day but they have been reliable...
Pulled relay block,pushed all connectors in on FI relay,didn't to to have much play but put her back together and she's running as she should....I'll have to find a permanent fix as I'm sure it will fail at the worst place.....
Thanks for the tip Docc,it appears to be the backside of the relay board,shake it,press it and she squirts an amazing amount of fuel on the garage floor....I've been lucky so far with not having this affliction,...oh well,...Can't recall who had the best fix/write up on this?...
Thanks Docc!
Working in the shop and dont have manual with me,forgot which relay drives the fuel pump,pump is not coming on,fuse is OK.... My last chance to sort before I go on a work trip for a month or so..... Thanks!
Oh your trying to go the other way,never mind...
My '02 Scura forks had the seals redone under a recall by PO because of leaky seals.While in the shop he had them re-sprung and valved.Also the shock....Best handling bike I've ever owned.Set up for stiff for smooth roads or track and on those it's quite good...The easiest and cheapest thing to do was buy an Ohlins equipped model and have them sprung and set up for you...
I've always heard the late 80's,early 90's 2v motors are the smoothest delivery ,wide powerband rolling off/on throttle,when they went to the 4v they needed to be revved a bit higher as those bikes were essentially their Superbike engne design(I have a 9964v ST4S) and that continued on to the Monster 2v,many look at the Monster SR1000 as the best example of that in the later bikes...Big,buttery,smooth power but FI and more updated brakes and suspension...Would love one!
Yes.
No,clutch has to be pulled in to override the switch
