Over my time riding, I transitioned "sport-touring" from bolt upright, textbook MSF posture to slide over/ knee out Keith Code style . . . The Corbin Gunfighter I put on my café first year GoldWing just served to reveal how heavy that bike was and how compromised its ground clearance. A circumstance that helped spawn one silver V11 Sport . . . [edit: It occurs to me to add that the Sport's handling let me settle on a suitable compromise of the riding postures keeping the knees in while shifting the upper body toward the corner without sliding over on the seat. The factory V11 seat shape is fine me, although I wish mine were firmer.]
Our TPS connector is this Aptiv (Delphi): https://www.eficonnection.com/home/product/delphi-3-way-gray-metri-pack-150-2-sealed-female-connector
Not bad for the TPS setting (within 3.5 mV of the 157 mV target should put the map indexing on the same "step".) The TPS connector is not AMP. I found this out the hard way trying to source replacement seals after I swelled mine with DeOxit. I'll look for that intel and report back . . . As for supporting a V11 to pull both wheels, no matter how you "support" it, use a "chain fall" or otherwise racthet strap to the joists above. This is critical method! Congratulations on the first start-up! Well done, sir!
The connection issue made me wonder if the cheapest fuses use very thin blades to minimize materials and better fuse blades are more robust and, therefor, make better contact. I have also experienced poor connection with females in other aspects, but let's not go there . . .
That's a great description of the mechanism. Thanks for clarifying the image, @GuzziMoto. And, yes, way back in our V11 lore, there is the idea that swapping the seat latch and high idle springs makes the seat easier to remove and high idle lever stay in place better.
Reminds me of @gstallons's saying, "Use a test light." The time has come to test light new fuses before installation . . .
So, just some musings as EICMA 2024 comes to a close. First, thanks to everyone here who has shared images and videos. Most especially our Man on the Scene, @v11_meticcio ! In particolare il nostro uomo sulla scena, @v11_meticcio ! While Moto Guzzi, predictably, did not offer anything new, they did have a spacious and well appointed display. I recall the introduction of the entirely new V85TT as a single bike in a faux desert scene complete with a big plastic camel. Not even a bored-looking girl on the sand. FWIW, I like the Guzzi line. I think it has a lot to offer the broader audience without becoming a clone of the greater market. I see what looks like some nice fit and finish and an admirable effort to retain brand identity. I see Piaggio's "Travel" assignment for Moto Guzzi's brand purpose coming through, yet with a lot of very approachable models for the younger riders as well as those of us that may consider a smaller displacement, lighter and smaller bike at some point. Sure, I am a little disappointed the "V7 Sport" moniker got pasted to a cooking V7 even though I appreciate the brake an fork improvements. Maybe some clip-ons and more "V7 Racer" style rear-sets would have been in order. Without the rubber footpegs that hardly say "Sport." That said, I do like the light blue V7Sport. It has a lot of nice touches and details, IMO . . . I particularly like the V100 Mandello in rosso/nero with the winglets veiled by the graphics. Nice looking bike with the gold accents. "Wind Tunnel ", baby! https://www.motoguzzi.com/en_EN/landing-page/v100mandello-wind-tunnel/
I think it is a cruel hoax to make the fuse link harder to see. That is, after all, what they were designed for. Not counting all of the 30 amp "charging" fuses mySport burned, melted, or charred, I have only "blown" one fuse. It was because of a loose connection on the battery positive side. Seems @LowRyter's new fuse failure is an all too common example of poor quality control in new parts and a seemingly unavoidable state of affairs in the modern supply system. I understand this is a huge impediment to updating the world's nuclear energy establishments. The chance that a defective component, or system, could be installed in the place of a known working component/system is a dire concern in the aircraft industry, yet ever more so in the nuclear arena.
What is the rationale behind these new opaque fuse bodies instead of the older clear bodies that allowed easy visual inspection of the fuse link?
Between the cable attachment and the adjustable contact cam, the high idle mechanism on the bottom of the right throttle body has a lot of adjustability . . .
Yah, I thought about that comparison. If power-to-weight ratio could be an indicator, the GB is about 75% that of the V11 and that new (heavy) RE 650 is about half. Not sure what all makes this new Enfield so much heavier, but apparently it is. One of the reviewers said, "The Indians like their metal!"
@mikev, the 2000 Sport has a rather soft spring (springs, if you also consider the forks). The original Sachs spring is probably good for a 165 pound rider (in gear) with no luggage or racks. Have you "checked your sags?" If the sag is excessive, it cannot be properly corrected by simply cranking up the preload or increasing the damping.
All that corrosion around the slave could simply be from the bleeder. Or from some prior attempt to bleed it. Might consider cleaning it up and using Teflon tape on the bleeder. After decades (literally now) of discussion over the front U-joint, best access looks to be from the front, coming across the U-joint guard through the shaft tunnel in the swingarm, and downward onto the Zerk (Zerk pointing upward, with the swingarm lowered) using an adjustable angle tip at 90º-ish . . . Otherwise, "You know. Snake Farm " . . .
I have always thought the frame side plates were cast. Not sure if this image helps make that discernible . . .
Agreed, Scud, the frame side plates are aluminum. [housekeeping note: moved this topic to 24/7 V11 for better viewing and archiving.]
