So, "Beetle map" for 1200s and "Meinolf map" for V11? (What do I know, the Poster Child for the factory set-up . . . .)
Interesting take on "improving" the Moto Guzzi dealership network. One thing for certain, there will never be a substitute for the ingenuity and generosity of fellow enthusiasts . . .
The lens certainly looks symmetrical (universal).
Getting creative out of necessity
docc replied to po18guy's topic in Special place for banter and conversation
Nicely done, Sir! Taking time to address the rear axle is good method. Be especially mindful of the right, outboard needle cage, sleeve, and washer between the reardrive and swingarm. These should be liberally greased with a waterproof grease regularly lest the sealing surface of the crown wheel be destroyed. Isn’t it a great feeling to make your V11 better? -
Oh, boy! We get hear some JoeGears!
Every time I look at the way the light falls across that image, I think it distills the basic elements of the V11 Sport: A lot of motor, a shapely way to give it fuel, a clear sense of direction, and a place to hang on . . .
More Black Arts!
What do you call your V11S?...
docc replied to mznyc's topic in Special place for banter and conversation
So, if a bike ends up inscribed, or otherwise tattooed, does that give it its name? -
South'n SpineRaid, ten years ago, the Sport looks poised and ready to pounce. Would that she yet will . . .
@Bbennett, what is the status of the relays on your Sport? I ask because the V11 Relay #5 has to carry 22.5 amps, continuous, to the fuel pump, injectors, and coils. Under-rated relays (20 amp NO) get hot and fail. This shows up, then, as a "heat related" fuel and ignition failure. (I would still make sure there is more than 3/4 gallon of fuel in that tank. A couple gallons and try again . . .)
It is always good to know what makes one crazy. Sometimes, people are crazy and no one knows why . . .
So, that is the regulator. It should remain stationary (no adjustment). The "rod" (circled in green) is open to atmosphere and is typically oriented facing forward. These things don't sound like the issue. Interesting comments about fuel line failures. Maybe even fuel filter? Or fuel pump failure? No way it could be an under-rated relay failing in Position #5?
" c. 3 days ago fuel tank drained*, new fuel (from working Honda bike) added. I was careful to get fuel into both lobes of tank - me not being sure which side sucks the fuel. Still, the fuel tank is not full. I would estimate there is only 3/4 of a gallon in the bike. d. *When tank was drained it was removed. Upon installation of the tank I turned the rod on right side all the way counterclockwise (see pic). The knob on the left is fully turned clockwise. ***Is this correct?*** Elec connectors were mated under tank as per usual. " Regarding your "c", above, my testing indicates the right lobe will trap 3/4 US gallon of fuel in the right "lobe." Perhaps you will benefit from adding another full gallon of fuel. Regarding "d": 1) Fuel is tapped from the left lobe through the petcock. Your manual petcock is visible in your first picture and the knurled knob on its bottom should be turned fully on (counterclockwise looking up at it from below). Make sure your left side petcock fully open (counterclockwise). These directions are as if you are looking up at the petcock, so the arrow direction in your image looks correct, but worth verifying. 2) I am having trouble understanding what you mean by "the rod on the right side." What is pictured in your second image is the regulator with the fuel line that returns unused fuel to the right (trap) lobe and should not be turned. Can you clarify what you turned on the right side?
Simply to plug the vacuum tap. After removing mine repeatedly too many times, the threads became damaged. I went back to the brass nipples and a cap (silicone caps hold up better than rubber).
- 123 replies
- 1
- v11sport
- maintenance
(and 1 more)
Tagged with:
It occurs to me to ask @Bbennett: original, early electric petcock? Not yet converted to a manual petcock?
For myself, I don't think I've ever had a moot pint.
Nicely done, Sir! It will be awesome to hear what you find after simply baselining the TPS and zeroing the CO Fuel Trim. Balanced the throttle bodies? (I was thinking about Meinolf's map while riding just today . . . )
- 123 replies
- 1
- v11sport
- maintenance
(and 1 more)
Tagged with:
Haha, well Moto Guzzi doesn't use many security ties for the harness and such. I see this little rubber tie on the clutch side to gather the various elements . . .
If it is the relay, there will be other signs on that circuit: headlight, brake light, horns, warning indicator lights. Even compromised charging. Regardless, high quality, high current "best" relays are worth the pursuit.
Good point about the revs. As much as pushrods and air cooling, isn’t the low revving motor part of the cruiser purpose statement? When I demo rode the new big Indian, I kept hitting the rev limiter (no tach). Finally, I figured out to put it in sixth and “lug” it. It was, then, perfectly at ease.
Welcome, Alfacity ! You are in the right place to “enjoy the ride better!” Here is a great starting point for running issues:
I suppose I must perform another session of epoxy reconstruction surgery on my original, but it is certainly showing it's been on the leading edge of these miles/kays. Thanks for keeping me in mind if you spot one or have one taking up valuable space . . .
PM sent @bbolesaz
