    1,085
  1. I know this may (or may not) be thread drift, but this is, far and away, my most cherished US South'n accent of all time:
  2. "Distinct cultures separated by a common language."
  3. Simply open the image -> "open link in new tab" -> "copy image location" - > paste into post:
  4. Wait . . . that's right, this is the future . . .
  5. Hey, so 72suppo, what year/model should it fit? Early V11 (1999-2001) are 4.5" wide and mostly silver (There were black ones on the 2001 Rosso Mandello). Later V11 are 5.5" and came in various darker variations of grey and black . . .
  6. Choose, well, your "Social Distancing Tools" . . .
  7. The Stelvio does not have a US plate, but the lad's calves aren't big enough for it to be the Scottish coastline . . .
  8. Worth inspecting the gearbox input hub for failure of the safety washer ?
  9. Blueboarhound shared this with me pretty early on . . .
  10. You're just buttering up our Chief Whip!
  11. docc
    New tank questions
    It really has been surprising just how tightly packaged the V11 is. To fabricate a fuel tank (or install a V10 Hi-cam!) is truly an amazement!
  12. I used a cheap laser level to alignment my Sport's swingarm Not really sure how to rig that for Zooter's frame check . . .
  13. docc
    V11 Tenni
    Thank you, Sir! Just trying to contribute the outstanding documentation so others can put this to good use. Here is an image of the steel flywheel with the toothed gear/"chain ring" removed: And one showing the steel flywheel in the upper right:
  14. docc
    V11 Tenni
    Good image of the rear aspect of the clutch assembly and "toothed gear." The flywheel is not visible from this side (correct?) as the clutch resides inside of it and the toothed gear/"chain ring" bolts to it.
  15. docc
    V11 Tenni
    These are great images, yet I was always confused by my misunderstandings until I got it all apart and realized my history with cars had me confused. If I am correct the image above is the front of the actual flywheel that mates to the crankshaft. The toothed ring/"chain ring" that is turned by starter is mounted behind this and is not the actual flywheel as in the cars I have been accustomed to. Perhaps fueling my confusion, the flywheel is not numbered in the parts diagram for the clutch and is not actually considered part of the "clutch" assembly : The flywheel #19 (and "chain ring" #22) is, instead, shown with the crankshaft and piston/cylinder assembly: It probably has not helped that we have so often stated concerns about failure of the "single plate clutch" when, in fact, the clutch does not fail but the aluminum flywheel that was used with it on the Rosso Mandello, Scura, and Tenni that is the singular fail point. [Just a wee stab at some clarification for those that may be wading through our discourse. ]
  16. docc
    New tank questions
    A long known field expedient for a blocked V11 tank vent is to simply pry out the rubber seal (it's not exactly an "O-ring") on the bottom of the cap which, essentially causes it to vent "normally."
  17. docc
    V11 Tenni
    Really? All those random spaces are to be expected? What a disaster.
  18. docc
    V11 Tenni
    Ouch, buddy! That hurts just to look at . . . So, even though it looks like ferrous "rust" on some of the images, and a different metal interface at the front, the entire ("single plate") flywheel is aluminum? Should be totally straightforward for concerned owners of Rosso Mandello, Scura, and Tenni to test their flywheel with a magnet through the timing mark viewing port . . .
  19. docc
    V11 Tenni
    So, it appears the nefarious "aluminum" flywheel really is bi-metal with the flanks/sides steel and the friction surface and attachment points to the crankshaft aluminum (?)
  20. docc
    V11 Tenni
    Okay, how about the magnet test? (Not on the starter teeth, but on the side of the flywheel in front of that where the TDC marks are)....
  21. The fuse block will actually pry up out of the rubber insulators without using the fasteners. A little at a time, back and forth between them.
  22. docc
    V11 Tenni
    Hmm, true that. I don't know why I thought that part of the flywheel was steel, while the friction surface was aluminum. Now that seems like such an implausible notion. Anyone with an original single plate flywheel (Rosso Mandello, Scura, Tenni) willing to put a magnet through the timing hole?
  23. docc
    V11 Tenni
    It rather surprised ,me when I took my V11 clutch apart, that the toothed plate that has the teeth for the starter to move is not actually the "flywheel" (like the old American V8s I am used to). The V11 "flywheel" is actually really deep in and anchored to the back of the crankshaft. Pretty sure there is no way to get a magnet onto that surface (?)
  24. It's the SPOrT-1100/V11 DrJohn/Crane cam, no? And the compromise to make sure the valves seat long enough (loose enough) to cool through the seats? Early, tight (US?) valve clearances were more about noise control? Certainly not about longevity. P.Roper rightfully noted that the looser the valve lash, the less the lift and duration from the cam. Lower performance (?) Trade-offs!
