    1,086
  1. Sounds like Relay failure, but she'll love you back for some extra attention to the charging system. In addition to High Current Relays and conditioning the battery, inspect the 30 amp (green) fuse for signs of heat damage, be sure there is a ground strap from the regulator to the engine, and that the battery terminals are clean and tight. Same goes for the main ground to the back of the gearbox behind the seat latch . . .
  2. Hi, Tim! Welcome to the best place in the Universe for care&feeding of a V11! No tach + no charging = Relay #2 (from the front). You can try swapping the relays around and using some contact cleaner on the connections, but swapping in a full set of "Best relays" is highly recommended. Best Relay Also, what battery did you install? Even a new Hawker Odyssey PC545 (OEM) benefits from "conditioning." (Think: charging with a particular method): Conditioning the PC545
  3. Remember, y'all: "garage space" is extra, but we can put two or three Guzzi in one of those spaces.
  4. Roger that: Sept 6-8 (Weekend after the US Labor Day) . . .
  5. " . . . or whatever that small bulb is called? " The small 4 watt bulb in the headlamp bucket id the "city or parking light." Comes on with the tail light, instrument light circuit with no relay, and the ignition switch Park position with the steering locked. "Euro" switchgear allows for the Hi-Lo beams to be turned off (in the "city") while the tail/ 4 watt lamp and instrument lighting stays on. Not sue who else got that left hand switchgear, but not the US.
  6. Hoo-boy, now we gots the Greenies crowing...
  7. Official capacity is 5.8 US gallons, as I recall. I’ve never been able to fill more than 5.2. Looks like your station’s pump could use a calibration...
  8. Just what do "telescoping gauges" look like? Never know when I might get the opportunity to "measure hole ID's" . . . I just wanna be ready if the circumstance pops up . . .
  9. Probably a good time for a South'n SpineRaid roll call . . . No reason to plan "TechSessions", they typically present themselves a capella ("in the chapel"), but could arise: allegro, vivace, or even > PRESTO < !!
  10. docc
    Resurrection
    Loosening oil filter = use quality filters (no early UFI !) and tighten 1 1/8 (one full turn plus one-eighth) turns past oiled gasket contact. The WIX have not failed me, tightened to that derived spec. (Much tighter than my intuition meter would have suggested . . .)
  11. docc
    Resurrection
    Gotcha. A noble venture to resurrect a fine champagne V11LeMans! For parts, I am dancing between MGCycle/ Wisconsin, Harpermoto/Missouri, and AF1Racing/AustinTX There are also a few V11 being broken here in the Classifieds and more on ebay . . . We're wit'cha, bud!
  12. We forum veterans have to pull together to reduce every alibi Al could invoke to miss another Sputh'n Spine Raid . . . It's just "over the hill", buddy!
  13. I am so busted by my best buds. So . . . I am down to this emoji?
  14. doslemans reminded me to score a room at TheLodgeatTellico since we're three months out from the Fifteenth South'n Spine Raid. An act of hope and confidence on my part while the Sport sits on the lift waiting for parts from Italy. And Missouri. and California . . .
  15. [sign216, I noticed many of your early images in this thread need to be restored . . . > edit: so, lots of images to restore if you various posters would be so kind . . . In the process, I rediscovered how breathtaking this guy's work is: CarbonArt Motorcycle Lifestyle
  16. docc
    Resurrection
    Wow, Nitzge, only now that I got a closer look at your Gallery images do I see that you pulled the pistons and cylinders off! (At least the right side). How many miles on this V11 and what are you finding?
  17. Had it out on a dark road to view beam pattern and projection quality, hi vs lo beam?
  18. Hoping to clarify . . . There are three cables to tune a V11: Lonelec sells the two cables that provide OBD II connection from the onboard ECU to "guzzidiag" or other ECU interface software. It is an adapter cable and an FDTI-chipped OBD cable that plug together. The TPS cannot be set in guzzidiag or any other software interface with the ECU. The other, unrelated, harness is to "tap in" between the TPS connector and the TPS (TPS "break-out harness") which is then read with a Volt-Ohm meter to test, and set the baseline millivolts of the TPS to the throttle plate position. I do not recall that Lonelec, in the UK, sells the TPS "break-out harness" . . .
  19. docc
    Resurrection
    As if you didn’t have enough advice already: Tank Off Maintenance Checklist Wheels Off Maintenance Checklist
  20. Seems the V11 is wrought with a plethora of vestigial structures, but little if any forward thinking . . .
  21. How did y'all make out? Such a great area to meet up and ride!
  22. Or were those mount points already on the SpineFrame from the faired SPOrT 1100/1100 Sport-i? From the Daytona, even?
  23. Yeah, it surprised me that link displayed the later "faired" Sport design study from Marabese Design/ June 2000. Luciano, himself, said he designed the V11 Sport in one night, without being asked by any Guzzi management or others; as an inspiration. And he was adamant that his vision was in one color, "monochromatic." Luciano Marabese/ V11 Sport Designer
  24. Luciano Marabese, the V11 Sport designer, is honored!
  25. (Be aware that the early '99-'01 gearshift lever is different from the LongFrame '02+ V11. The early brake lever is ~5/8" shorter, but will still work on the later frames.)
