    1,086
  1. @czakky.. I have several parts left from my "alternate" to pawl arm spring project. If you want to give it a shot, I'll send you what I have and a list of what I don't have to complete this as I did it. This evening I got the last pieces on and all the fluids in. Very short ride around the block. It all seems to be working. Smell of baking motor paint is abundant. The shifting is very nice with the LuckyChuck arm in. The extension spring on the shift pawl arm is working. The RAM clutch is a Very light pull. 1 finger will do it. Shake down this weekend! This totally needs its own thread. Seriously.
  2. Wow! Extra credit on that alpha-numeric translation. E36/7 is BMW's production designation for the Z3 based "roadster." Sadly, I can't find a single place name in my vehicle history, so had to resort to histrionics.
  3. My, my: here it is along with the fabulous *burgundy* . . . from the "2001" catalog:
  4. Yours is the only tank color like that I've ever seen until Amarrache showed up. I remember we talked about whether it was the early V11 Green that had faded. But, no, it is it's own unique color: Clearcoat light metallic lime?
  5. XR7-XR4Ti-V70-328i-XJ-JKU/S-E36/7 . . . No wonder I can't find my way around!
  6. Same as the axle nuts which can be pressed into tool service.
  7. Funny, yeah, me too, but I hear people referring to the parts diagrams like this. Kinda has surprised me, actually.
  8. You can purchase directly from Moto Guzzi? I did a search and couldn't find a MG site (at least in English) that sold parts. You can purchase directly from Moto Guzzi? I did a search and couldn't find a MG site (at least in English) that sold parts. I usually find all I need at MG Cycles http://www.mgcycle.com/or Harpers Guzzi http://www.harpermoto.com/ for oem. Harpers has a fiche as well. There are other vendors too I recently had great results with the parts website at MotoInternational in Seattle, Washington. Shipping to you, down the coast, should be very reasonable and fast. I have learned to place the order online and call a few days later for verification of availability. I have found it super-helpful to have downloaded the correct parts "fiche" for my V11 and use that to divine correct part numbers from the assembly diagrams.
  9. With a big, silly grin.
  10. That's correct. Specs are here: "Decent Tune-up" http://www.v11lemans.com/forums/index.php?showtopic=19610
  11. yep. Ostensibly, if you removed one Torx fastener and replaced it with a hex drive with the same fastening torque, then did the other, the TPS would end up *purdy close* to where it was before.
  12. What is the list of the "full set of parts" you installed?
  13. I can bring the cables if someone can bring a computer device with guzzidiag. Anyone hoping to baseline their TPS should replace the Torx fasteners in advance. Of course, that would also require setting the TPS. So: Catch 22
  14. docc
    Decent Tune-up
    So, Q1: yep, dark pipe exits are normal. Q2: Yes, baseling the TPS and zeroing the CO address this in their own special ways. Absolutely worth doing on any V11. Q3: This ECU uses various sensors to approximate the outcome without oxygen sensors. Others can explain this better than I.
  15. Originals are 5000Ω. The resistor tips on the early Champion items come out of the caps. If the NGK are like that, you could simply make up new 90º tips on your ignition wires and insert them into the rubber caps.
  16. Your tank is probably fine. Especially if the coating was applied early and accurately. Nastiness trapped in the Nylon pushes the paint up ("bubbles"). Really obvious.
  17. Seriously, a V11 is like a musical instrument. You'll never be *finished with it*. And that's a good thing!
  18. Open to atmosphere. No connection. Last question about the V11? Hm . . . Seriously, a V11 is like a musical instrument. You'll never be *finished with it*. And that's a good thing!
  19. Suggested TechSession: > Navigation Get there Find your way around. [GPS, SmartPhones, maps, chart books, following, or dead-reckoning. How do you find your way around?]
  20. This is the recent cost from MGCycle, Wisconsin, USA, for the "5speed" unit. For those looking to replace the scary flywheel of the Guzzi single plate clutch, this looks to be a worthwhile option to consider. Only the clutch pushrod must be machined to narrow the engagement end. Some discussion here: http://www.v11lemans.com/forums/index.php?showtopic=20037&p=223099
  21. RAM clutch $535US includes the replacement flywheel.
  22. I've only ever seen one other V11 that tank color: gstallons So, white face gauges?
  23. First thing: fuel level sensor: left side , forward position Second image: fuel regulator, right side of tank. Sorry, one more. I didn't pay attention to the arrows on the fuel filter indicating direction. I assume that the flow is from higher towards the gauges flowing down to the rear of the bike? Looking like an "early" fuel tank configuration (external regulator). Does the tank have a chin-pad and the fuel pump is outside the tank?
  24. When I said something about a RedBellySport, a good buddy said something about Woody-the-Farking-Woodpecker . . . How about a flame red fairing?
