And the reset button instead of the twist knob:
Trading up to these for the cable assembly . . .
Rear brake binding and master cylinder Brembo PS11
docc replied to Jez2561's topic in Technical Topics
It's one of those systems that if each of the five or six things mentioned is a bit marginal, it all adds up to a significant problem.- 28 replies
- 1
- Brakes
- Rear brakes
(and 2 more)
Tagged with:
Plus, the pads slide on a single pin that rides in the road spray, especially if the plastic protective cap has gone missing. The pin gets awfully nasty, corroded, and can even develop grooves that can cause the pad to drag even if the piston retracts. Make sure the pin is clean, polished with something like 600 grit wet-dry paper, and lightly coated with silicone brake grease. The careful (nipple up) bleeding, overnight brake application, and thoroughly restoring the even piston motion are also all necessary, as well as fettling the activation at the master cylinder as have already been mentioned.- 28 replies
- Brakes
- Rear brakes
(and 2 more)
Tagged with:
Correct, Tail Light is on with the Ignition Switch; Brake Light on with either of the front or rear Brake Light Switch. Cdogger, could you restate what the filaments do 1) ignition on, 2) front brake applied, 3) rear brake applied?
Depending on how it has been stored, it may be worth closely inspecting the wiring for rodent damage.
Gearbox plug came today complete with O-ring and thread protector. Nice polished finish (better than pictured in the part reference). Just under $10US shipped from Illinois, USA. https://www.zoro.com/parker-hollow-hex-plug-m16-x-15-metric-vsti16x15edcf/i/G5007764/?q=G5007764 Very tidy! Now to pull the tank and fish out the cable housing.
maybe I missed it but that's a dang nice replacement. About as close to the original that I've seen. I hate to ask if you already posted Docc but did you list the order options for this? It would be a great reference for the next guy wanting a replacement. I would want the exact same thing. So, I think I ticked every box and added every possible option. The final faces are the result of five proofs benefiting from a series of printed mock-ups I used to refine the design. Josh, and Goofman, and my son with the V7 café helped immensely through the design process. I'll post another summary when I get the wiring done . Not including the various fasteners and other materials for the mounting, the Speedhut cost made it to $559.90US.
I'm about finished with the mounting. I decided to retain the gauge "mount" cover (the black ABS "cups" that house the leading edge of the gauges as well as the wiring for the warning lights.) Because the Speedhut connections are more like audio equipment than what I would expect of reliable weatherproof motorcycle connections, I closed up all the mount/cover openings using trim plugs and polystyrene plate, affixed with JB Weld epoxy: I used the mounting for the warning light receptacle to reattach the mount /cover by chasing the sleeve threads and using it as a pattern to drill three new holes in the mount/cover for M4 x 50mm machine screws inserted from the front: The gauges themselves are located ("indexed") with three M5 set screws tapped through the ABS gauge cover, and a pair, each, of 3 1/8" ID x 1/8" round section Nitrile 70 durometer O-rings [ if I had more patience/time, I would have sourced rectangular section O-rings rather than the round section ]: Next, to divine the wiring in order to minimize the number of connections and excessive lengths of wire. Even with the shortened wires I specified, there is twenty-five feet of wire and seven connectors. (Without using the dimmer).
That's just beautiful: both the prose and the photo . . .
Not sure on your relay order, front to back?
Wow, Dale! What a looker!
Pretty sure all my Wants&Warrants in Arkansas have sunsetted . . .
This is one of those questions that, over time, prompted me to divine the "Decent Tune-up" from so many years of so many people working at sorting out these issues. It is a "baseline" that should be performed before changing cross-overs, adding "PC" devices, re-mapping, and the like. Is it the end-all and be-all and final word? Not at all. But it is a solid, well derived starting point. I didn't make it up, but assembled the procedure as a compendium that should be approachable by most owners with a computer, a volt meter and some gumption. Just add gumption!
I'm listening . . . I love this plan; could be the first *Spine Raid* outside of the "South'n" Spine Raid held on the TN/NC (USA) border since 2004.
She's likely wired just like an early V11 Sport. The last relay (rearmost) in the row is overburdened (coils, fuel pump, injectors). Can you hear the fuel pump prime when you cycle the Run Switch?
With the key on, do you get 12v at the power supply to the coil(s)? There are five relays under the seat?
Owning this *obscure/eclectic* motorcycle for these nearly seventeen years, people often ask who takes care of it? I often reply, "At my *local* Moto Guzzi dealer in Seattle, Washington." (2,500 miles away) . . . But the truth? There's a fellow in Varsseveld - NL that has kept me going all this time . . . Jaap Veldhorst
If the hanger got whacked, then keep an eye on the tab that is welded to the rear "seat" subframe. They can *come from together* . . .
My silver 9th is "2" . . .
The bolt on my bike almost looks like a standard button head. The one docc posted looks like a hex that has been ground so the head is rounded? Yeah, mine is a replacement that I fitted after an *incident* affected my original.
+1 on the grounding concerns. I had posted some photos and a brief tutorial in another thread, but it had some errors, so I'm taking it down. I'd like to get a photo tutorial together on the grounding and pin it or put it in "How to . . ." It's on my list of More Things To Do.
AFAIK, there is no designation in the VIN or tag on the V11 that declares the original color. Now, getting the V11Green correct is another matter. Word is, the code is cracked, though . . . Pretty cool seeing my Sport parked on the Cherohala in V11Green! Thanks for the cheap thrill, swooshdave!
Hey, two Spines is a Raid . . . Go for it!
