Didn't the entire V11 range 1999-2005 stay about $11,000-12,000US regardless of the model?
I see no mention of setting the TPS baseline...
I added you to the list, but it is not hard: just fill in your name, quantity, and location on the list in the Original Post, and refresh the page. No need to even "Sign In." P6x has made this so easy! @FreyZI's "1+" quantity seems vague . . .
Hoping to learn more about the origins of the Moto Guzzi SpineFrame, this publication does not disappoint! All this time, I thought the original Spine Frame was a "Daytona" 8V Hi-cam. Not so! The first SpineFrame Guzzi, the V11 Sport prototype so-to-speak, was this 1987 2V. Also, the first SpineFrame: "Made in America!"
No mention of CO setting, TPS setting, or throttle body balance. Highly recommended baseline procedure:
As of august, 2004, @Paul Minnaert had reported four of these failures. Bad production run? Unknowable. Yet it seems that if the problem affected all of the V11 aluminum flywheels, we would have seen about two failures every year for the last twenty years.
- 30 replies
- 3
No way would I delete your posts. Reminds me of why Don Garlits built the rear engine dragster. edit: https://www.forbes.com/sites/jimclash/2023/03/16/how-big-daddys-1970-wreck-revolutionized-dragster-design-saving-countless-lives/?sh=168d33e25cc9
- 30 replies
- 1
Seems like that sort of thing deserves a topic of its own off in Banter . . .
- 30 replies
- 1
At some point, @Guzzi 1947, a dedicated thread with this Tenni joining your alluring stable (with pics!) would be most welcome . . .
The Wizard is being summoned
docc replied to Randy's topic in Special place for banter and conversation
Watching for new member @motoguzzikc to post his concern, probably in Technical Topics, so we can dive into helping him and getting his V11 Sport alive and well . . . -
There have long been concerns, and reports, of cracking or failures of the aluminum flywheel mated to the single plate clutch on the 2002 Scura, 2002 Tenni, and (perhaps) the 2001 Rosso Mandello. To clarify: it is not a clutch failure, but cracking of the flywheel around its mounting to the crankshaft potentially progressing to separation and extensive damage. Many have preemptively converted their "single plate clutch"/ aluminum flywheel to the V11 double plate/steel flywheel or installed an aftermarket RAM clutch/flywheel unit. Those solutions are detailed elsewhere and may be linked here. This topic is meant to chronicle reports of actual failures.
- 30 replies
- 2
Discussion about flywheel failure concerns archived in this pinned topic: https://www.v11lemans.com/forums/topic/31018-aluminum-flywheel-failure/
For full disclosure, this is what I was after with the increased air gap: my (limited) understanding is that less air compresses less and tends to increase compression at the end of the stroke effectively shortening the travel (a sort of "harshness" toward the depth of the fork travel). Increasing the air gap can contribute to a more linear damping through the travel range. This is likely way oversimplified, but gives the idea. I would add that it is the last parameter to address after correct springs and preload ("sags"/ride heights), oil selection, and damping settings.
Easy to check by carefully prying the fuse block up from the isolator blocks (no need to fiddle with the fasteners) and be certain those four hidden spade connectors are clean and tight (Caig DeOxit® is our friend!). They supply power from the Ignition Switch to the fuses for the fuel/ignition and ECU relays.
Perhaps more relevant from that source, "Pay no attention to that man behind the curtain !" -
I derived this air gap for my riding preferences, combined with all of the other details of my suspension set-up. The fluid volume is derived from the air gap, not vice-versa. But only if you want to use the air gap as an additional tuning parameter. Many would say it is "splitting hairs" for the street. Yet, "the street" is all I gots.
Isn't there a replacement available, new, from Mg Cylce? edit: https://www.mgcycle.com/index.php?main_page=product_info&cPath=135&products_id=141
Factory cartridges. (I'm using Taxxion springs, but that does not affect the air gap.)
