    1,086
  1. Green . . . . black . . . . *silver* (looks like you've got *silver* covered ) . . . Are you going to be a RedFrame guy or a LongFrame guy . . . . . . . .
  2. I'm guessing April and May, here in The States, is going to bring out some tasty options for those afflicted souls looking to hook up with a SpineFrame!
  3. Did you crank it up and let it *affect* you!
  4. Shoooooot . . . . I saw Emry posted and clicked to see The Answer. Aw, man, I hate it when this is the answer:
  5. Heh - I *know a guy* who could build a Go_Winkie app for your mobile device . . .
  6. Wot?!? No Go_Winkie ?!?
  7. Yeah, good points there, man, as usual.
  8. It's hard to fathom that casting a dedicated piece, applying a finish, and pressing bushings into each end would be any cheaper than a length of round stock with two Heim joints installed? I had always had the impression it was done as a matter of *style* . . .
  9. Occam's Guzzi !
  10. Speedhut has been spectacularly professional and patient with me while I have re-refined the face designs. On to the actual build now, then to the installation. Thanks to all of those who have gone before me! Kiwi_Roy, Scud, chamberlin, gargoyle, callison, mjptexas, and moto fugazzi!
  11. I just added two relays to my EV's headlights and they are now visibly brighter. Would my '04 V11 benefit from the same setup or does it have a dedicated headlight relay already? TIA No dedicated headlight relay on your '04. Lots of owners have reported brighter headlamps with fused power to a dedicated relay, grounding headlights back to the frame or block. brlawson just got the components and materials from EasternBeaver to do this. http://www.v11lemans.com/forums/index.php?showtopic=19803&p=218190 I decided to use separate relays and grounds for the hi and lo beams, but I'm a certifiable nut case. Of course, everyone here knows that already . . . .
  12. Oh, right! Maybe four variants? Early (40mm) Marzoc's could have the axle threaded into the left fork leg or through bolted to a lock nut. I had thought the later 2003-2005 (43mm) Marzoc's were hollow, but forgot all about the Öhlins!
  13. But is it "a proper Jaaaag?"
  14. "Racing" . . . "Kevlar" . . . "Teflon" . . . ."Chromoly" . . . "ulrta high perf" . . . Man, that's all the food groups right there!
  15. You must have a hollow axle?
  16. I found moto fugazzi's 2013 post showing the valve. Check it out: http://www.v11lemans.com/forums/index.php?showtopic=18186&p=193003 And guzzimoto's explanation here: http://www.v11lemans.com/forums/index.php?showtopic=18243&p=193842
  17. Seems like when I replaced my breather hose there was talk of a check ball, but mine didn't have it and no other V11 owners reported one. I think I saw it in a diagram, so maybe the 1100 Sport/ Sport 1100?
  18. Again, why not use the check valve common to other Guzzi big blocks? And why was that eliminated from the V11 anyway?
  19. Did not pre-V11 big blocks have a check valve in the main vent? Is not the same thing?
  20. Is that a "Quat-D" ?
  21. docc
    Remap
    Uh, I don't think you can be "off-topic" in your own topic . . . Probably the best cross-over thread ever, by Greg field, here: http://www.v11lemans.com/forums/index.php?showtopic=11564&hl=mistral
  22. docc
    Remap
    If you connect guzzidiag and find your CO Fuel Trim set at minus 27 to minus 50 or something like that, you'll be spinning your wheels for a long time unless that gets corrected. Same with the TPS baseline setting.
  23. docc
    Remap
    Have you performed the "Decent Tune-up" and observed/set the CO Fuel Trim and balanced the throttle bodies?
  24. Aaaaaah! "Champagne!" That explains it!
  25. Ha, so . . . "lounge bikes" are all good if you can roll up some serious time on them . . . l love the "lounge room" moniker. Not sure why . . .
