Maybe an MSF Rider Training Course in the spring (might be good to register now, they tend to fill up fast). Good stuff!
That's good advice. I had relieved my original seat, but am using a replacement now and not sure about contact with the connector, so maybe it's time to do this. I left it connector up for year so I could back probe the computer to set the TPS, but with the Caspers Breakout Harness, that is no longer necessary! Are the rubber mounting spacers still used in the inverted (upverted?) position?
Thanks, Chuck. Good to know. I didn't even add a terminal end in order to minimize the number of connections. Perhaps this latest approach will hold for a good long time. Alternate Method E !
The terminals are part of a junction block to get the terminal stack off the battery. I added one on the negative side as well. The only terminals I left on the battery are the main cable to the starter, the charging wire (subject of this thread), and the feed to the junction block. "HRN" is the ATC fuse holder for the direct hot to the two separate relays for the FIAMM horns which ground back to the frame bracket that mounts the Fuel Pump. The "silver thingey" is a 10 amp auto-reset circuit breaker for the hot to the headlamps which are switched by a pair of separate relays in the headlamp bucket. They, too, ground back to the frame. (Photo shows the first attempt at relocating the Regulator Fuse).
From the album: docc's sport
http://www.v11lemans...=19672&p=214874 -
Having grown terribly tired of this connection melting and turning to charcoal, without ever opening the fuse, I am determined to get a solid connection: tinned 12 gauge wire soldered to the circuit breaker.
http://www.v11lemans...=19672&p=214872 -
At this point, I am not a fan of "spade" connectors at all. It is worth servicing the bottom of the fuse box where four additional flat/ spade connectors are hidden below Fuses 1 and 2 (ECU and Fuel Injection/coils/fuel pump). The connector to my Fuel Pump/FI fuse was not tight at all. These are the only two fuses that have these extra connections. EDIT: These spade connectors gave me some fits attempting to restart. Two of them did not seat correctly after replacing the fuse block. Fuse One prevented the ECU and Fuel Injection relays from pulling in, then Fuse Two prevented the pump from running. Make sure these connectors are *well connected* if you're having these issues, but the ignition switch and lights are all on.
So, this little green/red wire carries 30 amps from the alternator all the way to the battery? Seems dubiously undersized . . . perhaps it is 14 gauge just going by the notch on my strippers.
http://www.v11lemans...=19672&p=214870 -
Yeah, they had no remorse charging me fifteen bucks. "Cheapest stripper in town!" "A little goes a long way!" "Watch yer eyes!" All this for a tiny homage to Ing. Guilio Carcano that we'll have to get down on one knee to even see. Even then, most everyone will ask why it's still in primer . . . At least if they ask if I've used a good stripper, we can have us a time.
I have the 30 amp circuit breaker in hand. Once "popped" it is 3 inches / 7,5 cm long. Not sure how I'm going to mount it so it has clearance to "pop" and the terminals will be clear of any ground path. The terminals are labelled "LINE" and "LOAD." My understanding is that this sits between the regulator and the battery. Is the battery the "LOAD?" (It is definitely the regulator side that gets hot.)
Just back from the auto parts store where I do a lot of business. Sometimes, it's good to cheer folks up . . . "What d'ya need today, docc?" "I'm here to pick up a stripper. . ." (We got to the "aircraft" part when the howling settled down.
The news feeds I could find did not show anything very exciting for Moto Guzzi. Anyone actually get there and find some excitement at this year's EICMA?
Mmmmmmmmmh ... beeeeer!
docc replied to helicopterjim R.I.P.'s topic in Special place for banter and conversation
Shameless cross-post: -
Haha - I was wondering who was gonna get that . . .
http://www.ebay.com/itm/122215886327?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true
I bit the bullet and ordered the true zinc chromate from Chuck's aircraft supplier. $30US can of spray paint! Reminds me of what a bargain the LuckyPhil/Chuck-Made shift extenders are! I also replenished my handy cans of Alumi-Blast and Diamond Satin Clear from Eastwood (another thirty bucks). Pretty excited about restoring my alternator cover (a mark of true affliction, I know ), but not sure I have the courage to actually paint stripes on my bodywork. I read that the original Gambalungha was silver with unique blue markings. So, now I'm just conflicted and confused . . .
Looking, now, at the Gambalunga/Gambalunghino I see the V11 tank shape and why Marabese insisted on the "pronounced" tail section along with the vestigial number plate. The design makes so much more sense this way (Gambalunghino) than relating the V11 only to the V7 Sport.
http://www.v11lemans.com/forums/index.php?showtopic=19665&p=214825 -
Oh . . . you know . . . . "someone" with an extra spine frame lying about . . . . with a local powder coater . . . Heh - I tried to mock up a photo of a black V11 Sport with that green frame. That would be so cool!
Heh - here in The Deep South, we're fond of saying "tastes like yak" when we're not sure what's being served up . . . AKA: "meat" & 3
Oh - oh - oh , ok, ok , I'm good now. Whew! I did drive about 600 miles once to buy a 1000S with the green stripes. Cash in hand. Got there and #1, the guy changed the deal and jacked the price, and #2, it had a green frame! I was a little shocked by the green frame. Worse by the deal change and came home with an empty trailer. Later, I came to really admire the green frame. And only now, waking up from Scud's-own-nightmare, can I see a black (black), ahem: BLACK V11 Sport with a 1000S style green frame. "Someone" oughta do that: a black V11 Sport with the gloss green frame of the 1000S . . .
My RedFrame? The RedFrame on my Sport? Yer talkin' about my RedFrame? You must be . . . it's the only RedFrame I have . . . Make my RedFrame green? I'm havin' nightmares and I'm not even asleep . . . a green RedFrame . . .
