Registration here in Tennessee, USA, is on the month anniversary of the first registration of the vehicle with the current owner, usually the purchase date. This spatters my registrations rather randomly through the year. While it spreads the payments out, it also makes it easy to miss a renewal. One of the games we play when a bunch of bikes gather is to look for whose registration has dropped. It is always somebody. Also, here in Tennessee, a 25 year old vehicle is eligible for a one time, permanent "antique" registration. Special use restrictions apply (not supposed to be commuting on a daily basis etc). Next year, mySport is eligible.
The caps on the later V11 are NGK 5,000 Ohm resisters. The early V11 are Champion. I get mine from a scooter shop in England. Because they can be damaged (along with the sparkplug) in even a light tip-over, I carry spares in the monkey paw trap.
I am curious about the need for a remote preload. The Öhlins on mySport has one, but once set I never moved it again. Yet, I don't switch back and forth solo and pillion. Plus my pannier load-out and riding gear change very little. Perhaps a fresh rebuild and proper spring might be all you need?
The sticking gasket from the old filter is real and should be check each and every filter change. "Hand Tight" may have applied to external automotive filters, but is a formula for disaster on a V11 . . .
To take that a step further, the box section spine frame serves as a separator with the liquid fraction draining through the spine into the braided line that rejoins the oil sump at the back while the vapor fraction enters the airbox to be combusted. Or just gunk up the airbox . . .
ANSWERED Twentieth (XX!) South'n Spine Raid 2024
docc replied to Admin Jaap's topic in Meetings, Clubs & Events
Haha! Yep: -
Truth be known, I am holding a room for our Chief Whip in the event he can be our honored guest at this SSR XX. At some point in the SSR past, another member promised "a handful of Cubanos ." I suppose they could stay in the room and when the innkeeper inquires about the potential improprieties, we can say, "The Dutchman flew! and the Cubanos are nowhere to be found !" Okay, okay - the actual Cubanos: -
Also, be aware this vent hose can be abraded by contact with motor parts . . .
In spite of carrying various talisman on my person, and on mySport, at all times, I am not much of a believer in luck. VooDoo, sure, but not "luck" . . . "Synthetic" oil runs the gambit of claims and allowances. Good luck finding out what the actual base oil is on your motor oil of choice. There are but a very few actual Group IV/ Group V base oils. That true, full synthetic motor oils do not suffer the heat-evaporative losses of other oils might suggest a lesser load on our crankcase ventilation and less stress on this failure-prone hose. Of course, very humid environs, storage conditions, and even tuning status (too much fuel load?) all contribute to what this crankcase ventilation hose has to suffer from . . .
I also wonder about the motor oil in use affecting the longevity. "Mineral" oils have a significant heat-driven evaporative component while true synthetics (Group IV and Group V base oils) do not. I did change my hose while fighting various oil leaks, I saved my take-off as it was not faulty. That was at about 100,000 miles/ 161,000 km.
I have always liked the last gen red LeMans. While actually not "Termignoni pipes", they are nice Titanium canisters. Replacement foot brake lever could mean a wee tip-over in the history . . .
My engine is pinging when loading it, above 4000 rpm...
docc replied to p6x's topic in Technical Topics
Pretty sure, yes: "All 15M in the USA." Not sure I have ever heard of a "2006" V11. Or even a 2005 in the USA. I was thinking the 2005 Scura R was the last of the breed, but have never heard of one of those in the USA . . . -
Ah, yes, the "tip-slosh" replenish. Been there too many times. No way I can go 200 miles. My safe refuel is closer to 160.
Well done, @Cabernet! I am honoured at the "thank you." Pretty sure my thermistor's use-cycles and hours have made it less responsive. It has become less of a "low fuel warning" and more of a laughing crow cawing, "You've Run Out of Fuel, you dolt !"
Just got word of four rooms left at The Lodge . . . -
Seems a 1.5º chop on a Centauro frame would make 25º?
Perhaps @Meinolf could answer the "Status" question regarding guzzidiag . . .
I can only recall one member here using a 150 on the 4.5" rim. Last year I had the unique opportunity to see three early V11 Sport parked next to one another with three different size rear tires: 160, 170, and 180. The angle of the sidewall looked most natural with the 160 while the 180 looked decidedly stressed.
The non-start issue certainly deserves a thread of its own, but regarding guzzidiag, check your model selection in Preferences and select your model. It looks like you may be set the "MDS-01" . . .
