    1,123
  1. Look at where the two bolts clamp the assembly to the bar and see if the clamp has been turned upside down with the mirror mount on the bottom...
  2. Just make sure it has not gotten "sloppy." Check the pinch bolt on the shaft of the gear box, the lock nuts indexing the Heim/Rose joints, and wobble at the lever pivot. The lever pivot bolt may benefit from shimming (mine has a couple of times). There is an inboard lock nut that keeps that pivot bolt from turning. Look at the relative angles of the parallelogram and adjust as necessary to get as close to get the gearbox arm and the shift extension arm parallel. The lever has more apparent travel between certain gears, so check that it is not fouling anything above or the Frame Side Plate (below) in each gear change, up and down.
  3. Well said. Thank you, Lucky_Phil . . .
  4. I mean, how many times can we kick something with so may connections up and down over time before the "kinetic chain" needs attention . . . I have seen V11 with this series of fasteners just rattled apart, simply needing a good fettling, tightening, and lubrication . . .
  5. Next, I would adjust and make tight the entire external shift mechanism. Best done with the starter off. Make sure the shift lever does not hit anything on the full up and down strokes in every gear. That is best done with the rear wheel suspended in order to rock the wheel a bit to get it into each gear.
  6. Here is the thread where you posted this issue before, @LowRyter:
  7. "A picture is worth a thousand words." Something about this says it all . . .
  8. As spine frames go, the Dr. John version of the Daytona and SPOrT 1100 certainly brought an elegance to the otherwise clumsy origins. Whomever redesigned the "frame side plates" into the fabulously luscious stilettos of the Centauro, 1100 Sport-i and our V11 Sport/Le Mans variants really iced the cake, IMO . . .
  9. Of course a busted, leaking fuel pump needs replacing . I would so still *tap* on that regulator to "free it up" with a wake up call . . . Once all hooked back up, maybe cycle the pump repeatedly to flush the return line back through the regulator into the tank. If the right side of the tank residual fuel has "gelled" maybe a tank flush?
  10. An excerpt from Matt Compton's mgprotos.com: (also written by Alan Cathcart) . . . https://mgprotos.com/dr-john-rides-again
  11. Motoitaliane informed me they are sending me their new Dr. John book in March. I am even more looking forward to reading the interview with him from just a few months ago . . .
  12. Oh, yes, we have discussed this before. While (IMO) much credit is due Dr. John for the spine frame development, and production, the origin is another matter . . .
  13. A non-issue with the early V11 Sport with the external tank like @Gmc28's Greenie. Yet, still a valid way to depressurize the fuel system.
  14. Oh! Wait! Non-sparking!
  15. Good you had a look at the venting. That seems to be in order and in original specification (charcoal canisters). I can't imagine tank venting being the issue here, but a stuck regulator? Yes, how would that be tested?
  16. Collapsed/ clogged fuel filter . . . ?
  17. There is this external fuel pump replacement offered by MGCYCLE:
  18. Haha, well "helping with the confusion" wasn't how I should have put that...
  19. 2003 Carryover Sports have been reported from the UK (stewgnu and Guzzimax) and New Zealand (02V11), so not just a US thing. There were some apparent US marketing attempts with the 2001 Sport that gave us the "TT" and the "CF" that mixed the color palette of the otherwise monochromatic early Sport. Audiomick's 2002 LeMans with various 2003 features seems an anomaly . . .
  20. This is the topic post marked as the "answer" and references the pages with the installation details:
  21. Lucky Phil was replying to Audiomick. Mick actually created a separate topic to help with the confusion: Knowing if your 2003 V11 is actually a 2002 "Carryover" will direct your parts searches to the 2002 Parts Catalog and save much grief:
  22. That Starter Relay Harness might address your later generation V11 starting issues (startus interuptus), but not the hot fuse. My final solution was the Aircraft Spruce (Tyco) service relay.
