Inlet valve came loose,anyone heard of something like that?
docc replied to Anders's topic in Technical Topics
That cylinder has no compression? -
Single malt - what are you drinking?
docc replied to Denis's topic in Special place for banter and conversation
How novel . . . wait . . . all the parties round these parts are redneck themed . . . -
I looked, but could not find it. Link?
And looks right racy! Does the cap unscrew and you have to set it down somewhere while fueling?
That certainly confirms that the TPS cannot be set at baseline through the ECU, but requires voltage measurement at the TPS itself. Thanks, again, Camn!
- 61 replies
- TPS
- TPS connector
(and 2 more)
Tagged with:
Wait: "363 of 650?" Rosso Mandello were numbered through 300 and another 300 built but not numbered . . . Scura were numbered?
Eleventh South'n Spine Raid Theme Song: (thanks, Jaap!) http://www.v11lemans.com/forums/index.php?showtopic=18925&p=205474
Sounds the start of a therapy group.
Casper TPS harness came really quickly. I tucked the yellow wire in and added shielded bullet connectors to easily clip on a DVOM, red for positive (nero/viola or purple/black wire) and black for negative (viola or purple wire). Pictured next to my "backprobing instruments" Looking forward to comparing voltages at the TPS to that seen in the ECU through guzzidiag.
- 61 replies
- TPS
- TPS connector
(and 2 more)
Tagged with:
It is member Belfastguzzi that detailed the best threads on this pawl spring business. Search his posts with the advanced searching . . . . the pictures in the thread have likely expired, but the content is superb.
How so very interesting. Is there any "table" of factory map codes? I have the "original" V11 map that Meinolf references (3D02VS9F). I'll be more observant when I scan my "guest" Rosso Corsa of 2003.
- 18 replies
- ECUGuzziDiag
- engine temperature
(and 4 more)
Tagged with:
I love my Tekno panniers! The pannier mounts are susceptible to fatigue and cracking. This is the worst place I've seen come from together: http://www.v11lemans.com/forums/index.php?showtopic=16190&p=174290
Sounds good, David. Those inboard facing threads will be much happier with a full coat of anti-seize thread lubricant; especially since they're stainless . . . These pannier mounts have been known to cause cracks at various points in the mounting brackets and tabs, so look them all over really well.
Seven (+) weeks out and it's time to consider this year's Tech Session. Sometimes, these present themselves un-asked-for. As in, "What to Do with A Crossover Pipe F.O.R.D" or "Relay 101." Others have been by *design* : "How To Put a Case of Ale in the Tekno Panniers" or "How Far Off Center is Your Swingarm?" So, what-next-most? Will guzzidiag run on a SmartPhone?
Thank you, Camn, I feel better about getting the TPS breakout harness to set the TPS baseline.
- 61 replies
- TPS
- TPS connector
(and 2 more)
Tagged with:
If the valve adjustment "loosened" the valve would not reach further into the cylinder, but simply would not open. 5 mm into the cylinder, (I would think) would put the valve into the piston (very bad). It really sounds like the adjusting lock nut came loose (noisy, but no real damage). Just a valve adjustment - no engine tear down. -
I remember Mienolf saying that a voltage drop will affect guzzidiag (I paraphrase deeply . . .) It occurs to me to suggest the (simple) "Wiggle Test" - get the engine temp reading live and begin to "wiggle", and stress, and shove about on various points in the harness and connections looking for a place that changes the reading.
- 18 replies
- ECUGuzziDiag
(and 4 more)
Tagged with:
Since (I understand) you changed the sensor already, there must be some connection issue that is not allowing the ECU (and guzzidiag) to see the correct engine temperature. The technical interpretation of "stone cold?" The engine temperature sensor and air temperature sensor read the same. Otherwise, YSMV (Your Stone Might Vary) Meinolf's first post regarding temperatures (Post# 138): http://www.v11lemans.com/forums/index.php?showtopic=17865&p=204809 And Post# 142: http://www.v11lemans.com/forums/index.php?showtopic=17865&p=205220 I'll be having a close look since I am (finally!) using guzzidiag and have had extensive experience with the Engine Temperature Sensor.
- 18 replies
- ECUGuzziDiag
(and 4 more)
Tagged with:
Jim, Do you have a link to Meinolf's post about the temperature sensor?
- 18 replies
- ECUGuzziDiag
(and 4 more)
Tagged with:
After ordering this TPS breakout harness, I realized that guzzidiag will read both the throttle angle and the throttle voltage. So, I expect that the 150mV TPS baseline can be set using the software . . . Incidentally, I am using the referenced ECS FTDI OBD cable. It took a long time to arrive and it has no LED power indicator, but it is working.
- 61 replies
- TPS
- TPS connector
(and 2 more)
Tagged with:
Jim, is the engine temp only different at operating temperature, or do you see a difference in the cold reading as well? FWIW, mine reads the same running and not on start up (not at operating temp). [ ~24˚C ]
- 18 replies
- ECUGuzziDiag
(and 4 more)
Tagged with:
Agreed with the posters so far. A loose lock nut would be the likely culprit to allow to valve to loosen up. Also that 0,5 mm may be more likely? At a full 5 mm, the valve would not open at all and the motor would be running on one cylinder. Adjusting the valves and rechecking them fairly soon seems to be good method, and hopefully something you would not have to wait weeks for . . . -
I could only find this one (is there another you were thinking of?) V11 rear drive pinion play, March 2010 Otherwise, Robin, that play looks ok to me.
6,000 is great for a rear tire (for me at least - unheard of! ) I like 40 psi in the rear, 35 front - while our tire sizes are different and all that, but the V11 are certainly, well, "rear biased."
