    1,081
  1. docc
    Relay mounts
    Ah, yes, what I thought might be an "E" in a circle logo looks to be Bosch:
  2. docc
    Relay mounts
    Not exactly, but close. Our mounting blocks "dovetail" together, between each, and each has a mounting tab, with hole, on "the back side". I can't get an image that is clear. Looks like: 3 334 486 065 and a logo that maybe looks like an "E" in a circle. edit: Okay, here we go: https://rct-global.com/part/base-to-suit-micro-relay-mountable-bosch-3-334-485-045/
  3. This . . . +1 Ah , yes, a 2002 V11 would be prone to Startus Interuptus . You have good indications to clean/service your Ignition Switch and make plans for the additional @Kiwi_Roy Relay for the starting . . .
  4. That should be a field expedient for urgent intervention. I suppose a relay swap is a reasonable test point to observe for change in behavior. In that case, swap in Relay #3/middle/Neutral as it is the least stressed/least critical (and that circuit has a redundant power supply through the sidestand switch with the stand up). Make certain any relay in Position #1/ Start is 5-pin. Remind me what relays you are relying on?
  5. Ah, beyond GuzziDiag, then, and on to Reader/Writer? Probably time for a separate thread . . .
  6. docc
    wanted
    IIRC, the diameter of the fork sliders changed (increased) between early and later V11, but the clip-on/triple tree clamping diameter remained unchanged. Just from memory: 53mm? Not at all sure if memory serves there, but pretty sure the upper diameter of various V11 forks are the same.
  7. docc
    wanted
    I reckon they would only fit the early V11 Sport/RM mounted below the triple clamp as the early Marzocchi forks do not extend above as the later V11 do. I have a pair of ROX for Andy if he wants them . . .
  8. docc
    wanted
    Hey, @andy york, ping me if you think those ROX would be worth a try . . .
  9. docc
    wanted
    All of the LongFrame LeMans already have the clip-ons above the upper triple clamp, yes? Seems the Mototec can be mounted below, as well. (Which reveals the later V11 fork clearance above the triple) . . .
  10. docc
    wanted
    I've never been very fond of the "Form Follows Function" aesthetic of the MPH risers. I suppose they would just "disappear from the eye" after a time . . . The Mototec are very elegant, on the other hand . . .
  11. I am using GuzziDiag V0.47 with Mac OS 10.13.6 (Kind of afraid to upgrade the guzzidiag version since what I have "works" . . . )
  12. Hmmm, that's an odd one. Never heard that before. For sure the Run/"kill" Switch is on and the clutch lever being pulled in?
  13. Interesting to see just how early-on these springs were discovered to be problematic. Final solution became @Chuck's expertly designed spring available by dropping @Scud a Message through the forum system . . .
  14. There is another way to set the CO directly in the EEPROM that @Meinolf has showed us. I will look for the post. Otherwise, why would your bike not start? Does it make a click or whir at all?
  15. I wish the sound quality were better, and there were fewer ears in the view, but real music being made. "Don't let me down ", y'all . . . Maybe best crowd refrain, ever . . .
  16. Topic title change to show V11 relevance . . . Thanks for sharing your solutions, @Pressureangle and @Lucky Phil
  17. A new record for negative CO !
  18. Downloaded the correct FTDI driver?
  19. No relay for the ignition switch, IIRC.
  20. docc
    Wheels
    Hi, Max! Yes, the wheels interchange. I have even seen a 180 mounted on the 4.5" rim, but it looked mighty "pinched." I hope you'll keep us up on the build!
  21. *moderator edit: Trying to figure out where a Quota thread belongs . . . . Leave it, move it, "Special Banter?" . . . .
  22. Where would our San Fransisco and vicinity crowd do a "SpineRaid?" Modesto? Sonoma? Sonora? Mariposa?
  23. Yeah, the six I got from EFIconnection shipped for $24US. Six (with the grey connector) from customconnectorkits would be $16. More SpineRaid swag . . . "Get There. Bring Tools." ( and parts ) ~ Y'all come, now! Ya hear? ~
  24. Then there is this . . . From that same source the 12162281 black connector is $3.55 each, the grey 12162280 is 99ยข . . . We're only after the seal. Get the grey! https://www.customconnectorkits.com/12162280/
  25. Yes, sorry, not all of my edits came through. Corrected now (the wrong number is a two wire). 12162182 is the black connector/ green seal, 3 wire. The 12162280 you linked is grey, but correct. And BEST PRICE of all! As always, I just just be more patient before making the order for parts. @Speedfrog will nail it down!
