By "10 lb.", you mean you turn the pins in until you get ten pound-feet of torque on a torque wrench? How did you determine that measure? I could only turn them in til the bearings bound and back them off "a reasonable amount" (maybe a quarter turn or less). And, as I recall, you did your tracking alignment by the glass tube method. I used a laser, but wonder if my pronounced left side tire wear would resolve if I centered the swingarm . . .
That post is "worthless" without . . . .
I had the privilege of tuning another V11 sport today. The swingarm pins were symmetrical (within 0.002"). Maybe mine shouldn't be to the right 0.079" . . . Can anyone else check the depth of their swingarm pins inside the lock nuts with a Vernier caliper and compare side to side?
You're not talking about "head guards" that fit over the plug wire and protect the valve cover? It sounds like you're after the tubular version that fastens to the frame and protects the entire cylinder . . .
My headlamp relays are in the headlamp shell with dedicated 16 gauge wires and separate relays for hi and low. Two years ago I installed my spare OMRONs for the relays. Grounding goes by 16 ga. back to the frame (right side of the spine/ fuel pump mounting bolts. I'll have to do the voltage drop test and report back. Two volts lost is astounding! And, you know, it goes through the switchgear = ungood. I am looking forward to going back to a high intensity bulb (Silver Star or PIAA) since I think my broken stator wire was arcing and spiking the bulbs after 4,000 miles.(The PIAA lasted twice as long, but cost twice as much).
I did not know that the swingarm centering could be adjusted on loops and Tontis like the spine frame's side plate pins. I'm suggesting we can measure the depth of the pins inside the lock nuts for symmetry (or not) and see how off center the swingarms may be on the spineys that we can get our little grubby calipers on. If you come to the SSR and dubious parties are plying you with high octane grappa, it may be that dark forces are at work pushing calipers into your swingarm pins while you are otherwise diverted. Don't say I didn't warn you . . .
My Buell lenses are an outer smoked (Y0039.K) and an inner amber (Y0040.K) which do not require a bulb change. Yet, of course, they are "smoked" and not the original amber outer lens. Mebbe these are just for Scura wannabes like me . . .
Is this fuel pump the right spec? Help appreciated.
docc replied to Molly's topic in Technical Topics
And JB Weld or an equivalent reinforced epoxy (like Devcon) wouldn't set things straight without replacing the pump? -
Good advice here. Notice: no mention of a dyno run. I can't imagine you would need that to get your Guzzi to run right. And, here in the States, I suppose it would add at least $250 to the tune-up.
Roy, nice work! I'll have to spend a little time studying your result. Take this from a guy who rides with Carl's schematic in my tankbag! The diode apparently developed from a problem with the previous generation ECU which would fail if the battery went below a certain voltage, not just that it's polarity might be reversed. I also travel with this "flow chart" for quick and dirty diagnostics: (revised 4-20-2010)
You're right. Crank case vapors are gathered to the underside of the spine frame behind the head stem and the fluid portion is drizzled back to the crank case from the left side of the frame through a braided line. Vacuum is applied through an airbox line to the top of the spine behind the head stock. I am supposing these are the three lines you are referring to. The most suspect is the formed line from the case to the underside of the frame. It has been known to deteriorate and haze oil vapors out. Otherwise, the banjo fittings should be kept tight on the others for a clean fit.
I thought the consensus was that the TPS unit is sealed and cannot be cleaned . . .
In the past South'n Spine Raids , we've taken rear drive temperatures, brake rotor temperatures, re-gapped fussy plugs, and refitted exhaust cross-overs. This year, I propose to measure the depth of swingarm pins and see just who is right, left, or center. Bring Your Own Spine Frame!
So, Pete, you just set them the same on both sides and Bob's yer uncle? After starting from scratch (no swing arm), mine has ended up 0.079" (1.9mm) to the right using the anal retentive over-killer laser method. It is, in fact, little over 1% of the tire's width, but it feels great to be just right of center.
Actually, no. It would feel more like an in-cab garment fire . . . This sounds suspiciously like Guzzimeister's TPS failure. Is she due for a full TPS, throttle body balance?
But where are the marks? Are they now aligned?
I may be the Average Noob of which you speak! When struggling with a running condition a couple years ago, I did not see the jump in mV in the TPS signal, yet when checking it with the Ohm meter, it was obvious that the resistance would lag, then leap. Replacing the unit made a big improvement. I thought it was pretty simple and safe test. Hubert, do you think there is a trouble in it? BTW, Guzzimeister, what happens if you perform the resistance teat on you bad TPS, slowly opening and observing the milliOhms?
We're talking Red Frame Sports here again?
Folks have used the bulb method for a long time. And, all kidding aside, you'll need at least six foot bulbs (eight foot is probably better). I used the laser method, marking the floor. Honestly, I discovered this after I removed my (damaged) swingarm, and had to install the replacement. I had not recorded the original pin positions. And, no, they are not just the same on both sides. After the careful alignment procedure, the bike tracked notably better, and turn in feel was improved. I think I got it closer than Luigi had time for . . .
Oh, durn . . trapped in the old six-inch trap are we? No, no, really, I meant eight feet . . same thing . . . no . . . really
The washer is on my 2000 Sport and is shown in the Shop Manual, but not in the rear wheel reomoval; only in the rear transmission section (Section O, page 4). Of course, it is not necessary to remove the bevel box to change a tire, but it is a good idea at every tire change to remove the right side caged needles, clean and regrease then install them rotated differently than they came out. They do not spin, but have considerable fore and aft load over a narrow range of rotation. They will get quite knackered over just a few needles if you don't move them regularly. And they pick up a lot of moisture and road scuzz.
Hey, just a reminder, the swingarm has to center the rear tire behind the front. There are several methods to do this including using fluorescent glass tubes or a laser. Otherwise, the manual instructs to take off the lock nuts and measure how far each of the threaded pins sticks out from each side. They are not likely the same from side to side. Precise centering enhances stability and turn in feel.
Having Moto Guzzi is like having ALFA Romeo! Those fellows say it stands for "Always Looking For Another!":mg: (Of course, I have BMW: Belongs to My Wife)
