    1,123
  1. docc
    Manual languages
    The first German line is from the shop manual and the second from the owner's manual. I suppose the verbiage between the two manual varies just enough to make the words look puzzling as if these were in fact slightly different languages. I've kept most of the Sport's maintenance records in Italian these nine years. Not that I speak Italian, but the translation has always been on the facing page in the Owner's Manual. It has been fun, although it was pointed out that any subsequent owner may not be so amused! Plus, my wife seems decidedly aroused by spoken Italian. I hope she doesn't find out I've been whispering sweet valve adjustments to her!
  2. docc
    Manual languages
    I have an owner's manual with four languages and a shop manual in three. The Owner's Manual is in Italian, English, French and (I believe) German. The Shop Manual is in English and two other languages similar to both German and French. Could you please help identify some common phrases? With regard to the spark plugs: "KERZEN Das Motorrad ist mit NGK BPR6ES Kerzen ausgestattet, der Abstand zwischen den Elektroden betragt 0,7 mm. " (Swiss?) "BOUGIES De moto is uitgerust mit bougis NGK BPR 6 ES met een afstand tussen de elektroden van 0,7 mm." (Belgian or perhaps Dutch?) "Zundkerzen Zur Reingung und Kontrolle des Elektroden abstands sind die Zundkerzen periodisch zu eintfernen." (German?) I am sorry that my keyboard will not stroke the proper umlaut "u" in "zundkerzen" or the "a" in "betragt." Thank you for your kind help, docc
  3. The new digi-meter could be your V11's best friend! Setting the TPS by mV is one thing, but unplug the TPS and check its resistance in Ohms ( set to the little-Ohms setting [milli-ohms?]). As the TPS is opened , the resistance should change gradually, with no 'jumps.' If it jumps abruptly, the TPS is probably done (even if you 'clean' it like I did). Yeah, mine appears "open" and is currently the HD derivative (still Magnetti-Marelli). The original unit was also "open." I've sealed it with silicone, but will try to get a photo up to compare with what Hubert is going to post from Deutschland. EDIT: Well, no good. I tried for a photo, but it doesn't show much. And, it sounds like the point in question is under the TPS which would have to be removed for inspection. I'll pass: mine's been running too good to muck with.
  4. Stormsedge says he has an '01. I bet it's no different from the Y2K. After that, all bets are off ...
  5. Here's a flow chart I've found helpful:(I keep it in my tank bag window with Carl's wiring diagram) Fuses in blue Switches in red: IGN SW - ignition switch SS SW - sidestand switch N SW - neutral switch R SW- run switch ST SW - start switch (button) CL SW - clutch switch Relays in green: N R - neutral relay ("sidestand" relay) S R - start relay HL R - "headlight" relay "cl conn" are the problematic bullet connectors for the clutch switch under the left ford side of the tank.
  6. The tail light, tag light, instrument bulbs and "city" light (4 watt headlamp) don't run through a relay at all. These get their current through Fuse 6 and the ignition switch (Fuse 4). The turn signals also run off the ignition switch (through Fuse 7) with no relay. I would be suspicious of a connection from the battery or other connectors (under the tank) that feed power from the ignition switch back to the fuse block.
  7. Relays are a good start. I'm a fan of the OMROM from RYLAND. But many have had good results from the GEI from PYRODAN.
  8. Well, yes, in fact, they do bite. But, hey, maybe she likes it . . .
  9. I continue to feel damn lucky my Guzzi runs at all; let alone my stupid Chrysler product. Growing up on the Left Coast of Florida, I've always thought thermal effusivity should be treated with oysters and Margueritas. Then again, "Wiki . . " never asked me . . .
  10. Sure, but look at the price of those Buello Aguilas . . . just no availibillia . . .
  11. Hmm, I'm surprised at no response as of yet. With the side stand up, the switch is closed, routing power to the 'run switch.' When the side stand is down, power to the run switch must come from the relay activated by the neutral switch. This is, of course, called the "sidestand relay" just to make an appropriate Italian confusion of things.
  12. No offense, but have you searched "this old tractor?" Carl Allison has posted some superb work there.
  13. Ride, eat, apply Guzzi fluid - repeat. Scene from the paddock:
  14. Pilots Extraordinaire: Tim and Josh discussing relays, handling and frontal systems. Fine fellows!
  15. I've never seen so many *very fine* motorcycles overshadowed by one finer motorcycle and her rider. It is our loss not to have hosted your Sport and your husband's VFR at our lousy non/rallye-with-no-real-group-picture. Maybe next year! (I'm hearing Tellico Plains, TN, the weekend between Mother's Day and Memorial Day). See you for SSR VI (We'll take a group photo with the VFR in the front!) Wayne, laying on hands:
  16. Stunt parking (ouch). Hope all are home and well. 840 miles for my Sport, including one three mile gravel switchback (Josh is the most patient and forgiving wingman one could ever hope for!) For the record: the hacksaw blade is 0.026". Guzziology recommends 0.023 for the old round head and John with the SP will never be the same after Wayne healed his restart in the motel parking lot.
  17. Team Frontal System.
  18. Lucky bastards! Best of luck to Charlie! America remains too tame for "real" adventure. Maybe in 2015 when we , once again, become a third world country . . . I'm ridin' anyway, docc
  19. Coming in from the west, it looks like four of us leaving the Cracker Barrel on US 412 (I65/exit 46) at 0900 doing 276 ZUMO miles on backroads and byways to Newport. In the past a few folks have holed up at motels at that exit on Thursday night. If you're coming in on Thursday, let me know so some proper hospitality can be arranged. The usual stuff: beer, pizza . . . tires.
  20. The tail light still burns if the light relay is bad. It's on a circuit with no relay along with the 'dipped' light and instrument lights. Kind of a 'limp home' mode. Curiously, if the headlamp, brake light, and horns go out and she will not restart: it is fuse 5 (not a relay). (or the clutch switch . . .)
  21. So . . . that's why those cats won't wave!
  22. My weasel feels better aligned now. But, it aches a little. In a good way, though. . . (Look, really, I used a laser to align my swingarm after the *dumb-ass* crash. And it rides better. Everything you do to these bikes to tune and fine-tune helps. Except the stuff that makes it worse and tosses you into an oncoming 3-series sedan. My bad. I won't do that set-up again.)
  23. I believe this thread is too valuable to have it closed. Ya'll play nicely.
  24. Dad-gum! Rat thar nere the X-on. S'pose the wild girl from Year One at the Super8 in Athens has made bail by now? Looks like her kind of place. . . At least we have Wayne covered. I'm goin' to the Huddle House to suck my thumb and order grits . . .
  25. Questions have come up about restaurants and such walking distance from the Comfort Inn. The folks at the hotel tell me they serve a continental breakfast with 'make your own waffle." Across the street (25W/411) is Lois's Country Kitchen, the Huddle House, Timeout Deli and the Exxon makes burgers, sanwiches and sells beer. Both Audrey's Bar and Grill and the Midnight Rodeo serve food. About four miles east on I40 is another exit with a Cracker Barrel and much, much more. PLEASE NOTE: THE BRIDGE OVER DOUGLAS LAKE WILL BE CLOSED! INTERSTATE 40 WILL BE CLOSED WEST OF THE 411/25W EXIT (EXIT 432) 8 MILES TO EXIT 424. Detours are posted and it should be no big deal. Just a heads up if you're coming in from the west on I40. Bill and I have tweaked the route for Saturday looping north into VA/KY 238 miles. I'll try to print up some maps and directions. If you have Garmin MapSource, pm me and I'll send you the file. Later, docc
