    1,123
  1. docc
    Fork woes
    Thanks for the replies, guys. I guess I'll open the fork and take another look at the oil level. I am considering polishing the outside of the spring with some 600 then 1500 grit paper. Any thoughts?
  2. docc
    Fork woes
    Reading the TD instruction it is emphasized that the retaining ( blue) nut must be threaded on far enough that the cap then bottoms or shoulders fully before moving the blue retaining nut back out to lock the cap. It makes sense that if the cap is prevented from shouldering then the adjuster rods will not be seated. I have renewed my hope that my forks are just low on oil. Must ride this am, but I'll check levels this afternoon. One can hope! BTW, which was the thread with the debate on 'progressive' vs straight rate springs?
  3. docc
    Fork woes
    Certainly possible that the oil levels have dropped and are too low. I guess the spacers and springs have to come out to recheck and correct the oil levels. If the air gap is too big it would help explain why the dive seems little better than the stock springs when the forks were overfilled. The Marz springs are 1.37" and the TD are 1.35". ( and 1" shorter than the stock springs). The original sag was 39mm. I increased the spacer length from 109mm to 118mm to get a laden sag of 30mm. The higher ride height concerned me as I didn't want any increased rear weight bias so I dropped the triple trees 9mm. (I've left them there for now.) I couldn't find that 22mm blue nut setting anywhere. Is that 22mm from the top of the blue nut to the top of the threaded cartridge rod? I tried emailing Todd at Guzzitech but haven't heard back on the polished Hyperpro spring. Again, I didn't think I wanted a rising rate spring. I know it's been debated here before, but I missed the pros and cons.
  4. Jason, Show us how you end up wiring in the relay. I'm guessing you can activate one relay with either switch. I've already added four relays, a circuit breaker and three fuses to the Sport. Surely there's room for one more.
  5. Although the cams have certainly changed. I remember in Field's book Wittner discussing how much went into the V11 cam development with Crane. Yet I have no idea how it compares to other cams even the Sport 1100 or 1100Sporti. I'm going to try to get the strobe on mine today. Should be especially good since mine idles well and doesn't flame out . . . Watching the gear teeth through the window they jump 2-3 mm every 6-10 seconds. No change as it came up to temperature. I'm pretty sure it was fully warmed up after touching my elbow to exhaust. Certainly no 7mm jumps as that would shift the tooth from bottom to top in the window. Ratch, are your marks jumping around constantly or periodically ?
  6. docc
    A sad day today.
    Aye, but, North Carolina? V-twin heaven!
  7. Both switches gone south? That's like your wife and girlfriend both leaving you at the same time. . . Well, it's been known to happen. Poor bastard then, ya . . .
  8. docc
    Fork woes
    I'm looking forward to simply trying a smoother spring surface. I'm sure I've drug some fluid out of the forks everytime I pull a spring out. Next time in I'll recheck the luftkammer and reset. TD spoke to me about the 'WD40 cap measure'. Dan equated this with about 10mm height and the point at which most of us could tell a difference. I haven't yet quantified the WD40 cap measure. I'm not sure I have one of those caps . . .
  9. docc
    Fork woes
    I would think it could be the spacers are out of square, but the beautiful counterbored aluminum spacers that TD sent did it too. I'm thinking more and more it's the nodular surface of the wire material and the ribbed inside of the fork housing. Maybe polishing the spring surface would do it. I've asked Todd at GuzziTech for his input regarding the Hyperpro product. I really didn't think I wanted a 'rising rate' spring, but (obviously) what do I know? I left the oil in the forks that I had changed during the unseated cartridge debacle. Looking at Peter Verdone's charts I'm sure I could do better at choosing oils. This "centistokes@40 degrees centigrade" looks like a remarkable tool for fine tuning. "Thicker" for compression and lighter for rebound, ya think? I'm vague ( does it show ) on the luftkammer. I set mine to 100mm with the froks in the vice. Can it be set in situ ( with the forks on the bike)? With the spring and spacers in place, forks fully compressed?
  10. Having upgraded the rear shock on the Sport to the Ohlins I moved to respring the front as well. Traxxion Dynamics recommended 1.0 kg/mm straight rate springs 1.35"x10.6" with 120mm spacer for my 185 pound riding weight. (Marzocchi spring: 1.37"x11.6") The ride is improved and sag is respectable. With 3/4 tank of fuel: 23mm static/37mm laden. 1)There is still a good bit of initial dive in sudden braking which I thought would be much improved going from 0.65 springs to 1.0. (Although the TD springs come up 0.85 on the "calculator"). Perhaps a stiffer spring is in order? 2)Worst of all, jouncing the front sounds like a squeeky swingset. TD suggested there should be a washer between the spring and spacer. My forks didn't ever have one and I'm not sure I can see how that would change the squeel. The surface of the new spring is quite nodular, or rough, compared to the original which is smooth. I wonder if springs from another source would be 'smoother' and won't squeek? TD offered to send me some 1.1 springs to try. They have been very cooperative and helpful. Yet, I do hate taking the forks apart again and again.
  11. it does sound like a fuel supply failure. Make dure the fuel line from the petcock to the pump is groomed away from the cylinder fins. It may help to move the pump forward in its mount to straighten this line as much as possible. Shortening and even shielding the line are also options.
  12. Those sockets have a reputation for being pretty weak. Once the soft contacts on the bulb wear down from the vibration (which is amplifed hanging at the back of the subframe) the connection is very poor. Seems like I was able to get a probe in the socket and bend the connections out a little. Adding a dab of copper antiseize paste is good. Also, change to a new bulb with fresh contacts. The 'long life' or Euro style bulbs have an eliptical contact that protrudes more.
  13. What does it do when you try to restart? Pump whir? Starter truns over? Clicking?
  14. I thought the Ducati and BMW ( Bosch) replacements are for the pre '02 big headlamps with the steel bucket.
  15. The trick with the blue nuts ( sounds like it would hurt ), aside from being sure they are right side up, is to make certain they screw on far enough that the caps bottom ( or 'shoulder') completely before using them to lock the caps. I also learned from the Traxxion Dynamics excellent instruction package to preseat the rebound adjuster. The handling just keeps getting better. Tonight I did about 10 miles of high speed ( 85-95 mph) cruising past interstate trucks and such. I thought I had the weave sorted well before, but the high speed stability is remarkable with the new shock and springs. Four of my experienced and trusted companions listened to the noise this evening and shrugged saying, "Yeah, sometimes they do that." Sort of the same thing Traxxion said.
  16. Seems like Sarasota would be a lot more pleasant for you to get to than anything to the north. Any luck getting the trans recall certified?
  17. Stunt parking!
  18. It's in both legs. It sounds like a swing set more than a hydraulic component. If my lawn mower made this noise I'd take it apart.
  19. Ahh, yes, Glasshopper, the front glease fitting . . .
  20. docc
    soft bags for V11
    So, Terry, what year/model is the LeMans? It's not a Scura or a Tenni ? A Corsa ?
  21. I'm pretty sure Pete answered Raz that he could just take off the front cover as in post #11. Ratch' , how may miles on yer 'hack? I've passed the 49,000 mark and still holding a steady idle. Could it be that the tensioners and chains need the 50,000 mile replacement?? I don't think it's just the oil that loosens up. All the tensile tolerances in the valvetrain should 'relax' at temperature. Still, the timing mark moving 4-7 mm? That seems like a lot of degrees BTDC. I'm somehow sure you've tightened the timing pick-up and every other simple thing. Does your bike flame out periodically at idle like Nose2winds?
  22. Y'know, everything seemed pretty good before installing the new springs. My old sag numbers were sorted, but required too much preload to achieve. Topping out was too easy. The new springs really don't feel much stiffer, but do require less preload for the optimal sag. They are an inch shorter than the originals and measure 1.35" OD ( original Marzocchi 1.37"). I guess I'm lost on the stiction discussion and how to measure it. Yet, going from the familiar "squeesh-squeesh" before to "scrape-squeel" doesn't sit well with me. I just dropped the springs in and put the spacers on top. Am I missing something???
  23. I tried for the 15 minute fork spring change. Add two three minute sessions of drumming on the practice pad to Pink Floyd and The Police. Add 20 minutes for setting one spacer on top of the spring and dropping the other spacer into the depths of Hell without thinking to put the spring in first. Add 20 minutes to release, and reset the rebound spring for the squeeking-scraping sound when jouncing the forks. Add 20 minutes to discuss the awful sound with TD. Add a 45 minute ride to see if the spring will 'center up.' Add an hour to make PVC spacers only to find the same scraping-squeeking upon reassembly. Another 30 minutes to pour and drain single malt and lament the fate of the mechanically engaged. Should the springs make noise like this? The sag looks good, I think, at 21mm static and 35 mm laden. It rides nice and I can't hear the noise while in motion. But, I am afraid of having bad dreams about stiction and wear and particulates in my fork oil.
  24. Based on Verdone's work using cSt@40C it looks like most of the 'light' fork oil is still too heavy. I didn't like the Maxima oil I ended up with, but it looks to have about the right 'target' value of 16.00 cSt@40C ( actually 15.90). The Silkolene 5wt is rated 22.30. I have ended up with the 'heavier' Silkolene 5 wt in the rebound fork and the 'lighter' Maxima 5 wt on the compression side. Backwards by default? His chart on conventional slow speed damping adjusters is revealing. He shows that the adjustments are more sensitive in the first part of the range while making less and less difference toward the end. My estimation from the chart is that 10% of the 'clicks' is 25% of the damping; 40% of the clicks is 65% of the damping. I'll have to look, but I think I have the rebound adjuster on the fork turned in 75%. Based on Verdone's chart that is 95% of the damping. If I want 75% damping I should only turn in half the available clicks. + =
