    1,104
  1. Is there a famous hill climb or other motorcycle event held there? Also, Jaap, I am curious. How far is it for you to ride to Mandello? My friends and I will soon take a sport-tour to a neighboring state. In three days we will travel perhaps one thousand miles (1600km). My average ride is about 100 miles (160 Km if my conversion is correct).
  2. OK. I admit. I'm I bit in the dark on the "Ballabio' thing. At first i read it was a guy. A champion hill climber. Then I read it was an event. And even a place. So what (who) (where) is b-LOB-io?
  3. The fender chops look tough. But don't the bikes spray a big rooster tail on a wet street? Or has anyone chopped a fender outside of California?( Cuz, ya know, "it never rains in . . .")
  4. Welcome Bill! I've always enjoyed your wit and wisdom on the Wildgoose site. I was rather amazed to see you have added the Billabio to the stable. Enough of that mountain cruisin' - time to get down to some real carving!
  5. Purportedly, one of the original design directives of the Sport 1100 was that it be a tuner's bike. A platform for customization. Look at the Ducati Monster. Is it the longest production run of any Ducati ever? A platform for personalization. I am so hoping the V11s/LM is the "Monster of Mandello." A sound ,long running platform for each of us to personalize, hot-rod, breath on and otherwise soup-up. Parked side-by-side the three or four silver V11 Sports I know of have grown to be nothing like one another. These V11's, perhaps the Sports more so, epitomise the quintessential cafe rocker theme of the early ton-up scene.
  6. for those of us who are prone to riding medium-olderr japanese thingies, a bit more specificity would let us know just how eccentric you may be. Not that it will help get your bar-ends off but just in the interest of comraderie.
  7. docc
    FI Imbalance
    When my sport was first delivered it was very picky about fuel. Sounded like a Jamaican steel drum band on "Shell." Like an Offenhauser on "Amoco." After tweaking the TPS, balancing throttle bodies and jettisoning the evaporative fuel vapor system, I notice no difference between fuels. Which was just in time since "Shell" absorbed "Texaco" and "BP" sells "Amoco" fuels.
  8. docc
    FI Imbalance
    John, Usually setting the CO, the TPS and CAREFULLY setting the throttle body balance is enough to take care of your troubles. Also, be sure the tip-over valve in the fuel vapor system is not suctioning your tank. The whole fuel vapor recovery system seems to work best in a cardboard box. Finally, be sure you run the highest octane premium fuel. Good luck!
  9. Andy, I have the factory manual and "Guzziology" as well as a digital meter and Mercury sticks. Bring the LeMans down to Columbia and let's see what your base line is. Some fanaticaL tweaking and balancing always makes Guzzis happier. :luigi: E-mail me if you would like to hook up. docc
  10. My EBC rear pads just went to metal after 6000 miles. The originals and some Galfer blacks went 10000 each. And I've been consciously staying off the rear brake to avoid cooking the wheel bearing. So, I figure, "the caliper pin needs a lube." But, ,there is no caliper pin! Not only does the disc not float - - the caliper doesn't either! I thought something had to float. Is it by design that these bikes eat their rear brakes? Can they be converted to a semi-floating disc?
  11. The sales brochure for the 2000 V11 Sport also specifies WP rear shock. Sure the owner's manual specifies "either" but you've already bought it by then. Bait and switch?
  12. Evidently the short spacer is common. I remember reading about it in "Guzziology." Time to go back and see what Dave said . . . . I think you guys are on the right track. I mentioned this before but while experimenting with rear braking into corners I cooked a rear bearing. The bike is just happier with LESS rear brake. It won't fix the short spacer or the drag but overbraking the rear will aggravate the bearing failure in the brake side.
  13. David, I wonder if you have acracked intake beween the "TB" and the head. It's quite common and would explain why your bypass screws would be so different. I, too, would like to know what my CO actually is. It's tthe one wild card that colors all of our information sharing on tuning the FI.
  14. What grade steel wool are you thinking of using? In outdoorsmanship we've found 0000 steel wool to be an excellent fire starter. Even when wet, one spark will ignite the stuff into an aggressively burning mass. Is that a good trait for muffler packing?
  15. Awright, now! This cat business has gone a bit too far! Stuffing a cat in your bell housing? I happen to like the little felines just fine. Especially the way they do 'em in that little place up the street with the Sechuan chili sauce. hmmm . . . tastes like chicken . . .er, I mean, goose . . .
  16. I found a great color match for the painted side plates. Really just needed a touch up ( don't ask) ajnd spent three days looking at finger nail polish (don't ask) with no luck . Best match: Testor's (the model company) Italian Red spray paint. It's a good quality enamel and applies very evenly. It can be sprayed onto a card for a little brush work ( chips, nicks) if need be.
  17. docc
    TECHNICAL
    Al, Where can I get a Twin-Max? I looked back for that thread but to no avail. I tried ordering one from Chapparal but they sent me Hg sticks instead.
  18. Carl, Are you using the same tires on your "bugswatter" as the "exhilerator?" And Dave's talking 160/60 and 110/70? Also I wonder ahat tire pressures you use? I find 38-40 minimizes high speed squirm and firms up cornering. Added bonus: less wear. Regarding the original query: i really enjoy the dramatic compression braking of the Guzzi. Not to mention the acceleration and torque. Multiply that x6 upshifting and x6 down and . . .what's that? oh, the smell of tire having gone away! After the original Pirellis, dunlops, Bridgestones and, now Michelin Pilot Road I get around 4000-4500 (never mind the 2800 on the Pirelli rear). Fronts usually get more .
  19. docc
    TECHNICAL
    My pinging resolved after adjusting the TPS providing a richer mixture through the range. I have also noticed the surprise of richening not lowering fuel economy. Careful inlet balancing also makes these motors very happy indeed. As delivered my sport's pipes were blue and one side much more than the other. Now , with good mixture, they are evenly bronze.
  20. My Y2K V11 Sport came with the forks flush. After increasing my preload with spacers(16 mm!), I dropped the triple clamp 10 mm. My stability (acid) test is 90 mph passing 80 mph trucks on the freeway. It could probably drop the other 6mm , or perhaps more, pending stability and any tendency for the side stand to touch down. The other factors that figure in are your tire pressures, rear preload and rear tire size.
  21. David, Thanks for getting this posted! Those who followed the previous threads remember this filter came out of a good bit of research and the cooperation of pureoil Co. who makes the Purolator. Guys, just take a look at this filter and you'll agree: the laser welded stainless is very robust and appropriate for the vibration level on the spine frame. ( What, you LIKE all that vibration? ) The FI clamps really are a good upgrade as the usual perforated worm gear crap does cut into the fuel line over time. ( Again, read "vibration") Look well ahead! docc
  22. Indeed, the locator bolt is redundant. In fact the 2000 sales brochure claims the clip-ons are adjustable both fore-aft and up-down. The only way to acheive lower position is to loose the locator bolt. I have my 2000 V11 Sport clipons all the up and all the way back. Properly torqued the pinch bolts will prevent slippage under normal use, even at speed. I've only tested mine to 200 kph. Beyond that, you're on your own.
  23. Servicing one's own ride is akin to 'servicing' one's otherwise companion. leaving this to others robs one of the greater satisfactions in life. By all means, set your wrench upon it! After filling my rear drive to the overflowing point (from the level plug) I read ( in "Guzziology") that oil will cascade off the pinion giving a false reading. I found a proper graduated cylinder and measured the oil. The rear drive was at 80 % capacity. Probably adequate but having the full measure makes me feel a better partner to the Guzzi.
  24. My sport was very sensitive to brands of fuel until I richened the TPS. No pinging or stalling but fuel economy went from 37.5 mpg to 34.5 mpg.
  25. I'm trying to understand how a deep sump would solve the starvation problem. I'm thinking it's more the modified pick-up than the actual sump. Is there no way to modify the pick-up on the original set up? Also, do you think a windage tray would solve the starvation?
