Cliff, I had slowly increased my steering damping on my 00 V11sport to compensate for the wear in the front tire. After reading your post (and changing the front tire) I backed the damper all the way off. Felt like the bike lost 75 pounds! On the "some tires - some bikes" discussion: I remember the Pirelli Dragon Corsa that came on the sport. Very nervous tire. Just like Carl was describing, like it would not 'settle down' yet would turn in very sharply. That pirelli has the pronouced 'vee' shape of a roadrace tire. No doubt the V11s is much friendlier on the road with a rounder profile. Look well ahead, docc
While refitting a Merkur (Ford Sierra) i read the opinion that the vast majority of electrical problems can be traced to connections and conductivity. I've found this to be largely true (on the Ford and on an older bike I spent 4 years unravelling). Sure, you could have component failure, but it's worth your time to clean and inspect the harness and connections first. Good hunting and keep us posted! docc
My sales brochure for the 2000 V11 sport says the clip-ons are "adjustable in both width and height." I thought the 'security pins' were for shipping. And, anyway, they're quite secure in that bag with my security reflectors, security off-road plaques and security vapor cannisters. As long as the clip-on pinch bolts are properly torqued to the forks and there are no clearance or binding issues you should be able to position them where you like. The fully adjustable controls are one of the terrific, little noted, features of these bikes. Ride well, docc
I like the 'committed' riding posture of the v11 sport. With the Stucchi fly screen wind lift is reasonable at freeway speeds (70-90). Rather than change the clip-ons, I rotated mine all the way back after losing the little locator bolts that offer only three positions. It brings the torso a little more upright, shortens the reach, without any extensive changes. Without the 'locator bolts' you can lower the clip-ons as well. Handlbars must really change the whole feel of the bike. I'm sure it would enhance the comfort for us "medium-old" guys!
I dunno. 60% of 170 is 102mm and 70% of160 is 112 mm making the 160/70 a taller tire , therefor more circumference. yet if you could figure actual tire size this way ( I'm not convinced the real measure comes out like this) the 160/70 would be 20mm (3/4") taller! It just seems incredible. Using the same questionable method makes a 160/60 12mm (1/2") shorter. Still there's got to be enough difference in the circumference to skew the gas mileage computation from speedo error. Yet:taller tire= taller gear=more fuel economy. Damn, now I'm dizzy again !
My theory on tires for bikes has always been, "try something new. If you don't like it , it'll be worn out pretty soon anyway." It sounds like the concensus is 160/60-17. I'm hearing Bridgestone but isn't there a good handling decent mileage alternative? Ride well, docc
That lower leading edge of the sump is the Achilles' heel of my Sport's vanity. Between the garp kicked up by the tire and that olive-oil -based brake dust, how do you keep that part of the engine looking decent? My owner's manual says to use 'petrol' but that has some auspicious drawbacks not the least of which are toxicity and flash point.
Isn't that tacky? It's the 'press to talk' lead for a two-way radio that I still haven't sorted out. But power mirrors.. hmmm.. is there horsepower in that?
DB, That's good to know. I thought the plaques wre some stupid US federal thing. Now that I know they are genuine MOT they look even better hanging in my toolbox , well and good off the road. I feel better knowing my cans are not being used on the UK motorways and my chance of getting 'nicked' by your constabulary is pretty slim! Good to hear from you, docc
I use the CRG also . They give the bike that loong looow loooook. The elbows aren't seen but the little buggers are quite convex. Objects in mirror are WAY closer than they appear. Still, if you don't expect to differentiate between types of cars (you can tell if the blue lights are flashing!) you get use to the small images (daytime running lights help). I had my bar end weights machined by a local shop to accept the mirror without an adapter. The mount is very secure plus I kept the damping of the original bar-ends( plus added an ounce of lead shot up each clip-on). The machining added $85!!! but the reduction in vibration is just outstanding. If the extra $$ is worth it to you , I have a machine drawing dimensioned for the lathe work. E-mail if you want it. --------------------- docc 2000 V11 Sport Honda GB 500 98 Ford SVT Contour
You know a guy loves his Guzzi when he shares his toothbrush with her!
Konrad, when you get the Mistrals on, make one of those mpeg movies for 'fileshare'. Love to hear your sport in a fly-by!
So, John, how much did your speedo change from 170/60 to 160/60? And your impression of the handling change...? Thanks,docc
So what are you guys going with for 'correct' sag? BTW, Lex, I'd love to see a picture of your V11 with those red legs! docc
Help me out: the way I read this the '01 sport has Sach's rear shock? (my '00 v11s is WP). I'm reading differant spring rates, usually in kg. What is the stock spring rate? Does anyone know what weight rider the stock springs are set up for? Looking to optimize my stock Marz/WP, docc
Carl, That's a good point and I have to agree. I just couldn't think of any other reason why that change would have made any difference. I didn't expect it to change how the bike ran. I really did it more in the interest of purity and the cafe aesthetic. I have read that the check valve on the evap setup can cause tank suction. Although I hadn't experienced that, I wonder - could that vacuum affect fuel delivery? If so that may be another source of the lean condition common to these motors. Thanks for the feedback, docc
Ill bet if a guy had all the hardware , software and time he could really tune the wildcats out of this motor. In the meanwhile, if your bike pings and runs hot a little tweak on the TPS really does wonders. And this for very little investment . When starting with my '00 sport it would pop (intake backfire?) pulling away from a stop. Very discocerting as the bike would try to stand up and change direction. Lousy in a left hander. This grouchy behavior quit with the removal of the carbon cans. The only explanation I have is that the stock setup runs a vacuum tude from one intake to the other . That can't be good - to have the intakes tied together. There are some obvious drawbacks to the mod but, otherwise, some benefits. Tune well, ride well! docc
It's a miracle! Finally, Igot in 200 miles in very cold weather today. The 6-speed shifted wonderfully! I moved the linkage closer to the pivot (the lower position) and this has made an unbelievable differ ence. Still dry after using RTV on the shaft bosses Thanks for the help, guys! Ride well, docc
I had an offer of the software. I could tell ya where I got it but then I'd hafta............no, never mind that. At the time I had no 'puter. Now with a pc I wonder - does the v11 have a USB port? Or some other kind of jack? Jeez, that would sure beat 'backprobing' . Later bikes the ecu is mounted with the connector down making it even a little tougher (What's that up-probing?) Dave Richardson's book "Guzziology" is just invaluable. The FI section is a bit confusing but that's certainly no fault of Dave's. His advice on synchronizing at the off-idle point really smooths the shift transitions. Taking all the extra time to get the synch PERFECT makes an unbelievable difference. That and richening the mixture reasonably makes these bikes so much less fussy. Ride well, docc
To paraphrase, "around here 'off road' is interpreted very loosely!"
You guys are absolutuly right . The Mistral cans shown on hteir site are definately the Guzzi cans. Well, except for the beautiful red oval plaques. My little plaques actually look pretty interesting hanging in the toolbox in front of a v11 sport brochure. Hey, that's off-road, isn't it? Look well ahead, docc
The Mistral cans I've seen have a very nice glossy finish compared to my 'competition' cans. In construction they look more like my neighbor's (m900) Termignoni bu MGNA said (unofficially) they didn't think so. I'll look at the Mistral site for comparison. The Guzzi cans really sound great and they don't look ' bad ' just don't compare well with the Mistral ovals I saw. These were quite a bit more expensive , too.
Does anyone know who makes the v11 accessory "off road" cans ? Are they still selling them with the "off road" plaques?
I was viewing some posts that started with voigtstr that went cold last month. I thought it was worth reposting to keep awareness up. If your Guzzis running hot its not happy . Read," it could eat itself up!" Of course these bikes are set up lean to get through Ellis Island. Pinging is dangrous detonation that erodes the piston tops . New , my sport pinged on some fuels, some conditions. I synched the throttle bodies, removed the carbon cans ( off road use only) , and 'tweaked ' the throttle position sensor. Voila! No lean behavior at all! My dealer copped some set up from some 'tuner.' It was so rich my plugs sooted. I think he was trying to fuel cool my mtor to prevent an engine claim. It would routinely 'pop' upon hot restart (like ata gas stop) and blow the right throttle body off! Very embarassing and annoying. Finally, I reset the TPS at a more conservative setting. No pops, no hot or lean condition signs (no piston erosion ?) . The procedure requires a digital volt meter, "back probing" the computer ( putting a couple straight pins in right connectors ) and setting the TPS. The ECU basically sets the curve a little richer as if the motor was at alittle higher rpm. Very easy very cheap , very effective, Why don't 'dealers' (I want to call them pushers- same thing-right?) do this? My dealers' set-up philosophy ( Mixture, sychronization) seemed to be , "hey, it starts ,it runs-don't mess with it!" We can do better than that guys! These bikes run GREAT when they're set up right. Don't let a lean condition eat your motor! Let the big dog eat! docc
Mike, Unfortunately a new case won't fix the shaft leak. My (former ) dealer told me there is no seal there. He epoxied my first case to seal it saying that would fix it forever . Then the case was renewed and, voila, the drips. I actually fashioned a plug for the lower shaft from a Honda access plug and RTV'd it in. The upper shaft has a cutaway in the case and won't hold a plug. Just liberal RTV there. My (new) dealer suggested the shafts can be RTV'd from the inside to good effect. But,again, apparently no actual seal and I guess the shafts are not press fit. What wre they thinking? Or were they? The leak from the back sounds more serious. My last reassembly was with 'Yamabond' (blue , I believe). Evidentally a vast improvement over the original olive oil and pesto based stuff. What did your dealer use? Don't get caught bent over smelling like 90wt around the Harley guys. docc
