nigev11
    2001 v11 rosso mandello
873 profile views
nigev11's Achievements
Guzzisti
Guzzisti (2/5)
0
  1. nigev11
    nigev11
  2. Love the Rosso! Mines almost finished being spruced up after a hibernation; 100% original just love that very special mica red
  3. PDoz great tips mate, thanks heaps.
  4. Wow! You're right I think! Thanks kindly
  5. i think i have number 395 Rosso Mandello
  6. Hey all I am giving the old girl a spring clean and a spruce up. I cracked my screen and don't think i can get an original replacement. Luckily, the beautiful carbon fairing is in perfect condition and now super clean. While I was cleaning it I noticed an original sticker inside which gave me a very exciting clue; ser no. 395. Now being part of the second batch mine isnt numbered (first 300 were specially numbered models I believe). However, the ser no on the screen made me wonder is this a clue to its heritage? I have no reason to believe the screen isn't 100% original being the third owner. I can see great logic in ATE numbering the fairings for guzzi and thus feel really confident this could suggest my model number? The frame and engine numbers do not have the same 395 designators anywhere however. Any thoughts or clues? BTW, the rebuild and spruce up have restored her former beauty and with a bit of spit and polish, a leather seat re-upholstery and a lot of polishing, Ill reluctantly be selling her very soon.
  7. I know im four years late, But i have a second edition model, pretty much original down under in Sydney. Carefully stored for the last year.
  8. Hi All Long story short, I'm trying to locate (ideally) 2 carbon fairings as per my V11 Rosso Mandello original fitment. They are small, neat and headlight mounted. Aftermarket is ok, but carbon is a must. I can have screen made if need be. Any help much appreciated (tired googling and ebay'ing cant find anything) nigev11
  9. Hi All Long story short, I'm trying to locate (ideally) 2 carbon fairings as per my V11 Rosso Mandello original fitment. They are small, neat and headlight mounted. Aftermarket is ok, but carbon is a must. I can have screen made if need be. Any help much appreciated (tired googling and ebay'ing cant find anything) nigev11
  10. Raz cheers mate, much appreciated! The torque wrench is at the ready with anew set of bits; I'm off to the shed
  11. hey all a long time ago, i learned the value of carefully tightening critical bolts to the correct torque values. the manual has a list of them, but I cant find specs for the main frame/engine bolts, which to me would both suffer a lot of vibration and potentially upset handling and vibes if wrong. Anyone know what the values for these bolts and nuts should be? nigev11
  12. nigev11
    Heated Grips
    hey buzzard I just did a 6000km ride Sydney to Alice Springs to Sydney and that desert night air was cooooooold. I bought some oxford heaters on the way back and they saved my life. I agree the buttons are fiddly
  13. looking for a lemans fairing to fit to my rosso mandello for touring; anyone got one? Condition unimportant
  14. FOLLOW UP; POST REPAIRS hi all; just a quickie to let you knwo how it all panned out. Roper kindly replaced the suspect outer needle bearing with alow cost non standard item. Slightly different length, no problem. Refitted a replacement outer washer (was missing) Fitted new wheel bearings (no problems) Checked the cush drive; all perfect and clean and even came apart well. Drilled and greased the cush rubbers, replaced the brocken cush drive friction gasket, fitted s/s screws and anti seize paste. Got a new spindle (nyloc) nut from the local bolt shop for $2.40. Re-assembled everything with plenty of lube and torques to the coorect setting of 120Nm. Hey presto, good as gold. Rear end feels notciably smoother and less harsh on changes. Free rotation is good and so, Im back on the road and will keep an eye on things but it feels great. Thanks for all your help!
  15. FOLLOW UP; POST REPAIRS hi all; just a quickie to let you knwo how it all panned out. Roper kindly replaced the suspect outer needle bearing with alow cost non standard item. Slightly different length, no problem. Refitted a replacement outer washer (was missing) Fitted new wheel bearings (no problems) Checked the cush drive; all perfect and clean and even came apart well. Drilled and greased the cush rubbers, replaced the brocken cush drive friction gasket, fitted s/s screws and anti seize paste. Got a new spindle (nyloc) nut from the local bolt shop for $2.40. Re-assembled everything with plenty of lube and torques to the coorect setting of 120Nm. Hey presto, good as gold. Rear end feels notciably smoother and less harsh on changes. Free rotation is good and so, Im back on the road and will keep an eye on things but it feels great. Thanks for all your help!
