I had most of the listed problems.
I have a 2000 V11S 14,500 miles
The oil cooler brackets broke and were replaced at my cost with the improved steel ones.
The Tachometer went and was replaced under warranty. The dealer also installed an extra ground line from the tach to the frame.
Tank suck was a problem, so I cut a slit in the rubber nibble that mates when the gas cap is closed. I think removing or repositioning the tipover valve would have been the better solution.
I have had oil weeping in many places, nothing major, so nothing done other than cleaning off the oil, yet.
Front brake warp symptom was cured by lubing the disk at the floaters with silicone spray. (apparently the disks were not warped)
Pinging at full range of rpms and popping at low rpms cured by use of power commander, but the fuel consumption is up, 30-36MPG(US gallons) so I need a better map than what shipped with the power commander.
Front tire cupping cured by getting a front tire that had the grooves running in a direction that did not promote cupping.
Cracked starter cover, no fix yet, but I should drill a stop crack, asap.
Bolts have loosened and fallen out. I should locktite everything! I have lost the rear muffler torx screw, the security bolts that hold on the ignition lock, the bolts holding on the side covers, and a couple others.
Tail light bulb has burned out. I now carry one as a spare but would like to go to an LED lamp.
Original relays were replaced with Bosch 0 332 207 307 with no electrical problems in over a year.
Handle bar vibration was reduced with "Gel Pro Grips" and bar end mirrors. Although the mirrors vibrate more I can see behind me and the handle bar vibration is much less. I have thought about buying V11Lemans bars to replace mine.
Wind blast was kind of reduced with a bmw r90s fairing. The blast of air is reduced but there is more turbulence. It is nice to tuck behind the fairing over a tank bag on long interstate rides or to tuck behind at 100+MPH. plus it looks cool, but not as cool as the magni fairing.
